Question about Epson Office Equipment & Supplies
Ink smudge on right side of paper
After paper jam cleared from Epson 610 Workforce I'm getting red, black and yellow smudges all down the right side of paper.
  • Epson Master
  • 419 Answers
Chances are high that the process of clearing the jam has resulted in ink being released from the cleaning/resting pad area based over on the right hand side (where the printhead sits when not in use).
This waste ink has probable come into contact with the rollers and other parts over on the right edge of the paper.
You'll probably see this ink slowly fade out and disappear over time. If it doesn't however there's something effectively feeding things so check the resting pad for a loose tube, overflow, puddles, etc...
If there's anything like that, report back (preferably with images).
Posted on Jul 22, 2013
Dax_Rush
SOURCE: Ink smudges on the right side of the paper
Your problem is due to a worn fuser unit (upper fuser roller).
The teflon coating has worn again, alowing the toner to stick to the roller and then "repeat" about 3x down the paper (getting fainter each time).
You need to order a new fuser unit.
Click here to go to HP direct
RM1-1083-070CN Fuser assembly - 110 VAC - For LaserJet 4250/4350 series RM1-1083-070CN Fuser assembly - 220 VAC - For LaserJet 4250/4350 series
Make sure you order the currect voltage (US or UK)
Regards
Vince.
Posted on Mar 04, 2009
POCBM
  • 121 Answers
SOURCE: 4 - black ink smudges (1/32" wide x 1/16" high) in right margin
Very nice trouble shooting. The image defect you describe point to the OPC or drum unit this is essentially the toner cart. In your case black. Measureing the distance between repetitive defects is a sure way of diagnosing problems such as yours. Again nice work.
Google repetitive defect ruler for your model to help in the future.
Hope this helps
Posted on Apr 07, 2009
  • 7 Answers
SOURCE: BLACK INK SMUDGE ON RIGHT SIDE OF PAPER IN 3
Although they are quite pricey, it sounds like a new toner cartridge is in order.
Posted on Jun 11, 2009
canontech
  • 1219 Answers
SOURCE: mfc9840 has yellow spotty smudges down left hand
Firstly you need to remove all toners, and drum, then vacume all interior.
Check the transfer belt, drum for any dirt or residues of yellow toner.
If cleaning doesnot help, change the dirty part.
Posted on Jun 15, 2010
Testimonial: "Thanks for the advice, I will give it a go tomorrow"
jas247
  • 844 Answers
SOURCE: my epson workforce 610 had paper jam and I had to
Welcome to FixYa.
Open the Automatic Document feeder and look for any paper left inside. If you forcefully removed the paper without opening the feeder, a mechanism could possibly occur in which case, servicing the printer is the best option.
Press OK, YES then OK to clear the jam message.
Note: For Legal Size paper, load up to 10 sheets only. For Letter Size paper, you can load up to 30 sheets. This is to prevent paper jams.
Thank you for using Fixya.
Posted on Jun 25, 2011
5x7 inch paper moves towards end of print and black ink smudges edge of paper
Check for any small paper jam. Check the rollers, also use an alcohol swab to clean the rollers and check for ink leaking. Check you ink pad, it could be time for a new one.
Jan 21, 2014 | Epson Stylus 1400 InkJet Photo Printer
I have a Epson Work Force 610 series printer that had a printer jam, how can I reset it?
There may be a scrap of paper still jamming the printer. It needs another look
Mar 24, 2013 | Epson Office Equipment & Supplies
Torn paper- how can I disassemble epson workforce 610?
Before you do a complete teardown, use a flashlight to examine every possible point in the paper feed path where the paper is jammed. There may be an easier way to clear it. In some cases I have had to clear a paper jam bit by bit using tweezers.
Oct 15, 2012 | Epson Workforce 610 All-In-One InkJet...
Epson Workforce 610 blocked (or malfunctioning) nozzles
With epsom ink jet printers the printhead is on the machine, not he cartridge as with many printers. This complicates things!
I suggest you get some cleaner cartridges put them in and run one single cleaning cycle each day until the cartridge is finished. Remember just One cleaning each day,,, this is to allow time for the cleaner to sit and "possibly" dissolve the blockage.
It is about your only chance of salvage.
An Ink jet printers worst enemy is sitting for long periods of time without printing on a regular basis, The ink dries in the print head nozzle!
Oct 17, 2017 | Epson Workforce 610 All-In-One InkJet...
Why would paper be jamming or getting stuck on right side with black ink every time?
The rollers that advance the paper could have been messed up by the key, therefore crinkling paper and not advancing in proper timing with the ink. It also could have busted of the plastic gears in modern day printers.
Apr 24, 2012 | Epson Workforce 610 All-In-One InkJet...
My dcp165c printer print quality prints black & yellow colour. i clean print head through maintance 76 but problem cannot be solved
How is the printer printing black and yellow color? Is it a smudge?
When I print, the pages are smudged with ink. What should I do?
Description:
- If smudged stains appear at the top center of the printed page:
  • Make sure the paper is not too thick or curled.
    Also, verify that the appropriate paper is being used and that the paper type set in the machine matches the media used.
  • Make sure the paper is not curled when you print on the back side of the paper with the Print Odd Pages and Print Even Pages settings.
- If smudged stains appear at the right or left corner of the printed page:
- If smudged stains appear on the reverse side or at the bottom of the page:
NOTE: Illustrations shown below are from the representative product and may differ from your Brother machine.
  • Make sure the printer platen is not dirty with ink.
    How to clean the machine's printer platen
    1. Unplug the machine from the AC power outlet.
    2. Lift the scanner cover until it locks securely in the open position.
    3. Clean the machine's printer platen(1) and the area around it, wiping off any scattered ink with a soft, dry, lint-free cloth.
    4. Close the scanner cover.
  • Make sure you are using Genuine Brother Innobella™ Ink.
    > Brother Genuine Supplies information
  • Make sure you are using the paper support flap.
    To use the paper support flap, pull out the paper support (1) until it clicks and unfold the paper support flap(2).
Aug 03, 2010 | Brother Computers & Internet
Hope this helps
Apr 07, 2009 | HP Color LaserJet 2600n Printer
1 inch ink smudge down right side of paper
try going on ur computer that the printer is contected to and have the printer align itself
Mar 17, 2009 | HP LaserJet 1020 Printer
I have black smudges on my printouts. I using
This may be the cartridge itself, take the black ink cartridge out and check the head on it (the part that points in to the printer, usually down) and see if it is dirty or has ink smudges on it.
Mar 12, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Regards
Vince.
Mar 04, 2009 | HP LaserJet 4250n Printer
109 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
