Question about Master Mechanic Wet/Dry Vac, 16-Gal., 6-HP
Wet/Dry Vac, 16-Gal., 6-HP manual - Master Mechanic Wet/Dry Vac, 16-Gal., 6-HP
Suction is greatly reduced. Why?
dirty filters or bad lid seal can do this , also items can stick inside your hose too blocking its way
May 21, 2015 | Craftsman 16-gal 6.5-peak Hp Wet/dry Vac...
Can I use shop-vac without bag 5gal5.5 hp
If you are using it for wet pick up, you would not use the bag. If you are using it for dry pick up, I would recommend using the bag to keep dust from going thru the vacuum and back into the area you are trying to vacuum.
Apr 06, 2014 | Shop-Vac Corporation Shop Vac Wet & Dry...
Trying to remove a hose from a 10 gal shop-vac? Any Suggestions???
The hose connection unscrews, but it might be difficult to loosen.
Dec 03, 2013 | Shop-Vac Corporation ShopVac 962-47-10...
Wet vac wont turn on
That Model of Shop vac often has on/off switch failure.
Dec 02, 2013 | Craftsman 20 gal, 6.5 Peak HP Wet/Dry Vac
My rigid shop vac 4 gal 5.0 WD4070 wont start
Check elecrical connection, or switch may be bad.
Apr 14, 2013 | Ridgid Wet/Dry Vacuums Wd4070 4 Gal...
I have an old shop vac floormaster wet & dry vac, 8 gal., model 700c. I need the users manual to find out how to use it as a wet vac.
http://www.hammerwall.com/Download_Manual/16114/
GO TO THE ABOVE ADDRESS TO GET YOUR MANUAL.
REGARDS.
PLZ RATE THIS
Jul 04, 2011 | Vacuums
Genie 400PC 16 gal shop vac but can't find filters
If you need paper filters, you can easily use a bag filter cut in half, and have less dust clouds than the original filter. Remember to use the lock ring. Generic ShopVac mini's have the same filter in foam.
Mar 11, 2010 | Genie Company GV150 Wet/Dry Vacuum
Moto Brushes Problem... Who could help?
where can i fine moter brushes for my ridgid 5.25 hp 16 gal. wet dry vac.
Oct 02, 2008 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
177611 wet/dry vac
Either you aren't getting the top on correctly so it will latch, or there maybe a problem with the latches. You should have a one year warranty on this, take it back to Sears and have them look at it.
Nov 13, 2007 | Craftsman 17765 Canister Wet/Dry Vacuum
Master Mechanic Wet/Dry Vac, 16-Gal., 6-HP Logo
74 people viewed this question
Top Master Mechanic Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Master Mechanic Health and Beauty Expert? Answer questions, earn points and help others
