Question about Electrical Supplies
Spark plug wire order
How do you find a crossed spark plug wire on 3.o v6 taurus
  • 77 Answers
SOURCE: firing order for 97 chevy blazer
Firing order is 1-6-5-4-3-2. Distributor cap should be numbered. Number one cylinder is front on driver's side (3 and 5 follow on same side). Number 2 is front on passenger's side (followed by 4 and 6).
Posted on Apr 29, 2009
blueextc3221
  • 15935 Answers
SOURCE: I need the firing order for the spark plugs and plug wires I recently changed them and something is not in the correct order
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question!
Posted on May 23, 2009
  • 2841 Answers
SOURCE: i need to see a diagram of in what order the spark
Here you go: bb707d8.png
Posted on Feb 14, 2010
Testimonial: "clay58 came thru in a pinch! Thank you!"
  • 1757 Answers
SOURCE: what is the spark plug firing order for 3.3 v6
For the 2002 Dodge Caravan (and Grand Caravan) ALL 3.3L V6 Engines (including the Flex Fuel): Also for 3.8L V6 Engines:
Firing Order:
1-2-3-4-5-6
Cylinders:
........(back).......
|...1....3....5...|
______________
|...2....4....6...|
Ignition Coil:
.......(back)
electrical connection
..........V
5........1........3
2........4........6
.......(front)
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
Posted on May 18, 2010
  • 1757 Answers
SOURCE: GM 3.8 liter supercharge v6 firing order 2000
For the 2000 Pontiac Grand Prix:
I do not know if you have the 3.1L V6 or the 3.8L (including Super Charger) V6; however I have included both below...
For the 3.1L V6:
Firing Order:
1-2-3-4-5-6
Cylinders:
......(back).......
'...1....3....5...'
____________
'...2....4....6...'
.......(front)
Ignition Coil Connections:
.'.5..2.'..'.3..6.'..'.4..1.'
For the 3.8L V6 including the Super Charger:
Firing Order:
1-6-5-4-3-2
Cylinders:
.....(back).......
'...2....4....6...'
____________
'...1....3....5...'
......(front)
(back)
o 6
o ---3
___
o 2
o ---5
___
o 4
o ---1
(front)
Let me know if this helped, or if you have additional information or questions. Feel Free to contact us at FixYa.com!
Posted on Oct 08, 2010
What is the Wire Order with distributor?
theres no distributor and the firing order for your 3.8 is 1-6-5-4-3-2-the following link shows the coil pack
Buick General Motor 3800 V6 Engine Firing Order DIS IDI ignition timing 3.8 Buick Engine Coil Pack Firing Order Spark Plug Wire Location Which way do the spark plug wires go on & what cylinder is what?
For the Buick V6 231 3.8 liter turbocharged engine:
Answers!
Firing order:
1 - 6 - 5 - 4 - 3 - 2.
Spark plug wire location on coil pack:
Closest to the back of the car, left to right: 1 - 5 - 3.
Closest to the front of the car, left to right: 4 - 2 - 6.
Spark plug wire location on engine:
drivers side, front to back of car: 1 - 3 - 5.
passenger side, front to back of car: 2 - 4 - 6.
.----and this link shows the coil pack to cylinders
3 8 Buick Turbo Engine Coil Pack Firing Order Spark Plug Wire Location
Aug 15, 2015 | 1987 Buick Regal
I trying to fix my 2001 ford taurus i had someone put a new gasket on it and i think they put the spark plug wires in the wrong spot so i need a firing order for a 2001 ford taurus v6
the coil should be labeled with the cylinders near each post. the back three cylinders are 1-2-3 and the front three cylinders are 4-5-6.
Nov 24, 2010 | 2001 Ford Taurus
Firing order diagram ford taurus v6 3.06 6 cylinder engine, and which one is the number 1
FIRING ORDER IS 1 4 2 5 3 6. STANDING IN FRONT OF CAR ON PASSENGER SIDE FIRST CYLINDER FRONT IS 1 2 3 ON DRIVER SIDE FIRST CYLINDER FACING YOU ARE 4 5 6 SEE 1 CYLINDER FACING YOU ON PASSENGER SIDE.GET A PIECE OF PAPER WRITE NUMBER ON TOP ACROSS LARGE NUMBERS 3 2 1 AND BOTTOM OF PAPER WRITE NUMBERS 4 6 5 THATS COILS WIRES FIRING ORDER TO SPARK PLUGS.
Sep 26, 2010 | 2000 Ford Taurus
Replacing spark plugs
Not exactly sure what you need?
Standard Rules:
Use a Spark Plug Socket to remove and install Spark Plugs.
Replace (remove) one Wire at a time from one Spark Plug.
Replace One Spark Plug at a time. Use Anti-Seize Grease applied moderately to the threads on the new Spark Plug.
Using a Socket (with a extension) START all installations using your hands. This prevents cross-threading and stripping of the threads inside the Heads.
Standard Torque 15-20 ft-lbs.
Replace the One Wire connection to that One Spark Plug.
Replace that One Wire connection to the Ignition Coil.
Go onto the next Spark Plug using the above Rules.
Repeat.
For the 3.4L V6:
Firing Order:
1-2-3-4-5-6
Cylinders:
......(back)
1.......3.......5
2.......4.......6
......(front)
............(back)
.|.5..2.|..|.3..6.|..|.4..1.|
............(front)
Mar 21, 2010 | 1997 Chevrolet Venture
What is the firing order for a 1997 Ford Taurus.
2.5L Engine: 1-3-4-2
V6 3.0, 3.8: 1-4-2-5-3-6
Taurus SHO V-8: 1-5-4-2-6-3-7-8
V6 Cylinder numbering:
1 - 2 - 3
4 - 5 - 6
(Front of Vehicle)
The coil pack looks like this
--4 pin--
--1--- 2--- 3--
--5--- 6--- 4--
----------------- Coil: with the connector positioned in the lower right hand corner, the upper row from left to right is: 4-6-5. The lower row is 3-2-1.
Sep 03, 2009 | Spark Plugs BR4HS Plug 10/BX #3322
I replaced my spark plug wires on my 1996 chevy truck. may have crossed one,need a diagram from the spark plugs to the distributer cap.
Since you didn't state whether it is a V6 or V8, I'll give you both.
V6 -4.3Liter
Firing Order is 1-6-5-4-3-2
Distributor rotor turns Clockwise
Number 1 spark plug tower on distributor cap, faces the front of the engine.
->Drivers side, spark plug order in engine, starting from the Front going back:
1-3-5
->Passenger side, spark plug order in engine,
2-4-6
If it's Electronic, the distributor cap has a Left side, (Drivers side), and a Right side, (Passenger side)
Starting from the Front, going back on the Left side,
3-1-5
Starting from the Front going back on the Right side,
2-4-6
V8-5.0, 5.7, and 7.4Liter
Firing Order is 1-8-4-3-6-5-7-2
faces Front, towards the Drivers side.
Electronic distributor cap has two sides. Drivers, (Left), side and Passenger, (Right), side.
Starting from Front going back on Drivers side,
1-7-3-5
Starting from Front going back on Passenger side,
8-2-4-6
Spark plug order in engine, starting from Front going back, Drivers side:
1-3-5-7
Spark plug order in engine, starting from Front going back, Passenger side:
2-4-6-8
Aug 28, 2009 | 1996 Chevrolet K1500
Spark plug wiring diagram
3.9L V6 Engine. Engine Firing Order: 1-6-5-4-3-2. Distributor Rotation: Clockwise.............did i guess the right motor? let me know/rate me
Jan 14, 2009 | 1991 Dodge Dakota
Spark plug wires
I do not know if you have the 2.5L (4-Cylinder) or the 3.0L V6; however I have included both below:
For the 2.5L:
Firing Order:
1-3-4-2
Cylinders:
.......(back)
1.....2.....3......4
.......(front)
Distributor:
.....(back)
(+).....4
...............2
.3
.......1...(+)-screw
For the 3.0L:
Firing Order:
1-4-2-5-3-6
Cylinders:
........(back)
1.........2.........3
4.........5.........6
.......(front)
Distributor:
....(back)
......(+)-screw
...3.......6
5.............1
...2.......4
......(+)-screw
....(front)
May 16, 2008 | 1986 Ford Taurus
Electrical Supplies Logo
206 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
