Question about Panasonic SA-HE7 Receiver
Channels right channels not working
  • 3,799 Answers
Check your cables and then move the channel selector through all settings a couple of times. This will give some indication of the real problem. If the channel comes back after exercising the channel selector, then you have a "Furred up" selector. If the channel doesn't come back then you may have a failed amplifier in the amp.
Posted on Jul 22, 2013
Sansui AU-D33 Lh speaker channel not working.
As the channels are identical you can use the good channel has a guide to the bad one. First thing is to look around see if anything does not look the same as the right channel.
If nothing obvious stands out, with the power on, using an insulated screwdriver touch the two channels one at a time. Keep away from the power supply and anything that is common to both channels. The channel will buzz once touched. Depending which points you touch them. The right channel will tell you if it should buzz at that point. Work backwards from the speaker outputs if you can. If you hear a buzz on the left channel then it is working at that point, if it produces the same sound on the right.
Using this method you should track down the part that has gone.
Dec 11, 2015 | Audio Players & Recorders
Right channel distorted denon UDRA M7
Hello there, I have the same amplifier and now it has the same problem on the right output. Have you found out how to fix it? Thanks!
Nov 07, 2013 | Audio Players & Recorders
Right channel not working
An idication of a faulty headphone socket if the headphones being inseted cuts off the speakers. Otherwise a faulty switch that switches the speakers off.
Jan 27, 2013 | Cambridge Audio Azur 640A Amplifier
Why is my right channel not working on my Technics reciever?
The right channel output section or speaker might have damaged. Seek tech support.
Jun 03, 2012 | Audio Players & Recorders
YAMAHA RXV350 RIGHT CHANNEL NOT WORKING
Adding on again: I have interchanged speakers, if i connect any speaker on the right front channel it will not work. When I do a automated speaker test only right front channel does work.
Jan 26, 2012 | Yamaha RXV-350 Receiver
My Harman Kardon AVR 220 reciever's front-right channel isn't working. I have switched the two front speakers and the right speaker works on the left channel so it is not a problem with the speakers or...
if front left is working it is possible u have a dry solder on ur right channel line. try resoldering or if u want to know exactly where dry solder is, shake gently every right channel components and connections. if resoldering does not work it is possible u have a faulty ouput amp for ur right channel. if ur not sure about this i suggest u get it checked by a qualified tech.
Apr 05, 2010 | Harman Kardon AVR 220 5.1 Channels...
Describe your Onkyo TX-SR875 7.1 Channels Receiver Problem All right channels are not working. Left channels including center channel speaker is working. Please advise.
Recommend changing your FINAL drive AMP IC most house BOTH right and left channels, your drivers right channel input is good cuz it is used to make the left channel signal
Nov 22, 2009 | Onkyo TX-SR875 Receiver
Only the right channel working on the amplifier
first check on all your cabling, speakers and input sources for loose/defective cables. can you tell me what brand is your amp and model? does it employs digital source switch or mecahnical switches only.
Aug 12, 2008 | Audio Players & Recorders
Right channel doesn't work
check you rca jacks switch sides if the right channel still has no sound then it needs repair if the left channel doesnt work then the rca jacks are messed up
Mar 26, 2008 | Pyle 3000 Watts 2 Channel High Power...
Mitsubishi HS-412UR - Audio - Right Channel Not Working Properly
One of the strangest things that has happened to both the consumer and the technical field has been the use of a flexible adhesive on many of these machines' circuit boards. The glue in question is vanilla-colored, and has a tendency to react to electricity by inducing capacitance, resistance, and in some cases, even causing inductance issues. The fix, of course, is to remove as much of this material as possible, and following right behind with a nylon-based retainer. Then, if the problem persists, a followup with tried and true technical procedures...accordianman
Feb 12, 2008 | Televison & Video
Panasonic SA-HE7 Receiver Logo
175 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
