Question about Whirlpool Dishwashers
Whirlpool shu7004 will not start after closing door and pulling on knob
4 Suggested Answers
dniro592006
  • 121 Answers
SOURCE: My whirlpool top load washer will not start when I pull the knob. It makes a humming noise.
Motor sounds like its not starting up strong
May need a motor....
Posted on Jun 02, 2009
SOURCE: whirlpool gd5thgxks01 door does not auto close
You need to level the refrigerator slightly backwards so the weight of the door closes it automatically. The front legs are adjustable, so just turn them until the door closes on its own.
Posted on Aug 05, 2009
mnwarfield10
  • 452 Answers
SOURCE: Closed door selected the cycle pulled knob out light for door lock came on but didn't start tried to open the door with the door lock light on and it opened. unplugged machine and the plugged it back
change door lock unit.. it sounds it has gone faulty.
Posted on Nov 25, 2011
How do you dry clothes in this machine please
A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
http://www.manualslib.com/manual/511763/Whirlpool-Lte5243dq.html?page=10#manual
Nov 14, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
Will not start
This is hard to diagnose without tools. The first thing to do is check the breaker for it. See if it has tripped. If it has not then turn the dial to a setting and close the door and put your ear right on the knob to see if you can hear anything that sounds like a small electric motor.
If you hear that then there is power to the unit. If not then you need to pull the unit out and get some test equipment to see if it is the power, siwtch, motor, latch etc.
Jun 04, 2014 | Whirlpool Dishwashers
The touch bottons are clicking on and off and nothing works. I had to shut the washer off in a hurry recently and this is the result.
Make sure the door is completely closed and latched. On models with a dual-digit display, the control displays "- -" during a cycle if it believes the door is not latched. Check for obstructions (spoons, etc), interfering with the door operation. A lower dish rack that is installed backward will also cause incomplete door closure.Is there power to the dishwasher Check your household electrical box to see if a fuse has blown or if the circuit breaker has tripped. If the unit has a plug-in power cord, make sure it is plugged in.Does your dishwasher have a rotary timer knob? (Some Models)The cycle selection must match the position of the timer knob. Turn the timer knob to the beginning of the preferred cycle. The timer knob should click when you reach the start of the cycle.Is the control lock option activated?Press and hold the Heated Dry option (button with lock icon) for three to five seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.Is the delay start option activated?To cancel the delay and cycle, press Cancel/Drain.Has the motor stopped for less than 10 minutes?
The motor may have stopped due to an overload. If this is the case, the motor will automatically reset itself within 5-10 minutes.Is the Start/Resume indicator flashing?Opening the door or interrupting the power can stop the cycle. Close the door and press Start/Resume. If the Start/Resume indicator flashes three times when you press Start/Resume, the dishwasher is waiting for you to open the door after the last cycle. Open and close the door, and then press Start/Resume.On models where the controls are on top of the door be sure to close the door within 3 seconds of pressing the Start/Resume to start or resume the dishwasher cycle.Is the water shutoff valve (if installed) turned on?Make sure that the water shutoff valve is turned on
Sep 10, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Knob will not pull out to start dryer
i dont there is a pull out knob on dryer there should be a start button knob is to set time make sure door is closed and push all buttons ans see what happens
Sep 11, 2009 | Hardware & Accessories
Dryer not working
How do you know the belt is on? Did you take the unit apart? Maybe a connection to the control knob came off. Otherwise:
1) Check the breaker to see if it has been tripped
2) Dryer plugged in
3) dryer door securly closed
4) if your unit is a single knob with various dryer settings, try a different setting (delicate, permanent press, etc)
5) if your unit has a start button, set the knob to the desired setting first, then press start.
Jun 09, 2009 | Whirlpool Dryers
Must repeatedly slam top loading door shut for machine to start
on the inside of the lid there is a lid switch hole that a plastic tab goes down through the switch could be bad or the screws holding the switch in could be lose or broken
Mar 28, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
I have a whirlpool duet washer and dryer the dryer lights all come on but I get a beeping sound and dryer will not start
try to unplug the dryer for 5-10 minutes this should reset the board. if not take off the bottom panel and test the resistance of the thermistor ( the tech sheet is in the bottom there or up top)
Dec 09, 2008 | Whirlpool GEW9250 Electric Dryer
The dryer has power but the start cycle knob only buzzes
IF THIS MODEL USES THE TIMER TO START THE MACHINE BY PULLING OUT ON THE KNOB, I HAVE HAD TO REPLACE QUITE A FEW TIMERS FOR THIS PROBLEM. SOMETIMES BY MOVING THE KNOB UP AND DOWN AND SIDE TO SIDE WHILE PULLING WILL START THE MACHINE. IF SO, REPLACE TIMER.
Nov 20, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
I dont know how to start the whirlpool ultimate care
make sure the door is closed all the way and set it to the cycle you want and push the timer knob in and hold it for a second to start it.
Jun 28, 2008 | Whirlpool Dryers
Dishwashers Logo
22 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
