Dell Studio 1737 Laptop Logo
Anonymous Posted on Jul 21, 2013
Indicator light of charger not working - Dell Studio 1737 Laptop
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Jul 21, 2013
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
383
Points
33
It is most likely that the led has blown out of the computer if you have had it for more than 5 years that is most likely the problem if it is not go into your control panel and reactivate led lights in the device manger
Why doesn't my battery charge? Why doesn't the charger's light come on?
Hi Suzanne! Follow these steps to check that your charger and battery are working properly.
1. Unplug the charger for at least 30 seconds.
2. Plug the charger back in. The blue light on the charger should flash once.
If the blue light flashes once this is an indication that the charger is still functioning properly. If the blue light does not flash, the charger will need to be replaced. Follow this link to order a replacement charger. LiNX Battery Charger
3. Place the battery in the vacuum and turn it on for 30 seconds. (even if it does not turn on or powers off)
4. Turn the vacuum off.
5. Remove the battery and place it in the charger.
If the light on the charger is solid blue this is an indication that the battery has been reset. Allow 3-4 hours for the battery to fully charge. The blue light will start to blink slowly to indicate the battery is fully charged.
If the light on the charger is flashing blue or there is no light at all this can mean that your battery needs to be replaced. Follow the link to order a replacement battery. LiNX Lithium Ion Battery
Hope this helps!
Bosch ixo charger not working
About the only indication if the charger is not working is when you put the batteries into the charger and no lights come on. This indicated that the charger is faulty. If the lights come on it is most likely the batteries. The best thing to do is take the batteries and charger to a Bosch service center and they will test them for you. Most will do this for free.
Dec 03, 2012 • Drills
Battery charger light doesnt work showing that the batteries are being charged.
okay first of all check that the batteries can be seen from the charger socket, otherwords get a electronic meter and insert the probes in the two outside holes , do you get a reading on DC ?
I have an amigo RT, bought is second hand. I bought new batteries but the indicator light on the front control panel drops down rapidly. any suggestions
check the charger, if you plug it in the indicator should blink for aprox. 30 sec. then go solid and when charge is complete the indicator will start to blink again, also if the charger is working the scooter should not move when plugged in, if charger not working check power cord before replacing charger
Our black and decker 14.4 Dustbuster is functioning but the charger does not shot its light that will indicate of charging. we dont know if the charger is not working or just the charge light is the one...
You can test the output of the charger with a multimeter. Set it at about the 20v scale and touch the contacts at point where it connects with the Dustbuster. If you get a reading it means that the charger is working. I would say that the charger is most likely not working because LED indicators very seldom fail while chargers are not all that reliable.
How do I know when an EN-EL! for the Nikon Coolpix 5000 is fully charged? what do the following conditions indicate? 1. Charger red light flashing 2. charger red light steady 3. charger red light...
Charger flashing red indicates the battery is still not full and is in the process of recharging.
Red light steady indicates your battery is fully charged and ready to operate with your Coolpix 5000.
When red light is off it indicates there is no battery inserted or the charger is not pluged in.
1helpful
Charger seems not to work and indicator lights on
The chargers are pretty fragile - I've seen several dead ones. If the light doesn't go on when you plug it in you pretty well need a new one.
1helpful
Charing my battery for a FireStorm 9.6V
Yes, it means the charger is not working. The light is the charge indicator and is red while charging.
If you need further help, Iā€™m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Nov 05, 2009 • Drills
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
