Question about IBM ThinkPad R40 2722 Notebook
IBM ThinkPad R4O - Screen is blank *ugh*
Hi everyone! I want to say thank you and I appreciate your help in this matter.I do not know what is going on with my laptop. I turn on my laptop and the screen is blank. I shinned a light down and I see no image. What should I try? I am a single mom trying to get this up for my 9 year old so he can have something to use for school. Sincerely, Denise
  • 1 more comment
  • Denise  Delmolino
    Denise Delmolino Aug 29, 2007
    Thank you Benimur!
    Something new has happened...
    Last night I turned the laptop on, it started up and even showed the desktop! All of a sudden, my screen turned blue with allot of writing... then it shut off. And now i don't see the desktop - Weird!
    Help!
    *hugs*
  • Denise  Delmolino
    We are almost there... thanks!
    ~Denise
  • Musky2 Apr 11, 2008
    My daughter is on the phone with me right now with the same problem! How did you end up fixing yours?
    Thank you!
    Brigadier General:
  • 6,966 Answers
Hi Denise, Based on your post/description, it is not an LCD display problem then. You may want to check if it the leds/lights flash/lite up when you plug the AC wall adapter, also is there any beeping sound, any whirring or spinning sound from the inside when you power it on. If there are some indicator lights, it is possible that it's just the memory loose underneath the laptop. Turn it over (bottom side up) and look for a panel/lid with a screw (or 2). Open, inside should be 1 or 2 strips of memories. Parting sideways the 2 locks at the side will pop the memory up a bit. Slid it out and proceed to clean the little gold terminals at the bottom with a pencil eraser. you may also want to clean where it is inserted. An unused paint brush will do just fine. Other that that, couldn't think of any more steps you can take without opening the laptop fully. Should this still be a nogo, you may need the services of a qualified comp tech. Hope this be of some help/idea. Post back how things are or should you need further information. Good luck and kind regards.
Posted on Aug 29, 2007
  • Louie  Role
    Louie Role Aug 30, 2007
    Hi again Denise,
    Have you tried the memory cleaning/re-setting?
SOURCE:
Hi, I can't login to my thinkpad T400 2765 R2A windows vista?
First of all try using blank (none) as password (otherwise at the log on screen hit "enter"). If this doesn't work log on at the administrator's account. To do this if you can see the administrator's icon click on it and use blank (none) for password again. If you can't see the administrator's icon, hit ctrl+atl+del TWICE and type as user "administrator", blank (none) for password and hit enter. After you log on as administrator change your user's account as you wish and you are ready to go.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
May 14, 2010 | IBM Lenovo ThinkPad T400 7417 Notebook
Faulty screen - blue with lines -thinkpad - help please!!
You have faulty memory, replace the memory cards. If that does not fix the problem then the video card is faulty. first change the memory cards. If it is integrated on the motherboard, buy an PCI graphics card. I hope this info was helpful.
May 11, 2009 | Computers & Internet
Ibm turns on than shuts down
Hi, May be the harddisk is not recognizing. Restart your laptop and go for BIOS and check whether the harddisk is recognized.
Mar 09, 2009 | IBM ThinkPad R40 2681
Locked screen
I found a page with a video, on how to open a padlock - I hope this is what you need, it looks easy.
3325d60.png plz let me know how you go - maybe I know of a safe we colud open...
/Teis
Jan 16, 2009 | IBM ThinkPad T20 2647 Notebook
Screen is blank although sound and lights are evident
Try removing and reseating your CPU, video cable and or memory. If nothing stills hapens, your video card or chip may have gone bad. Please let me know if this works.
Dec 13, 2008 | IBM ThinkPad T43 Notebook
T30 motherboard problem
press f8 on boot up. select safe mode
Go start>run
type msconfig
hide all micosoft items in services and deselect the remoaining
Also deselect any "dghdfg" looking items from startup
Reboot
Install CCleaner & run
Dec 12, 2008 | IBM ThinkPad T30 2366 Notebook
T41 IBM thinkpad monitor goes off
Saw exactly the same think on another t41 i was trying to fix. If it was moved at all screen went off.
Turned out it was corrosion on the motherboard that was causing the problem.
Has it been liquid damaged or got damp in the past?
Jan 07, 2008 | IBM ThinkPad T41 Notebook
LCD BLANK
Laptop Screen Dim, Blank Or Black - Notebook LCD Display Monitor ...
Click on the above link/ Follow instructions.....Good Luck.
Please dont for get to Vote.Thank You.
Dec 15, 2007 | IBM ThinkPad T30 2366 Notebook
Disabled video card drivers for IBM ThinkPad A31 2652=Blank screen on reboot
hi, so far as i can understand ur question, u have disabled the video card in the device manager, if thats the case then post boot hit the F8 key which will take u to the startup menu, select safe mode with VGA option, then enable the vga card back and restart.. let me know
Nov 24, 2007 | IBM ThinkPad A31 Notebook
IBM T30 Start Up Problem
see website laptoprepair101.com, sev eral ways to test this problem
Mar 28, 2007 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad R40 2722 Notebook Logo
206 people viewed this question
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
