Question about Sony MDR-IF5000 Headphones
Battery replacement for sony wireless headphones
I don't understand the breakdown to replace the recharchable batteries
3 Suggested Answers
SOURCE: Sony 7506 Headphone Replacement Drivers
One of the channels on my MDR-7506 gets a little fuzzy in the bass intermittently, too. It's got a sound like there's just some hair or something in there; it doesn't sound like an electrical noise. This is not a very professional solution, but I found the problem goes away if I give it a good tap with my finger, right on the driver (the part that faces your ear). No need to remove the covers or anything. The delicate parts of the driver are well protected from something as blunt as your finger. As long as you're not pounding on it or jamming things into it, there's no danger of doing more damage. In mine the symptom is a minor inconvenience, so I'm not inclined to buy new ones yet. I heard that special ordering each driver from Sony costs almost as much as a whole new unit, so repair isn't cost-effective if the driver really needs to be replaced.
As for replacement, well, for durable, multi-purpose headphones with great range at a reasonable price, the MDR-7506 can't be beat. Some people say they think the high end is too bright on these, and the low as well, but if you've got normal patterns of hearing loss, you probably need the slight boosts, IMHO. Just don't switch to anything else without testing them out with your own music first; if you go shopping for something different, go to a store that lets you test the phones and bring some CDs and/or a portable player with music you're familiar with.
Posted on Jun 26, 2008
SOURCE: SONY MDRIF610 Wireless infrared headphones -- I
Hi, to reach the internal battery You have to 1) gently detach the L(left) internal soft ear cover from the headphones, 2) Unscrew the 4 internal screws -- To replace the original NiCd 600mAh battery, You have to unsolder the contacts of the old battery and solder the contacts of the new one. You must buy a battery with soldering tabs, because tabs are very hard to solder well. - Yes, ONLY with this model You may use a NiMh battery, because the original charge-circuit was designed to stop after the battery is fully charged. (NOT many NiCd battery chargers have a cut-off circuit based on battery charge. they use only thermic protection cut-off) -- I've used 2800mAh NiMh to solve the problem, but I'm thinking to use the new hybrid cells battery, because they have a very small discharge rate when are not in use. -- No, You must not use LiIon or LiPo because they need a more precise charging rate and they may explode.Simply don't do that! ;-)
cheers, Rcatech
Posted on Mar 02, 2010
Sony wireless headphones keep shutting off
Check up the batteries and replace by new one.
Or remove the battery and reinsert.
Sep 09, 2014 | Sony MDR-7506 Professional Headphones
My battery terminals keep snapping and I have replaced the postive twice already in two months. What could be causing them to snap in half? They are hard metal so I don't understand.
A poor connection to the battery can melt a cable. Make sure your battery terminal is clean and free from corrosion.Make sure that your battery lead has slack and that it is not taught, especially when the engine is revving.
Make sure you don't over-tighten the soft battery terminal as it will over stress.
Nov 14, 2012 | 2001 Ford Explorer Sport Trac
Need replacement button battery for (Sony) MDR-IF320RK
I have the same problem.
I am about to wire in an AAA NiMH cell. Putting it on top of the plastic cap.
Aug 21, 2012 | Audio Players & Recorders
How do I change batteries? I cannot find their location.
The right earphone holds the batteries. Grab the cushion and TURN it slightly and it will release from the headset. Don't pull it off without turning first.
The two AAA batteries are exposed. Just replace and replace cushion with slight turn.
Sep 10, 2011 | Koss Quiet Zone QZ99 Consumer Headphones
After I charge my Altec 903 wireless headphones and I try to use them, they don't turn on; only when they are connected to the electrical source
I am afraid your batteries are dead..
they are replaceable Chargeable batteries ,pls replace them as soon as possible.
.try to buy more amps rated ones to use it longer among charges....
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Jul 21, 2011 | Audio Players & Recorders
I have 2 sets of Sony MDR-RF970R Wireless Headphones. On set works O.K. The other loses contact with the base intermittantly. Sometimes it reconnects and other times when I operate the headband switch...
Are you using the rechargeable battery that was supplied or have you ever replaced it?
If you're still using the same rechargeable battery then it's probably worth trying a decent set of AAA alkaline batteries or other rechargeable batteries.
If this doesn't solve your problem then you're probably right in the fact that there's a fault or loose connection in the automatic headband switch. The only real repair solution would be to have a look at them yourself as taking them anywhere for repair wouldn't be cost effective.
Jun 21, 2011 | Sony MDR-RF970RK Headphones
SONY MDRIF610 Wireless infrared headphones -- I have two sets that won't work -- the Infrared units light up, but I get nothing from the headphones, which haven't been used in a long time and don't seem to...
cheers, Rcatech
Nov 21, 2009 | Sony MDR-NC11 Consumer Headphones
Sony MDR-IF5000 Headphones Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
