Question about Ariens Garden
Adjusting belt on riding mower
Belt loose
dgjtex
  • 405 Answers
SOURCE: I NEED BELT DIAGRAM FOR MY HUSQVARNA RIDING MOWER
http://www.usa.husqvarna.com/home.aspx try this out for your answers, I hope this helps you. MERRY CHRISTMAS!
Posted on Dec 23, 2008
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
  • 10865 Answers
SOURCE: murray belt manual for a 20hp 46" rider lawn mower
here is a link to all of the murray manuals, for free. pick out your model and enjoy your manual.
Posted on Jun 02, 2009
  • 10 Answers
SOURCE: Trying to put on mower deck belt for cub cadet
Visit this web site http://www.partstree.com/parts/
you can pull up your Cub
Posted on Oct 18, 2009
  • 78 Answers
SOURCE: HONDA 3011 LAWNMOWER RIDING HOW DOES THE BELT ON
I dont have the diagram but remember the V of the belt aways goes in V pulleys and the back of the belt on flat pulleys . Honda provides you with diagrams at hondapowereqipment .com
Posted on Oct 27, 2009
When engaging cutting leaver on rideon the belts underneath are still loose and does not turn cutting blades .all springs look okay
Are you sure the belt is good. May be coming apart. If its ok check the pulleys and the belt adjusting tightener. sounds like something is not working properly. Have you installed a new belt and is it the right one for that machine. Has the belt slipped off the tightener. Can't say but just giving suggestions.
Dec 26, 2016 | Garden
Me drive belt is loose
Assuming the tensioner pulley is good and the associated spring is still stiff then the belt has simply stretched with time and use and should be replaced.
Jul 30, 2016 | Husqvarna Riding Lawn Mower 42 Inch Cut...
My Craftsman riding lawn mower LT2000 (2002/2003) stopped moving. The drive belt seems to be loose. The engine starts and cutting blade engages fine. Was working fine but stopped working when it started...
there should be a drive belt tensioner somewhere on the belt, it usually works off the clutch/brake, when you push on the brake it apply's the brake and also takes the tension off the belt to stop it from moving.
Not sure of your ride on mower but that is how my ride on mower works so I hope this helps.
May 19, 2014 | Craftsman Garden
My craftsman riding mower vibrates so bad when I engage the mower. How do I stop vibration?
Things you need to check, loose blades, blades out off balance, bad belt or loose belt, bearings in the blade mandrels worn.
Jun 29, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do you tighten lower belt on a 42 ich yardman riding mower?
By lower belt i suppose you are reffering to the drive belt or the blade deck belt, either way these belts are usually tensioned by a spring loaded idler pulley. If the belt is still too loose even with the pulley tensioning it, it may be time for a new belt (that one may have streched out a bit).
May 06, 2010 | Garden
Tighten belts on my Yard machine ride on lawn mower
There is rarely any adjustment to tighten the belts on a riding mower. The belts are tensioned by an idler pulley which is controlled by a idler pulley spring. Almost all riding mower belts must be accurate to the hundredth of an inch or no less than accurate to 1/8th inch. It is very rare for a belt to be in full inch increments. This is why automotive or general purpose belts will not work on a riding mower. I know it is tempting to try to get by with a $10 belt rather than spending $35 or more for the correct belt. Trust me, you will only waste your money trying to get by with the inferior belts. Riding mower belts and extra heavy duty and generally will not stretch at all. Generally they will have 5 or more strands of a Kevlar type material so that stretching is virtually non existent. If the belt will not tighten then it is most likely not the correct belt. If the belt is in fact the proper belt and still is too loose, then you should look for pulley wear or weak tension springs. Metal pulleys do wear and tension spring do loose tension.
Sep 12, 2009 | Mtd Garden
Does not walk good.....could the cable stretch or is the belt loose or housing needs adjusting?
Check the drive belt for tension first...most likely the belt has stretched out with use over time.
Jul 06, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
BOLEN RIDING LAWN MOWER 13AN683G163 TRANSMATIC DRIVE. REPLACED BELTS AND THE MOWER RUN IN 7TH SPEED AND SLIP WEHN I TRIED TO PLACE IN LOWER SPEED
Either the belt routing is incorrect or there is a tensioner which needs adjusting. Recheck your belt installation. Oh, it could be the wrong belt, too.
May 01, 2009 | Garden
Garden Logo
73 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
Are you an Ariens Garden Expert? Answer questions, earn points and help others
