Question about Samsung Washer & Gas Dryer Wf431abw & Dv431agw
Samsung dv431ag dryer preset sensors not working
My dryer works fine if I use the Time Cycle and manually set it. But this dryer has nice preset features like Sanitize, Towels, Normal, Bedding, etc. The dryer cuts off way too soon, many times within 5 minutes. I've had this dryer only over a year. I clean the lint every time I use it. There is no lint in the trap when this happens. And, the manual cycle works well.
SOURCE: I just bought the samsung SF448 steam washer.
why not do the special cycle and set it as "My Cycle". that way you can keep that one special setting under this cycle and use it every time you wish to use that particular setting
Posted on Apr 06, 2009
  • 181 Answers
SOURCE: pre wash cycle- do y need to use every wash, what does it do
no check out the manual. the pre-wash is more for stubben dirt then delicates
Posted on May 13, 2009
Sea Breeze
  • 4654 Answers
SOURCE: samsung WD-J1255C washer-dryer 5E Error
Samsung is a division of Maytag and they take pride in their respect of their customers. In a nice way I recommend you contact them. Not the people that serviced your washing machine. They may be the problem, not Samsung. I sponsor Samsung and Maytag and many other major companies. So please contact the information listed below and they will get you fixed and the people that are charging you for all these repairs. Thanks for understanding, Sea Breeze
If you need additional information or technical support, you can reach us by email at publications@maytag.com
Or you can FAX to 319/622-8158
Or you phone 888/547-8279 or 319/622-8646
Posted on Jul 05, 2009
  • 6277 Answers
SOURCE: Samsung Front Loader P801 5
First the 'E6'. The only Manufacturer's decode I have for Samsung 'E6' is 'water temperature rising/ falling too quickly, check thermistor'. I would go through the balancing act (detailed below) and then see if it recurs. If so it's a service call I'm afraid ;-0(
Now the dancing
Although you say it's level I would recommend you try my method to make absolutely certain before considering something inside ;-0)
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly!
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal suspension is malfunctioning.
Good luck,
John C
Posted on Apr 07, 2011
Chesc
  • 59 Answers
SOURCE: Samsung washer keeps reading ND. Have manually
The nd error code stands for No Drain.
Try following the steps here:
http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view_us.jsp?SITE_ID=1&PG_ID=4&PROD_SUB_ID=864&PROD_ID=866&AT_ID=149972
You will need to slide the unit forward to access the pump if there is no access panel on the lower front. If the clean out access panel is on the lower front bail the water from the washer and twist the filter head counter-clockwise. If the front panel does not have the access panel the washer will need to be slide forward. With the washer pulled out the back access panel can be removed. With the panel removed, the drain pump will be visible. Remove the two hoses on the pump followed by the two 7/16 bolts that mount the pump down. With the pump off, you can now remove the debris inside.
Put the washer back together and test for proper operation. If the error code comes back this means that the pump is clogged again or the pump has failed and would need to be replaced.
I hope this information helps you. A 4-thumbs up rating is greatly appreciated. :)
Posted on Jun 07, 2011
Kenmore elete model 110.67032600 timer changes to higher # and takes a long time to dry on auto dry.
I had this and it was lint trapped in door below lint filter screen.( several handfulls) Took door apart/ reassembled and he worked fine.
Oct 07, 2015 | Kenmore Dryers
Cycle selector knob clicks forward
PDF]Repair Manual - Splendide
www.splendide.com/service/TRAINMANM_Complete.pdf
WD802M (Splendide 2000). WDC1025M ... 6SOHQGLGH¥. Front Loading AutomaticWasher Dryer ... Description of Preset Wash Cycles / How to Set A Wash Cycle ONL: 21. Description of .... may appear to work well after repair is finished, but failure may occur at a ..... rear of the main top, then slide forward. Removing the ..
Sep 19, 2015 | Splendide 2000S Front Load Washer / Dryer
Samsung frontload gas dryer DV218AG moisture sensor doesn't work properly. Dryer adds minutes to drying cycle even when cloths are completely dry.
Clean the sensors with windex or like cleaner. Farbic soften can build up on the sensors and cause you trouble, Also, the time displayed is an estimate not actual drying time.
Jan 26, 2014 | Samsung Dryers
The beep that signals load is done sounds prematurely for about a minute ,the dryer continues until load is dry then shuts off
On this dryer each of the seven automatic cycles listed on your machine perform different functions based on fabrics, load size or variables. In essence the first four settings (Heavy Duty to Delicate) relate to your desired drying temperatures of high, medium, low or extra-low respectively. The moisture level of the load is determined by the dryer's sensor system and the machine will set the drying time to an optimal level.
Whirlpool added a WRINKLE FREE feature or what one might describe as an extended intermittent tumbling time. This added cycle helps reduce wrinkling when you may not be able to unload the dryer immediately after the end of the cycle when the buzzer goes off. Starting this setting is a simple one button operation at the control panel. TheWrinkle Shield™ Plus Feature is preset to on during the permanent press cycle.
Jan 30, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Maytag electric dryer (PYE2300AYW) does not stop on auto cycle.
Either the control board or the humidity sensor is bad.
Jan 11, 2010 | Dryers
16820 dryer not working
I suggest checking the moister sensor and or cycling thermostat. the hi limit thermostat as well, with a meter for continuity. other wise you may have a bad timer
Mar 20, 2017 | AEG Lavamat 16810 Front Load Washer/Dryer
DRYER RACK DOES NOT DRY CLOTHES
try timed dry cycle instead of the auto-sensing setting. In your drum if you have auto dry such as less dry normal dry and more dry, There is a sensor sometimes in the drum and sometimes in the exhaust right after the blower. If in the drum then your clothes brush by this and if moisture is sensed then it keeps on drying. With your rack the clothes can't touch the sensor so it tells your dial to turn and that items are dry which in fact are not. Try this and see how it does.
Feb 17, 2009 | Samsung 7.3 Cu. Ft. 9-Cycle Electric Dryer...
Samsung Electric Dryer
This may be a problem with your moisture sensor or the control that read the sensor. If it is under warranty have Samsung fix it for free. Make sure the cycle settings are correct before tinkering. First make sure the electronics are not too dusty. You could blow them off or vacuum them. Dirt particles can conduct electricity and make it read wrong. Next check the electrical connection for the moisture sensor. See if its location is in the manual. If it doesn't work after some tinkering asked the service for the dryer about possibly replacing the sensor but first try hard to get it to work.
Jun 13, 2008 | Samsung 7.3 Cu. Ft. 9-Cycle Electric Dryer...
Not heating
Check the exhaust vent and make sure it is completely cleared out.
Oct 20, 2007 | LG DLG5988 Gas Dryer
Samsung Washer & Gas Dryer Wf431abw & Dv431agw Logo
27 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
