Question about Dryers
Connections for electric Whirlpool dryer replacement thermostat do not match wires from dryer.
I already sent this in twice but cannot tell if either went through with your website setup. Brian Muldoon bmuldoon@howardcountymd.gov 410-313-43643
    Top Expert:
  • 12,223 Answers
Use the website www.applianceblog.com
for to find the diagram needed.
God bless you
Posted on Jul 22, 2013
I already sent this once but not certain it went throughSears Electric Whirlpool dryer LEB6000PO1 ( or P01) high thermostat.
If that is an OEM part you SHOULD NOT have to cut or change anything!! What is the model of the machine? What is the part number of the new and old parts. IF YOU CAN EDIT YOUR POST, remove the personal information
Jul 21, 2013 | Dryers
Dryer not drying in alloted time
there is a thermostat. it usually is located on the heating element housing
May 26, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Electric Dryer replaced element and thermostat / drying slow
Is your washer spin working. things may be going in to wet. Check and get back to us. thank you
May 19, 2010 | Whirlpool LEQ9858L Electric Dryer
How do i know i wired my thermostat right
If the thermostat only has two wires that connect to it then your ok...
Apr 20, 2010 | Whirlpool Dryers
My Whirlpool geq8811ll1 dryer turns on and spins but doesnt blow
you probably have one of the wires not connected correctly. or you could have bad themostat.
Sep 01, 2009 | Whirlpool GEQ8811L Electric Dryer
Dryer runs clothes not drying intermittent problem
Hello there
if you have already checked the timer and the wiring ect.ect this is looking like a heating element issue please visit www.whirlpool.com to view the online repair manual and parts list this should help you troubleshoot more if needed and it will give you telephone numbers you can call for support. ok?
best regards michael
Jul 31, 2009 | Whirlpool Dryers
Heat cycle stops/goes off
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
NO HEAT
Check for 220 volts incoming at the terminal block where your cord connects.
Make certain the dryer wiring is good there also.
Check the heating element to a ground on the dryer.
Check the continuity tthrough the start switch on the motor.
for the heater wire connection.
Mar 09, 2009 | Whirlpool LER4634J Electric Dryer
Changing heater element in kenmore dryer (110.60702990)
the orange wire is for the timer if you do not connect it then the cycles wont work.the timed cycle will but not the other cycles.
Nov 13, 2008 | Kenmore Dryers
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
