Question about Dryers
I already sent this once but not certain it went throughSears Electric Whirlpool dryer LEB6000PO1 ( or P01) high thermostat.
Trying to replace high thermostat and heating element. Replacement thermostat I purchased at Sears Service Center at White Oak (New Hampshire Ave at US 29/Columbia Rd/Colesville Rd) in Silver Spring Maryland did not have enough male prongs to connect to the two red wires and one orange wire (with a smaller female prong connection)from my dryer which had been connected to the original thermostat (which I disconnected from the original thermostat so I could take that part to Sears Service Center). However I did note that the replacement thermostat came with two alternate connections of female ends . Am I supposed to remove the female connection on one of the red wires from the dryer and attach one of these two alternate female connections so the orange wire can connect to it? The bronze alternate female connection that came with the replacement thermostat looks like it may have a male connection prong for the orange wire but: How to I connect this alternate female end to one of the two dryer red wires and which red wire from the dryer do I connect it to? I marked all the dryer wires when I disconnected them from the original thermostat. The highest red wire was marked "1", the orange wire was marked "2" and the lower red wire was marked "3". I assume it goes on one of the red wires but which one and how do I attach it? By the way I also gave my old heating element to Sears Service Center and they gave me a replacement whose connecting holes for screws did not match connection holes on dryer so rather than screw it I just duct taped it in place. Thank you Brian Muldoon (410)313-4363 bmuldoon@howardcountymd.gov bdoon51@gmail.com wife's cell: (240) 426-0260
  • Dryers Master
  • 16,026 Answers
If that is an OEM part you SHOULD NOT have to cut or change anything!! What is the model of the machine? What is the part number of the new and old parts. IF YOU CAN EDIT YOUR POST, remove the personal information
Posted on Jul 24, 2013
  • 1028 Answers
SOURCE: connecting 4-wire recectacle 14-30r dryer
doesn't matter both are 110v lines but if you want look up to top screw connections the wires coming to those screws are also colored as long as the red and black are to outside screws dryer will work ok
Posted on Aug 07, 2008
SOURCE: changing heater element in kenmore dryer (110.60702990)
the orange wire is for the timer if you do not connect it then the cycles wont work.the timed cycle will but not the other cycles.
Posted on Nov 13, 2008
SolutionGuy
  • 331 Answers
SOURCE: four prong plug to three prong plug
Kalola,
You can if you want to, but it's not generally necessary. Here's a picture of a 3 prong configuration with a ground strap...
That green wire with the yellow stripe is a ground and it is most definitely connected to the cabinet somewhere. So it will serve as the ground strap (in the above picture).
Here's the thing... say you were going from a 3 prong to a 4 prong. That is, the dryer was originally "designed" for a 3 prong. This means you'd have to "retrofit" it a bit. Take a look at this pic... ( I made this for someone else, so please disregard my somewhat hostile remarks, OK?)
The ground strap has been removed and has been replaced by the ground to the frame. Yours probably does NOT have a ground strap, though... yours uses that Green/Yellow wire for frame ground.
All of that to say this. Don't lose sleep over it. Ya done good.
SG
Posted on May 02, 2009
rickzilla
  • 706 Answers
SOURCE: Whirlpool Dryer - Model LHE 5700. My Dryer had
Hello David_Teresa,
Under the new Codes...all dryers (and stoves/ovens) must now be 4 wire....having a seperate neutral and ground wire in NEW construction. In decades past, the neutral was allowed to serve as both - the neutral and ground - typically by means of a solid metal strap or wire strap that bonded that connection to the metal frame of the dryer. This sounds as if it is the case in your existing dryer...which was typical.
But...the old arrangement wasn't always reliable...and a seperate dedicated ground provides a greater safety path in the event of a fault inside the dryer (lowering the chance the user may get a shock when touching the frame of the dryer).
To modify your existing 3 prong dryer over to 4....you'll need to remove the 3 wire - disconnect the ground strap (or wire) that bonds the neutral to the frame of the dryer...and install your 4 wire so that you'll have (from left to right) one hot, one neutral, one hot connection...and connect the ground directly to he frame of the dryer (there is usually a green screw near the dryer connection block for this ground)
For more on this - with an illustration, see:
http://www.american-appliance.com/service_pages/electric_dryer_cord.htm
When done properly, you can test for correct wiring and connection with an ohm-meter (continuity check)...by checking for continuity from the ground prong on the plug to the frame of the dryer...you should see continuity. Then check for continuity from the neutral prong on the plug to the frame...you should NOT see continuity....nor should you see any continuity between the neutral connection at the wiring block to the metal frame.
The whole purpose of the Code change to the 4 wire is to seperate the neutral from ground to provide additional safety for the user.
Hope this helps,....
Posted on Nov 29, 2009
SOURCE: Change 3 prong dryer cord to 4 prong
I have a Maytage Gas Dryer Model SDG515DAWW that Starts up fine but once it heats up ahd the gas shuts off the first time it will not come back on. The blower keeps running but no heat
Posted on Dec 14, 2009
I have a Whirlpool electric dryer M/ WEP5300o that will not heat. I have replaced the Cycling Thermostat, High limit thermostat, Thermal fuse and heating element. It still doesn't heat. There are
If you have fuses on your electric panel it normally uses 2 fuses, 1 for electric power 1 for heat. The same may be true on the circuit board panel check this to eliminate this possibility
Feb 02, 2013 | Whirlpool Dryers
I have a Kenmore electric (front load) dryer, model number 84092500 that would spin but does not produce any heat. I tried cleaning/vacuumin the tubing that vents to the outside and resetting the circuit...
The first step of the fix has been done by cleaning the lint filter and the vent system.The next step is replacing the thermal cut-off and the high-limit thermostat both located on the blower housing. It is common that the dryer stops heating when the thermal cut-off blows open due to the failure of the high-limit thermostat to cycle off and regulate the heater temperature. The thermal cut-off cuts power to the heating element should the high-limit thermostat fails and the dryer temperature goes extremely high as a safety feature. Click on the links below for the troubleshooting and repair details.
Whirlpool and Whirlpool-made Electric Dryers (With Removable Back Panel) Not Heating
Whirlpool and Whirlpool-made Electric Dryers (Without Removable Back Panel) Not Heating
Jun 19, 2011 | Kenmore Dryers
My electric whirlpool dryer IS heating but not drying clothes. Takes a couple of cycles. I have replaced the cycling thermostat after multimeter registered it bad, the thermal fuse and timer assembly are...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Apr 20, 2011 | Whirlpool WED5200T Electric Dryer
My whirlpool leb 6000 pqo will not heat
check heating coils, high limit, temp selector switch.
Apr 05, 2011 | Whirlpool Dryers
Kenmore dryer blows cold air. I replaced heat element still no luck? model 96263800
It doesn't necessarily mean the heating element is busted when an electric dryer stops heating. The heating circuit is not just composed solely by the heating element, it is composed by the thermal cut-off, high-limit thermostat, cycling thermostat, motor centrifugal switch, and the timer. The first thing to look at when an electric dryer stops heating is the thermal cut-off. It cuts power to the heating element when it blows most likely due to the failure of the high-limit thermostat. The thermal cut-off must be replaced, together with the high-limit thermostat, if found open. Click on the link below for the detailed instructions in troubleshooting this problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers (Filter on Top and with Removable Back Panel) Running But Not Heating
Mar 25, 2011 | Kenmore Dryers
Dryer wont heat
The problem is likely the thermal cut-off and/or the high-limit thermostat if the dryer runs but doesn't heat. Verify this by bypassing the thermal cut-off and the high-limit thermostat. Click on the link below for the detailed troubleshooting.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers Running But Not Heating
Feb 18, 2011 | Whirlpool GEW9200L Electric Dryer
Electric Dryer replaced element and thermostat / drying slow
Is your washer spin working. things may be going in to wet. Check and get back to us. thank you
May 19, 2010 | Whirlpool LEQ9858L Electric Dryer
Replaced high temp sensor on whirlpool front loader
The high limit thermostat should have been replaced also.
If there are no obstructions that will fix your problem.
Mar 13, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool LP Gas Drier LGR4634JQ1
Try a new set of coils located on the gas valve.
Jul 13, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
44 people viewed this question
Top Dryers Experts
