Zeepad 7.0 tablet question
Hi Ive had the zeepad 7.0 android tablet for around a month and a half now, At first I had no issues with the tablet. Yesterday it started acting up and not wanting to charge at all, even on the charger. Ive tried a couple different chargers on it and none of them did any better. Even when the charger is plugged in it stays at 0%. Sometimes the battery says 2 or 3% then suddenly it will say 100% but only for a few seconds before it goes back to 2%. I was hoping maybe you had some advice for me if I need to send it back to amazon (I ordered it from amazon.com by the way) Would they send me a replacement or would I just be out of luck? Thanks in advance for any help. I just didn't know what else to do.
  • 24 Answers
SOURCE: medion 2310 laptop switches off as soon as charger is plugged in
1. It can be a screw loose inside the unit shorting something out.
2. The AC Port is damaged and needs to be re soldered.
3. Bad motherboard.
I've seen this be a bad motherboard more than not, however it has been the other 2 options from time to time. Most likely need to take it apart and you can see if it's the first 2 and if not than your board is bad.
Posted on Nov 10, 2008
  • 2567 Answers
SOURCE: Acer Aspire 5738Z won't hold charge
Sorry. It seems that your battery is dead.
If your laptop is working fine on AC power only (with the battery disconnected), then your battery will need to be replaced.
Posted on Jun 16, 2010
  • 2567 Answers
SOURCE: Was using my Hp Pavilion dv7 laptop, suddenly
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Posted on Oct 10, 2010
SOURCE: when my acer aspire 5734z
It is a sign that your battery is failing. Try to remove the battery then put it back. After that, try to check if you still experience the same thing. If so, then you need a new battery replacement.
Batteries usually start to degrade after a year or after 500 charges, whichever comes first.
Posted on Feb 11, 2011
SOURCE: hp pavillion dv4 charging indicator
Dear alfred I have found lots of problems like yours over the web.
Your problem is one of many that the best solution to them might be to buy a diffrent kind of laptop with a diffrent charger.
I have seen a lot problems where pepole had to buy a new charger (10$ at amazon) or a new battery (70$ or more) so you should consider replacing becuase it may be cheaper.
There are lots possibilities who might cause this problem,here are two:
1) Your laptop battery has stopped taking a charge, because of a chemical breakdown of the electrodes from the electrolyte. With any battery (to date) you can only reverse the chemical reaction, needed to generate current flow, a limited number of times before the internal components of the battery break down. So it may just be that your battery is no longer able to charge in the first place.
2) A common occurrence with barrel type connections is that they tend to become loose over time due to the cable being jostled around as it's resting in the connected state. If metal to metal contact is not occurring on either the outer barrel or inner pin of the connection, the electromagnetic polarity required to move the electrons (i.e. current flow) will be nonexistent, causing the device to not charge the battery or supply electricity to the internal circuitry. In this case you could find any electronics technician to simply replace the power connector for you, considering they have simple soldering knowledge and you can find a power connector to replace it with through your laptops motherboard manufacturer.
There are lots of possibilities for your problem,I also advise you to try another charger to check if the problem is at the laptop or the charger.
Posted on Jun 13, 2011
Tablet turns on shows zeepad then android and wont turn on
someone told me that when that happens that I must have blown one of my cores
Jul 09, 2014 | ZEEPAD 7 inch Android 2.2 Tablet
NEED OWNERS MANUAL FOR A ZEEPAD 7.0 TABLET
http://www.manualsdrive.com/results.php#.U7ebO_mFV8E
Jul 04, 2014 | ZEEPAD New 7 Inch Android 2.2 Tablet Pc...
How do i connect my zeepad to my pc?
That is a known issue across android smartphones and tablets. It is a certificate conflict or issue, the only way that would be a work-around is a factory reset. After which you will have to re-download the apps you installed and customise any settings.
Jun 25, 2014 | ZEEPAD 7" 7.0 Allwinnwer A13 Boxchip...
IS THERE A MANUAL FOR A ZEEPAD 7 TABLET
Go to Settings -> Storage -> Factory Data Reset.
If that is not an option, then:
1. Power of the device completely.
2. Hold down both volumes and power at the same time. This should bring up an image of an android on its back, opened up.
3. Press both volumes at same time to open up a small blue text menu.
4. Then use Vol - and Vol + to navigate the Recovery mode.
5. Select "Factory Data Reset", press power, choose "yes" from the menu then press power again.
6. Your zeepad should now be reset
May 25, 2014 | ZEEPAD 7 inch Android 2.2 Tablet
How can I reboot my Zeepad?
Here are the some simple steps to hard reset your ZeePad 7.0:- 1.)First of all,Go to Settings -> Storage -> Factory Data Reset. 2.)Otherwise,Power of the device completely. 3.) Now,Hold down both volumes and power button simultaneously. 4.)After doing this,you should get an android on its back opened up or something. 5.)Now,Press both volumes at same time to open up a small blue text menu. 6.)Then use Vol - and Vol + to navigate the Recovery mode. 7.)Select "Factory Data Reset", press power, choose "yes" from the menu then press power again.
May 16, 2014 | ZEEPAD 7 inch Android 2.2 Tablet
Forot the password to my zeepad 7.0 tablet, how do i reset it?
lost password and hard reset require firmware reinstall. Instructions can be found at www.zeepad.net
Feb 09, 2013 | ZEEPAD New 7 Inch Android 2.2 Tablet Pc...
How to reset a zeepad 7.0 andriod tablet when screen stuck on zeepad 7.0
To reset zeepad if password is lost or tp fix other issues the firmware must be installed. For instructions for doing this go to
www.zeepad.net
Dec 26, 2012 | ZEEPAD New 7 Inch Android 2.2 Via8650 Epad...
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
