Question about Samsung HCL4715W 47" Rear Projection Television
Internal Screen Adjustments No Response
My Samsung HCL4715w rear projection had a convergence problem. I replace the SUB PCB. Convergence problem fixed. However, Red CRT is very dim. I tried the screen adjustments directly on the CRT, but no response. Same for Blue and Green (think they work in series). Any cheap fixes or ideas? Definitely not putting a new Red CRT on - set is not worth it. But I would love to tinker and get this set fixed, just for the satisfaction of completion. I am not electric technical, but if I can do surgery on humans, I should be able to do surgery on a television.
  • 1 more comment
  • Mark Koonce Sep 06, 2007
    screen controls wires, directly go to the Red CRT, then jumps to green, then blue.
    Focus controls go directly to the focus block.
    Focus controls work, but the controls on the CRT have no response, and red CRT is dim.
    Someone mentioned the 220V line?
    You are correct in regrds to the focus controls.
    But the screen control wire goes directly to the Red CRT, then is in series with Green and Blue.
    Red CRT is dim (Blue and Green are fine). The screen controls on all three have no response.
    The Focus block has three dials for Focus, and you can clearly see the wires going to the block.
    Then the Screen controls on the Focus block are "dummy switches", no wires going into the back of the Focus block.
    You can clearly see the Screen Controls wire going from the Sub PCB directly to the Red CRT, then it goes over to the Green CRT, and then the Blue CRT.
    Sergeant:
    Champion:
  • 375 Answers
Thr focus block assy.has the screen and focus controls on it it about 3"x3" in size has red wires attached to it and one feeding form the flyback transformer to it.
Posted on Sep 06, 2007
  • g w Sep 06, 2007
    you can check on each neck board for the b+ voltage and screen voltage if there the problem is common to all three because you should be able to adjust either one at any time ,not affecting the other if the fault is not common to all,when you tried to adjust the focus did you see 6 adjustment pots on the focus block.
I have a Samsung Rear Projection TV with a red convergence problem. Will replacing the deflection board fix this problem?
No you have 2 convergence ICs replace them if you havent and look for burt resistors near ICs 2.7ohms most of the time 2 of them need to be replaced They are Big Black ICs will have part# on them STK392-020s order parts from Mats 1-800-628-1118
Sep 16, 2009 | Samsung HCL4715W 47" Rear Projection...
All screen is red
IF THE SCREEN IS ALL RED WITH VIDEO VISIBLE AND RETRACE LINES. ADJUST SCREEN CONTROL IN THE FRONT FOR THE RED TUBE ONLY. TURN CONTROL COUNTER CLOCKWISE. IF THAT DOESNT DO IT THE TUBE CAN BE REJUVINATED.
Nov 19, 2008 | Samsung HCL4715W 47" Rear Projection...
Replacing Convergence ICs
As long as you can solder you should be okay, however i would suggest getting your ICs at the following link because they provide free instalation instructions with pictures on how to remove and replace the Convergence ICs. heres the link.
http://servicemanuals.vstore.ca/
Apr 26, 2008 | Samsung HCL4715W 47" Rear Projection...
How to remove back of Samsung HCL4715W 47 in rear projection TV
the screws are identified by little arrows pointing to the screw holes. However I would be surprised if its the convergence board most times its the Convergence ICs located on the sub board
Apr 22, 2008 | Samsung HCL4715W 47" Rear Projection...
Convergence board for Samsung HCL4715w
The Convergence ICs will need to be replaced , 95% of the time thats the problem they are on the sub board not the convergence board. You will need two STK392-040 ICs . you can get replacements at the following link and they will provide free installation instructions along with free on-line tech support when you install them. takes about 45 minutes. Heres the link.
Apr 19, 2008 | Samsung HCL4715W 47" Rear Projection...
Flashing red lines on Samsung hcl4715w rear projection
The convergence board wont correct the problem. You need to replace the two Convergence ICs on the sub board STK392-040 and you will be back to normal. See my response above. That site will help you get it back to normal.
Dec 21, 2007 | Samsung HCL4715W 47" Rear Projection...
Red CRT is dim....
Yes I did. You will need to get a service manual for this TV set to trace the voltage coming from the sweep power supply. If this is a problem that is new after you replaced the convergenbce4 board, you for sure have a broken wire or connection somewhere in the set. Have seen this happen may many times after a novice repairs a TV set. Good Luck
Sep 06, 2007 | Samsung HCL4715W 47" Rear Projection...
HCL4715W Rear projection CRT problem
your screen and focus controls need adjustment to acheive a good grey scale picture the adjustment are not on the crt neck boards.(focus block)
Aug 29, 2007 | Samsung HCL4715W 47" Rear Projection...
HCL4715W Rear projection "Red" color is dim
screen adjustment,remove front bottom cove and find the focus block the screens are also on the same block,if your not sure don't try.
Aug 28, 2007 | Samsung HCL4715W 47" Rear Projection...
New PCB SUB - But blurry and color off.
have you tried to also adjust the lenses to fine tune the focus .
Samsung HCL4715W 47" Rear Projection Television Logo
88 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
