Question about Akrapovic Valve system Harley-Davidson Touring FLHR Road King 2006-2013 Exhaust
Changed handle bars and the check engine light won't go off
2011 suzuki motorcycle s40
Hi, Isaac and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Tip over sensor needs a reset.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Starter control circuit, relay, or solenoid faulty.
10. Main fuse or circuit breaker may be blown or faulty.
11. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
2009 Suzuki Blvd S40 won start
S40 won start new battery no power anywhere after kid drained battery
Bike won start Doesn click Lights work
Suzuki LS650 Savage Boulevard S40 Motorcycle Online Manual Cyclepedia
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Aug 29, 2016 | Suzuki Motorcycles
Brake light stays on when engine is off on a 1999 Victory
check your brake light switch on the handle bars. it maybe bad or just out of adjustment
Mar 22, 2014 | 2002 Victory V 92 C
How to wire your 2007 FLHTC after you change your handle bars to Ape Hangers
Hi Anonymous, you might have pinched some wires re-installing the handle bar controls and switch housings. Check your fuses also. Good luck
Feb 04, 2014 | Harley Davidson FLHTC - FLHTCI Electra...
The handle bars won't go back in on my bike
Line the bottom thing up to make it flush and then insert it then tighten up the Allen key on the top
Apr 06, 2013 | Cycling
I changed the oil in my 98 concorde and now it wont start. The oil light is on but not the check engine light.\
do you here the fuel pump working when you turn the key?If not could be a fuse that runs the fuel pump.
Aug 05, 2012 | 1998 Chrysler Concorde
Outside door handle won't open door
replace bar linking inside with outside handle undo handle remove square bar inspect both parts replace which ever is worn or broke
Apr 06, 2012 | 1990 Jaguar XJ6
Changed relay switch for radiator fans now check engine light won
So youre saying the fans are coming on and going off like they should, have you changed your thermostat and be sure to burp the system getting out all the air bubbles. And the check engine light will not always go out on its own, most times manually clearing it or disconnecting the battery is the only to go if you dont have a generic scan tool
Jul 27, 2010 | 1998 Dodge Grand Caravan
Engine revs when turning right.
Wrong size throttle cable or misadjustment. At the handlebars, I've seen some set that acceleration causes a pull of the cable, I've also seen bikes set to push the cable. Confirm this is set correctly, and that your mechanic used the correct legnth of cable.
Jul 30, 2009 | Yamaha XJ 650 Motorcycles
Akrapovic Valve system Harley-Davidson Touring FLHR Road King 2006-2013 Exhaust Logo
73 people viewed this question
Top Akrapovic Sport & Outdoor - Others Experts
Bill Eager
Are you an Akrapovic Sport and Outdoor - Other Expert? Answer questions, earn points and help others
