Question about Gateway Computers & Internet
Read sd card
The G:/ is not available in my computer. It will read the sd card but only in photo frame not to save to the computer.
  • Gateway Master
  • 17,328 Answers
What computer system and what operating system?
Posted on Jul 23, 2013
5 Suggested Answers
hulk god
  • 36 Answers
SOURCE: photos from pc to sd
The easiest way to do this would be to buy a card reader for you PC. You can buy an external one that plugs into the USB port.
Another way is to used a computer with a SD reader and upload it into a flash drive. Once you have the flash drive, you can upload the pictures using your flash drive into the frame.
Posted on Aug 08, 2008
  • 3 Answers
SOURCE: how can i copy photos
The easiest way is to purchase an SD memory card reader. You plug it into your usb port and it will show up on your computer as a removable hard drive. You can just drag your photos to the memory card. Prices range from about $10 and up.
Posted on Aug 09, 2008
leecom72
  • 4806 Answers
SOURCE: Sony Vaio desktop with service pack3 not reading a 4GB SDHC card
does the card work in any other device?
Posted on Nov 14, 2008
haayz
  • 197 Answers
SOURCE: when I put sd card in memory slot on hp 6280 all in one printer it sees the pics on the card but will not allow me to save them to computer. tells me not set up you need to install device software, wh
You need to save it manually. Locate on your My Computer where your SD card shows off, open the folder then copy watever files you want to copy from you SD memory card to your computer.
Hope this would help your problem :)
Posted on May 28, 2009
Pandigital Photo Frame will not read MMC card
The new card is not compatible with your photo frame. Only thing you can do is to make sure that what you use is compatible. Your manual or website will tell you the largest memory card you can use.
Aug 27, 2016 | PANDIGITAL 7" Digital Photo Frame With...
Once rotated photos on my computer to put on sd card the frame rotates them back
When loading pictures from PC to SD card you need to rotate and save at that stage!
Jan 02, 2016 | Photography
Why is the photo frame not reading my sd card
Try a different card, with less than 4gb capacity. If the problem persists, it's the frame. If the problem disappears, it's the card.
Some devices have a capacity limit. 4 GB is one such limit. Trying a 32 GB card in a frame only designed for 4 GB is sure to give trouble.
If so, either get a newer frame, or use your computer to transfer photos to a smaller card.
Mar 17, 2015 | Photography
How to put photos onto SD cards
In Windows, click on Start/Computer. A window opens showing all the drives connected to the computer. Under "removable drives" locate the SD card. Hover your mouse pointer over the SD card icon and it should tell you how much free space is on the card. If necessary, delete some photos or other data to make more space available so you can add the photos you want. If there's already plenty of space, try formatting the SD card in either ex-FAT or NTFS format. Then try copying the photos again. If the SD card does NOT in appear in removeable drives then the SD card may be faulty. Try a different SD card.
Nov 04, 2014 | Philips 6.5-Inch Digital Photo Frame...
How do I recover pictures back to my power shot sd card
If your computer has a built in card reader you can put any photo back on the card from your computer by dragging and dropping the file to the drive letter that is your SD card. If you're trying to recover lost photos from a SD card Google "card recovery pro". It's a free program that will read your SD card and restore as many photo's as it can.
Sep 23, 2014 | Canon Powershot Power Shot A70 A 70 3.2 Mp...
Bought digital photo frame a700 as a present for 90year old. have photos of great grandchild on 2 different sd cards. can i put them on one card for the photo frame
Yes. Connect one of the sd cards to a computer and drag the photo onto your desktop. Now connect the second card and drag the photo onto the second sd card so that both photos are on the same card. If you have a mac, the sd cards will appear on your desktop. If you are using windows, I believe it shows up under your start menu and then my computer (though to be honest, I haven't used a computer with Windows in a while).
Sep 17, 2011 | Mustek PF-A700B Digital Picture Frame
My dpf-0802 digital frame will not read my sdhc card and it is unolcked and all photos show on my computer.
Some frames are not able to use an SDHC card. You might double check the requirements from the manufacturer... or even easier, try a card that is just a plain-jane sd card.
Hope this helps!
Feb 23, 2011 | Westinghouse DPF-0802 Digital Picture...
I have a digital photo frame Coby DP-5588. I bought a sd card Kington 4GB when I insert the card in the photo frame appears a message "wrong Card" and it doesn't read the card content. What can I...
Your 4GB card is actually an SDHC card, not an SD card. While SDHC cards will fit into SD slots, they are electronically incompatible and will not work. You need to use an SD (or MMC or xD or MS), 2GB and smaller.
Dec 05, 2010 | Coby DP-5588 5.6-Inch (4:3) Clock &...
Card read error on the digital picture frame - brand new. I bought this 7" digital photo frame from argos and I insert the SD card whilst the device is turned off, when I turn it on the message reads...
Put the card back into the camera and off load/take off your pictures (Put them on the computer). Then, put the card back into the camera and go to your options menu. Find the format feature, and format the card. Take some new pictures and then try putting the card back into the picture frame. Does it work? If so, transfer the images from your computer back to the card. If it continues to work, then Great! If not, more than likely there is an improper or corrupt file among your photos.
Good Luck!
Dec 12, 2008 | PANDIGITAL 7" Digital Photo Frame With...
7" Trutech digital photo frame
I don't have the booklet for this darn thing and I just got it for mothers day.... I have a sandisk in it and I can see the pics just fine, but it doesn't save them??? I can only view when I have something in it??? That's crazy?? Isn't it?? Help
Dec 29, 2007 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
