Question about Kitchen Ranges
Jenn air gas range slow to preheat - Kitchen Ranges
VANMAN69
  • 23 Answers
SOURCE: F1-1 error on Jenn-Air Range
if it is the stove that is in the picture the fault codes are in the door under the oven door.
Posted on Jun 02, 2007
jsrock516
  • 5911 Answers
SOURCE: jenn air jgr8850adw won't bake
This usually is an indication of a bad igniter. If this is the standard glow type igniter, it could appear as if it is working, but may not be providing enough current to open the gas valve. This is a safety feature on gas ovens. The gas valve requires a current potential of .32 to .37 amps through the igniter before it will open and allow gas to flow. This prevents gas leakage if the igniter fails to light. The reason your broiler works is probably due to the fact that the broiler gets used less and the igniter is probably in better condition. You can test this theory, if you like, by swapping the igniter for the bake and broil burners to see if the symptoms change. Or, you can simply just replace the bake igniter with a new one. Make sure you secure the power before attempting, though. You shouldn't have to turn off the gas for this. Chances are that's all it is. I hope this helps you.
Posted on Jul 14, 2007
SOURCE: jenn air gas range ignitors won't light
My jennair gas range ignitors will not light. Any suggestions?
Posted on May 07, 2009
erpaalai
  • 999 Answers
SOURCE: jenn-air electric range model JES9800AAB some kypad # not working
Unless they start working again after it has a chance to dry out the touch panel will have to be replaced. This happens when excess moisture gets between the very thin layers of the membrane.
eric
Posted on Jul 03, 2009
SOURCE: How to replace spark igniter - Jenn-Air SEG196 gas-electric range
took off the knob to the ignition system to clean and spray got onto the ignition under the dial and now the two front burners won't ignite unless I turn on one of the functional back burners then turn on the front burner. How do I repair this?
Posted on Oct 11, 2009
When preheating oven it will not maintain the designated heat
You need to replace the temperature sensor. Here is a link to that part to order. There is also a video on that page to show you how to make the repair.
Aug 30, 2013 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Gas oven is slow to ignite & preheat
What kind of range? Taking that long to ignite and small flame. Sounds like both weak ignitor and safety valve is not opening.
Jan 14, 2013 | Kitchen Ranges
It takes over an hour to preheat my gas stove
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 27, 2011 | Jenn-Air JGR8850 Gas Kitchen Range
Hi ,I have model jgs8850ads,it takes along time to preheat,about 40 min. what could this be? please respond.
is this a duel fuel with an electric oven..... the bake is the bottom and the broil is the top both cycle on and off to preheat the oven.... if ur lower bake element is burnt out then u woould expereicnce the problem u stated..... if u have a gas oven then ur ignitor or glow bar is probably burnt out....... either way it sounds like your bake element or bake ignitor has failed
Jan 31, 2010 | Jenn-Air JGS8850ADS Gas Kitchen Range
It is slow to heat up
The oven ignitor is slowly going out...it needs to be replaced!
Oct 25, 2009 | Jenn-Air JGR8855BDS Gas Kitchen Range
My Jenn Air JGS8850 takes over 10 minutes to preheat to, say, 400*. Is this normal?
In a word...Yes !
10 min. is actually a really great preheat time. I have many customers who would kill for that kind of preheat, most are between 15-20 minutes minimum to 350 degrees celcius, especially with the introduction of hidden bake elements in the last 10-15 years.
Hope that is helpful,
Good Luck :)
Oct 22, 2009 | Jenn-Air JGS8850 Gas Kitchen Range
Jenn air jgr8850adw won't bake
Jun 12, 2007 | Jenn-Air JGR8850 Gas Kitchen Range
Kitchen Ranges Logo
27 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
