Question about Sharp Audio Players & Recorders
How to record
I have the remote but I can't find how to record to tape 2
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sharp Master
  • 102,366 Answers
What model Sharp stereo?
Posted on Jul 22, 2013
First. Don't have the remote. On a magnavox dv220mw9 model. Plays regular. VHS tapes ok it won't play a recorded tape on our 32 inch Curtis flat screen tv. Where can I get a remote for this. Also wi
You can get a general purpose "universal remote" and program it but difficult and tough to get all of the functions to work. I would recommend stepping up the price paid for a remote to around 100 - 120 dollars. The one I recommend is the URC remote. This one can be programmed with multiple components to a single button. There are many out there other than URC but it is one the I use and have found to be very reliable.
Jan 31, 2013 | Televison & Video
Video on my Sony VCR (SLV-780HF) goes gray after playing a tape a few seconds. What could be the problem?
The only real cure will be to clean the video head. If that doesn't work then I'm afraid that whatever recorded you EP mode tape was not set up well tracking wise. So other machines struggle to track the tape. Some VCR's will only playback SP or LP tapes and don't have EP mode. In which case you should check to see if these VCR's can play the EP tape and if they can't find one that can.
Dec 06, 2012 | Sony Televison & Video
I have an Aiwa Surround Sound Theatre system Model #cx-nmt720. Has a 3 disc player, am/fm, and 2 cassette decks (one on right allows recording/dubbing) Everything works great except cassette...
The unit may be damaged or may just need adjustment- only a tape deck technician will be able to answer the question after seeing the unit. To answer it remotely like this, is really an impossible task.
Nov 03, 2012 | Audio Players & Recorders
Want to record VHS to DVD on my Toshiba DVR620KU but do not want to connect to my TV set. Is this possible? My TV is older and does not have the input/output jacks. I just want to put in a VHS tape and a...
If the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit
2) Insert VHS tape
3) Insert DVD-+R or DVD-+ RW
4) Using remote, press VCR
5)Using remote, press play then pause the tape where you want to start recording.
6)Using remote, press DVD
7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
When using this method, don't hit the RECORD button!
I hope this helps!
Sep 05, 2011 | Toshiba DVR620 DVD Recorder/VCR
I have a Fisher RS636 receiver. I can't seem to record from "Tape 2 to Tape 1" or from 1 to 2. I don't have a remote. Will this be a problem? Can you guide me through procedure. Do...
Most receivers have a dub switch and it would still be in one direction only, say Tape 1- >> Tape 2. Lacking a dub switch the Tape Loops are in an order like that so monitoring the one upstream of the other allows the second one to see it as a source.
Aug 22, 2011 | Audio Players & Recorders
Need the manuel original lost or misplaced and can not find. want to record cassettes to cd's
Insert a blank CD-R or CD-RW into the unit. Press the Function button on the remote (key above Vol+ on the bottom right of the remote) or the turntable itself (top left of the control panel) until the unit is in Phono mode. Then insert the pre-recorded cassette and press Play to advance the tape to where you wish to start recording. With the cassette playing, press the CD Record button (recording will flash on the display). The CD Record button is to the left of the fast reverse button on the unit; it is labeled Record on the remote and is below the Stop button. When one side of the cassette finishes playing, press Stop. Wait for the display to return to Phono. Then eject and turn over the cassette to play side 2 (if you want to record both sides of the tape). Press Play again to advance the tape and then press Record. When this side finishes, press Stop and then Finalize. Finalize is at the bottom left of the remote buttons and to the left of the stand by indicator on the turntable.
The manual is available at Crosley: http://www.crosleyradio.com/Product.aspx?pid=1790 . The direct link to the manual is http://www.crosleyradio.com/Manuals/CR248_Manual.pdf . Recording a cassette to CD is on page 11 (page 12 of the pdf).
I hope this helps.
Jun 10, 2011 | Crosley CR248 Turntable
Can I change record speed without a remote from sp to ep? Mod#NO VWM 400 I need to record longer than the tape last on sp
can't find any documentation, but the compatible remotes are available on eBay...
Search "sanyo remote vwm" andcheck the 'include description' box.
May 11, 2011 | Audio Players & Recorders
VCR won't record.
When you press record, does the tape eject? if it does, make sure the safety tab is intact. if not, put a piece of scotch tape over the hole. Do you hit the record button on the vcr or a universal remote? On a remote, you may have to hit recort 2 times.
Jun 19, 2010 | Sharp VC-A582U VCR
How do I change the vcr to 'SLP' - it seems to be stuck on 'SP'. (There is no "speed" button on my remote.)
Use the remote to get into the setup menus. There may be an option to change tape speed when recording. Alternatively, when you press record on the remote (or deck), you may have option to change the tape speed there.
The VCR part of your deck may be able to playback, but not record in SLP mode.
Searched around for the manual for your machine, and though there are references to it, it appears that a manual / information page doesn't exist for the model # that you listed.
Jun 11, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Toshiba M674 Lost Remote can't change tape speed
Is this an older VCR? If you can set the timer on the VCR itself
like on an older model you can set the timer and set it to record
in another speed. But if you can't do this. You are stuck at
recording in sp. If you can set the timer, if you make just
one mistake it may not come on at all. That's why vcrs
are not as reliable as dvrs. if you don't want to miss a show
diffinatly make sure you re at home and see it come on
like fill up the whole tape and put the show on the end of the tape. like a 2 hour movie comes on a 8pm-10pm set the
timer at ep speed to come on at 4:05pm- 10:05pm and put a 2 hour tape in it. in ep it will record for 6 hours. tape will stop
automatically so you will record it, and it will be on the tape
at the end. that's the way i do it. if I'm not going to be at home
if i really don't want to miss a show at all. because when you set the timer it still might not come on if you see it on you know
its going to record it.
note its cheaper to just buy a new vcr than buying a $72 remote.
you might as well do that if it is a newer model.
I bought an older model vcr in a thrift store for $10 and it worked good for a year for recording shows. I got lucky I guess.
it didn't have a remote I use the timer to set the ep speed
to record.
Nov 22, 2006 | Toshiba M674 VHS VCR
14 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
