Question about Mtd LAWN MOWER PART # 753-0698 KIT-DECK 42" NEW S
Won't shift into gear
Can shift into gear but transmission does not catch.
  • 31 Answers
Is the pully turnning the shaft or is it just spinning on it could be the pin sheared, if not you can remove the rearend and take it apart pretty easy to find a new one or order the part not much to them really pretty simple bout ten bolts split it apart and have a look maybe just dry of grease and froze up
Posted on Jan 27, 2014
When trans shift from 3rd gear to 4th gear it act like it shifts into neautral and slips
You need a transmission rebuild. Whether this is an automatic or manual you need the transmission rebuilt.
Jan 24, 2016 | 2005 Chevrolet Chevrolet TrailBlazer EXT...
2007 Yamaha Stratoliner 12.5k miles. Downshifting from 2nd to 1st shift lever does not always catch first gear. Problem is intermittent.
Hi, Anonymous and the usual suspects are:
1. Clutch dragging slightly.
2. Primary chaincase overfilled with lubricant.
3. Corners wore off shifter clutch dogs.
4. Shifter return spring bent or broken.
5. Bent shifter rod.
6. A loose shift lever on shifter shaft.
7. Shifter forks sprung.
8. Shifter pawl needs adjusting.
9. Heel/toe shifter coming in contact with the floorboard.
10. Transmission oil too heavy.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.starbikeforums.com/forums/15-stratoliner-roadliner/3901-transmission-issues-shifting-into-1st-gear.html
bike won go into 1st gear
http://atelierstarsclub.free.fr/pdf/roadliner-stratoliner-service-manual.pdf
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/2007/LIT-11626-20-41_stratoliner_all_1554.pdf
Oct 10, 2013 | 2007 Yamaha Stratoliner
3rd gear in transmission wont catch
Dose the eng rev up when it shifts
Mar 06, 2013 | 1989 Chevrolet C1500
My blazer won't shift into any gears, only park. When I try to go into R or D or any gear, it shifter just goes up and down, like it's not catching. What could the problem be?
If the shifter feels loose, then the linkage may have come disconnected at the transmission. If you look under the vehicle, you should be able to see where is hooks up on the left side of the transmission.
Feb 08, 2013 | 2000 Chevrolet Blazer
My 99 z24 cavalier standerd shift it will not shift into 3rd gear
The gear may be stripped, can't catch other gear,have you been grinding this gear,will have to go into transmission and replace third gear, will have to wind second gear out and shift to 4th gear.May be better and cheaper to get a remanufactured transmission cause all parts are new versus just 3rd gear being replaced.
Dec 24, 2012 | 1999 Chevrolet Cavalier
F250 1998 light duty won't shift out of park
For car not changing gears and not shifting out of park mode ,it can be shifter assembly issue, or it can also be transmission issue. Get the shifter assembly inspected with ignition OFF.
For more troubleshooting, I suggest you to get the Following help link checked, its complete step by step procedure to inspect gear shift issues: -----
GEAR SHIFT ISSUES
http://alltypesofpartsreplacing.blogspot.com/2012/11/gear-shift-issues.html
NO REVERSE ON TRANSMISSION
http://alltypesofpartsreplacing.blogspot.com/2012/12/no-reverse-on-transmission.html
Transmission fluid leak, transmission gears slip,
http://alltypesofpartsreplacing.blogspot.com/2012/12/transmission-fluid-leak-transmission.html
These will help.
Thanks.
Dec 06, 2012 | 1998 Ford F250 SuperCab
My 03 mustang won't down shift after shifting the
HI,
Search online..but it sounds like the 'synchros' in the transmission are going/gone.
Also, the clutch may be wearing out.
Td
Oct 01, 2012 | Cars & Trucks
Automatic transmission won't catch any gear?
Check trans fluid levels, if this is ok, could be a torque converter or valve body solenoids issue.
Aug 21, 2012 | 2003 Chevrolet Blazer
My transmission is lock
tell me what transmission doing when you say it is locked up.
Dec 13, 2011 | 1998 Plymouth Voyager
Transmission not leaving first gear
SOunds like the linkage needs adjusting. If it don't catch until it is in first gear, that is why it isn't shifting. Hopefully adjusting the linkage will allow it to catch in drive and then you will shift fine.
Good Luck
Dec 15, 2009 | 2000 Ford Econoline
Mtd LAWN MOWER PART # 753-0698 KIT-DECK 42" NEW S Logo
35 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
