Question about Gel Canister 106765 1.5 Quart Ice Cream Maker
I need a new canister lid,mines cracked. - Gel Canister 106765 1.5 Quart Ice Cream Maker
I NEED A NEW LID, CAN I GET IT REPLASTED
I have found that 90% of canister Ice cream makers are modeled the same, I have had a Back to Basics, Rival and West Bend Ice cream makers and the lids are interchangeable.
A lot of companies don't make replacement parts so I usually go with the West Bend lid. The first thing you will want to do if find the brand on your Ice Cream maker (usually found on the motor/top) and see if the manufacture does make replacement parts for your machine. If they do not have parts available I would try the West Bend Ice Cream maker lid U66-2, like i said it is a pretty standard size and will fit most Ice Cream Canisters.
Here is a link to West Bends part page: IC10885 Ice Cream Maker
The lid is very inexpensive so even if it doesn't fit your not throwing away a lot of money.
-Colleen @ Mending Shed
Apr 19, 2015 | Ice Cream Makers
I have lost the clear Canister lid and cap. Can I get a replacement
Where can we acquire a new cover?
Unfortunately Rival doesn't make replacement parts available for their appliances. You can contact them directly at Sites rival products Site However I haven't ever been able to get replacement parts through them.
I have found the 90% of canister style Ice Cream makers have the same size lids. In the past I have purchase West Bends Ice Cream maker lid and it fits perfectly on both my Rival ice cream maker as well as my Back to Basics model.
Here is a link to the parts on West Bends site:
The lids is part number U66-2, and is only a couple of dollars from West Bend.
Apr 14, 2015 | Rival Ice Cream Makers
We need the cover for the mixer.
Unfortunately Rival doesn't make replacement parts available for their appliances. You can contact them directly atSites rival products Site However I haven't ever been able to get replacement parts through them.
Here is a link to the parts on West Bends site: IC10885 Ice Cream Maker
Apr 14, 2015 | Rival 8804-BL 4-Quart Oval Ice Cream...
Where do we acquire a new cover?
Apr 14, 2015 | Ice Cream Makers
We can't get the lid to lock no matter how hard we push down on the deni scoop factory 5100
Same thing happened to me. I think the canister is now misformed. The bottom of the frozen canister pushed up and it won't lock on the bottom piece correctly. Mine is probably 10 years old at least. I am going to try a new canister.
May 16, 2011 | Deni 5100 Scoop Factory 1.5 Quart Ice...
Need Proctor Silex Ice Cream Maker Manual and Container Lid
I have a lid for the older proctor silex. Contact me if you still need one. My canister rusted out so I can't use it anymore.
Nov 23, 2008 | Ice Cream Makers
Deni Ice Cream Maker Manual
I don't have a flatbed scanner to scan it, but here are the operating instructions (at least for the 5201).
1. Place canister in freezer for 8 hours (must be frozen solid-so that you can't hear liquid in canister sloshing around)
2. Prepare your ingredients ahead, and chill them for best results.
3. Take canister out of freezer and place on motor base. Use canister immediately after removing from freezer, as it will begin to thaw once placed at room temp.
4. Place the paddle inside container. Be sure the tould side of the paddle faces up.
5. Lock the lid (the clear plastic piece that fits over the container)onto motor base. The tabs on the bottom of the lid should line up with the indentations in the motor base. This ensures that the lid is locked in place. When fitting the lid onto the base, the stir paddle should "fit" into the lid.
6. Turn the On/Off dial to the right (on position).IT IS IMPORTANT THAT YOU TURN THE UNIT ON BEFORE POURING IN THE MIXTURE. THE CANISTER ROTATES WHILE THE STIR PADDLE REMAINS STATIONARY.
7. Slowly pour the mixture in the top opening of the lid. It is at this time that you place the top on the clear-vue lid and leave the machine on for about 5-30 minutes (time varies, depending on the coldness of ingredients and canister, and desired consitency) If making ice cream, your result should be a soft, custard-like ice cream
8. When the frozen dessert is ready, make sure the unit is off. Remove the lid and the mixture from the bowl with a plastic spoon or scoop. NEVER USE METAL INSTRUMENTS IN THE CANISTER.
9. Ice cream will be custard-like. If you prefer hard ice cream, place in freezer in air tight container and allow to set until it reaches your desired hardness. Don't put the ice cream in the canister in your freezer for more than 30 minutes, as the ice cream will freeze solid to the container and possibly damage it.
Hope this helps... If you need something else, let me know. I will try to check back soon.
Apr 14, 2008 | Deni / 5201 / 5202 / 5203 / 5205 Ice Cream...
Gel Canister 106765 1.5 Quart Ice Cream Maker Logo
26 people viewed this question
Top GE Ice Cream Makers Experts
Andrew Taylor
Andrew Taylor
Are you a GE Ice Cream Maker Expert? Answer questions, earn points and help others
