Question about Acer Aspire One Netbook 8.9" Notebook
Factory restore with Restore Partition - Acer Aspire One Netbook 8.9" Notebook
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 52 Answers
Press F11 (I think) right after power on laptop, and follow procedure. But remember, this can delete all of your data, so choose Repair if available.
Posted on Jul 21, 2013
  • 244 Answers
SOURCE: need to restore acer to factory settings
just boot from your backup disk. it will guide you to reload the Operating system (factory default).
FYI, if you haven't delete the recovery partition, you can use alt+f10 to reload. just press alt+f10 during boot.
Posted on Aug 01, 2008
zohail
  • 1223 Answers
SOURCE: restore factory settings
there are 2 ways for doing this
1) Fast and easy without backup disk just do this
Acer: When you turn on the laptop and see the Acer logo screen, hold the ALT key and press the F10 key (you need to do this before the Acer logo disappears).
2) If the method above doesnt work u can do it thru backup disk u have got when u purchased ur laptop u shud have made it thru Erecovery software.
Pls rate me FIXYA for help !
Posted on Apr 13, 2009
chudd1
  • 18 Answers
SOURCE: ACER NETBOOK MESSING UP NEED TO RESTORE IT BACK TO ORGINAL FACTORY MODE
reboot and hit the alt and f10 buttons at same time and follow the prompts
Posted on May 03, 2009
  • 52 Answers
SOURCE: Want to restore my Acer aspire 4720z!
From Acer direct
The other way before Vista starts up is to tap ALT + F10 (at the same time repeatedly) when the computer is first switched on.. The window of opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then it indicates that you have tapped the ALT + F10 correctly, and all you now need to do is press “Enter” and the Recovery program should load on your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
Posted on Jul 12, 2009
1alexh
  • 484 Answers
SOURCE: restore a acer aspire 4330 back to factory settings
Follow these instructions carefully:
To start the recovery process:
1. Restart the system.
2. While the Acer logo is showing, press <Alt> + <F10> at the same time to
enter the recovery process.
3. Refer to the onscreen instructions to perform system recovery.
I copied the above from an Acer manual, and it works on my own system, which is not the same model as yours. But you must understand that this will basically restore your computer to the condition in which it was when you bought it, unpacked it from the box, and followed the instructions to set up a new computer.
This will give you your system back as if it were brandy new, but in most cases, anything you created, like DOCs, or XLS files, again … ANYthing you created since buying this computer, will also probably not be there any more.
You will have a pristine, clean as new, computer system.
Be careful, be absolutely sure this is what you want to do, and go ahead and do it.
-a.
Posted on Dec 15, 2009
I need key for driver restore
Davis,
You can restore the system to factory conditions by following the information below.
Dell Factory Image Restore The Dell Factory Image Restore tool replaces PC Restore. Access it from the F8 boot menu.
Start the computer and TAP the F8 key. Once the options appear on the screen you can choose Repair Your Computer and follow the prompts to restore the computer to factory conditions.
CAUTION:
This utility formats the operating system hard drive partition prior to restoring the factory image. This means data on that partition is deleted and cannot be recovered.
If the customer creates a second partition with a third-party utility, Dell Factory Image Restore is not affected as long as the image partition is not removed.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
May 07, 2015 | Dell Vostro 1000 Laptop
How to take laptop back to factory settings
Depending on the brand and year it was made there may be a factory partition that will restore computer back to factory defaults, if not then a reinstallation of windows will be necessary, If factory partition is available just do a search o Google with your make and model # such as : How to restore an Acer Aspire 7425 to factory defaults using recovery partition
Mar 15, 2014 | IBM ThinkPad T40 2373 Notebook
Factory reset
jeremy,
To restore your system to factory conditions you can start the computer and tap the F8 key. Once you have the advanced options on the screen choose the one that reads "Repair Your Computer" and follow the prompts to restore the system.
CAUTION:
Thank You,
Dell-Jesse L
Dec 08, 2013 | Dell Inspiron One 2305 Desktop Computer...
I want to restore my hp pavilion dm4 to factory settings
Are you specifically talking about "settings" or are you wanting to restore the PC to its original factory condition? Original Factory Condition can be done with your system restore CD/DVD that you created from the restore partition or from the restore partition itself. In either instance you will lose any data stored if you choose to do an erase wich is the only option to bring it back to its original factory condition.
Oct 09, 2013 | Computers & Internet
Restore factory setting
John,
Dell Factory Image Restore The Dell Factory Image Restore tool replaces PC Restore. Access it from the F8 boot menu while booting up.
Once you have all the options on the screen, choose repair your computer and follow the prompts to restore.
CAUTION:
If the customer creates a secnd partition with a third-party utility, Dell Factory Image Restore is not affected as long as the image partition is not removed.
Thank You,
Dell-Jesse L
Oct 02, 2013 | Dell Inspiron 1420 Laptop
Im trying to factory restore my vaio what does "do
It means do you want to change the default factory partition size (ie. the size of the C Drive). I suggest you select No because you may have a Restore partition on the hard drive and if you change the partition size you may wipe out this Restore partition and you will not be able to do any future factory restores.
May 02, 2013 | Computers & Internet
How to restore sandisk from Factory Image Recovery on Dell Inspiron 1545
Hey Pam,
The factory image on the 1545 is accessed by starting the computer and press the F8 key. Choose the option that reads Repair Your Computer and follow the prompts. If this does not work you will need to manually reinstall Windows. Below is a link that will provide information on manually installing Windows.
How to Restore or Reinstall Windows on your Dell Computer
http://dell.to/Yq0yzy
If you need any further assistance you can email me from my email address listed below.
Thank You,
Dell-Jesse L
email Jesse_Leonard@dell.com
Apr 08, 2013 | Dell Inspiron 15 Laptop
How to reboot my gateway nv53 laptop to factory without a cd bought this laptop used starting to have problems so i want to erase everything and make it like new
Hi.
The laptop may have a hidden recovery partion which you can access from boot up. Turn the laptop off and then restart it. When you see the Gateway logo hold down Alt and repeatedly press the F10 key. From there follow the on-screen instructions to restore the laptop to factory defaults, it should take about half an hour but could be longer.
Remember to back up any data that you want before you restore the system.
If you can't access the recovery partition then you can use Windows to do it for you. Click on the Start Menu> All Programs>Gateway and then Gateway Recovery Management. In the Gateway Recovery window click on Restore and then select Restore System to factory default and follow the on-screen instruction. The computer will restart and proceed with the restore.
Regards.
Apr 27, 2011 | Computers & Internet
How do i restore factory settings without a cd
If you have windows , Click start, all programs, accessories, system tools,system restore, select the restore point and follow instructions to restore.
Nov 29, 2010 | HP Compaq Business Notebook NX9005...
Reset
If you don't have the restore CD there is no way you can restore that model to factory settings. Some (most?) newer models have the restore information, including the Operating system and any other factory installed programs on a separate partition, allowing you to start up from that partition and restore your OS, etc. From that partition, but the 240 needs the restore disks.
Sorry for the bad news, but I hope this answered your question.
Mar 09, 2008 | Computers & Internet
Acer Aspire One Netbook 8.9" Notebook Logo
20 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
