Question about Intex Relaxation Station 4-Person Water Lounge Raft | 58296Q
How do I fill with air - Intex Relaxation Station 4-Person Water Lounge Raft | 58296Q
I have whirlpool 650s top loader washing machine.it shows PE error when switched on.so please tell me what to do to get rid of this error message in the board
the PE error relates to the fill level of the washing machine. The fill level sensor is a pressure operated device. There is a sealed air line that goes from the bottom of the tub to an air pressure sensor. As the tub fills, it compresses the air in this air pressure sensor. When the tub is filled to the level selected on the dial, the sensor stops the fill cycle.
This air line can be plugged or the sensor itself can be faulty. This air pressure sensor is usually located near the top of the tub just under the top cover. If you can locate it, disconnect the air line from the pressure sensor and blow through it - it may be blocked by lint and soap from several washing cycles. There may be a filter in this line to help prevent this blockage. But the filter may have become blocked itself.
Oct 14, 2016 | Whirlpool Washing Machines
WHORLPOOL WASHING MACHINE PE ERROR
In my research, the PE error relates to the fill level of the washing machine. The fill level sensor is a pressure operated device. There is a sealed air line that goes from the bottom of the tub to an air pressure sensor. As the tub fills, it compresses the air in this air pressure sensor. When the tub is filled to the level selected on the dial, the sensor stops the fill cycle.
Sep 12, 2016 | Whirlpool duet Washing Machines
How do I fill the air on wheels for stroller
You will either need a simple bicycle pump (which I always carry in the basket of my stroller justbin case) or go to a gas station where you will be able to fill your stroller tires with air!
/uploads/images/10_2_2014_10_54_38_am.jpg
/uploads/images/10_2_2014_10_55_18_am.jpg
Sep 20, 2014 | Baby Gear
White Magic 650H. Why is error code PE displayed and water reuse LED blinking?
Sep 29, 2013 | Whirlpool Washing Machines
Put water in radiator
Usually, all you need to do is fill the radiator, leave the radiator cap off, start car and let it idle until engine reaches normal operating temperature, and the thermostat opens (upper hose will get hot or warm). Then shut off the car, top up radiator and overflow bottle, replace cap, and you are good to go.
I own a Sentra and was recommended when filling the radiator to keep the car running while filling to help expel air. Also many cars have a bleed valve on top of or near the thermostat housing which should be open while filling with coolant, and as soon as coolant starts coming out the bleeder valve, it should be closed, and then continue filling radiator. If you don't have such a bleed valve, and you still think air might be trapped in the engine, you could find a coolant temperature sensor or sender unit that is at or near the top of the coolant passages or areas of the engine where coolant is found, crack it open to make sure only coolant and no air comes out.
The Sentra engine is easy to trap air, but by running engine when filling, and waiting until thermostat opened before shutting off and capping the radiator, I had no trouble filling the coolant-no air was trapped.
Good luck.
Jul 03, 2013 | Jeep Cars & Trucks
I have problem with my washing machine when i switch on the machine it display shows PE.
May 23, 2011 | Washing Machines
Hi...I currently own Bugaboo Cameleon, which has the air filled wheels. I would really like to purchase foam wheels since it eliminates the part of filling air filled wheels. I would love to purchase...
Yes they do. I've never had a problem with the air filled tires for two reasons. I threw away that plastic joke of an air pump and filled the tires at the local garage to 2 bar / 30 psi not the silly 1 bar / 15 psi Bugaboo recommend. 15 psi is to soft and makes punctures far more likely.
Feb 25, 2011 | Bugaboo Cameleon Stroller
Air conditioner will run for about 3 hours then stops because its full - it seems to fill constantly fast??
Hello my name is Heath it will be my pleasure to assist you. This is normal depending on the amount of humididty in the air the faster it will fill. What you could do is run an external drain line to drain the water while its filling so you don't have to keep dumping the fill pan.
May 26, 2010 | LG LP1200DXR Portable Air Conditioner
On my 05 kx250,im changing the fork seals-do you have to fill and bleed the cartridge seperately or just fill up the fork leg?
The best way to fill fork oil is to add the specified amount and let the forks sit overnight to allow all entrained air escape. Leave the fill plugs off. Ofter you let the air escape, plug it up install the forks and add air to the desired pressure if has that option.
Jan 18, 2010 | 2005 kawasaki KX 250
Intex Relaxation Station 4-Person Water Lounge Raft | 58296Q Logo
557 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
