Question about Boating
Motor will not stay running?
The motor will only run if you manually throttle it up. It dies shortly after starting if you don't give it throttle.
    Sergeant:
  • 352 Answers
SOUNDS LIKE A LOW IDLE CIRCUIT ISSUE...CARB REBUILD...MAYBE!
FIRST FILL FLOAT BOWL WITH SPRAY CARB CLEANER A COUPLE OF TIMES, MAKE SURE PLUGS ARE BRAND NEW, DRIP A LITTLE GAS IN PLUG HOLE(S)..REINSTALL PLUG FIRE UP UNTIL IT BLOWS ALL OUT, OR IT\'S REBUILD TIME
Posted on Jul 21, 2013
Dirty fuel
Rough idle, bogs when I give it throttle then dies
Brad:
Go back to the carburetor adjustment screws and snug them down gently. Do not use force on those screws or you'll damage the needle valve seats. Turn both screws out one and a quarter turns out and start the saw. The motor should stay running.... if not adjust the screws until it stays running. Turn one screw in until you hear the motor start to stall, then turn that screw out just a little bit. turn the other screw in until the saw starts to stall, then turn that screw out a little bit. Now if the saw bogs at full throttle, turn one screw out one quarter turn. See if the saw runs at full throttle... if not turn that same screw in to where it was and try the other screw the same way. If you're good, you can adjust the screw while the saw is running to get the best full throttle run. This is not an exact science, and it takes time and many adjustments to get the saw to idle and run at full throttle. Good luck... and have patience.
Oct 03, 2015 | Garden
Would a faulty electric fuel pump relay be the reason there is no power going down to the fuel pump in a 2002 suzuki grand vitara 2.0 rhz diesel engine
To test fuel flow, have a 2nd person stand over air filter (air filter housing open) with a can of starting fluid in one hand. Don't give any throttle, then 2nd person gives 1-second squirt into air filter while you're turning starter motor (no throttle). When engine catches, immediately give one third to one half throttle. Just before it dies, 2nd person should give another short squirt of starting fluid to keep engine from dying. If throttle won't keep engine running and only starting fluid keeps it running, then yes, no fuel is going through fuel lines. Either its a fuel pump issue or maybe there's restriction because of clogged dirty fuel filter. If it starts but runs rough and has black exhaust smoke, then its clogged or dirty fuel injectors.
Nov 29, 2013 | 2002 Suzuki Grand Vitara
Sachs amici 125 starts but only runs for a few seconds. If I give it throttle dies straight away. Has only done 500klm
Hard to diagnose w/o knowing the history. If motor has been sitting for a while, carburetor usually needs a cleaning to give motor enough gas. Also, check gas & air filter.
Oct 02, 2013 | Sachs Motorcycles
Runs but quits
Probably gummed up carb. If you don't want to try to rebuild the carb, then try adding a really good carb / fuel injector cleaner to the gas/oil mixture. don't forget to use a very small amount, then run the motor as fast as it will go for short periods of time to try and dissolve the gumming in the jets.
Aug 28, 2012 | McCulloch Garden
She almost starts, then dies.
No on the question about the starter being the cause.
You said you poured gas in - I assume you mean in the tank.
If it sounds like it wants to start we will assume the plugs are getting spark from the dist cap. If the pump is failing, you may not have enough fuel pressure.
I would either check fuel pressure or pour some fuel into the throttle body and try it. You could also use carb cleaner in a spray can.
You need to figure out if it is a fuel or ignition problem to proceed.
Jul 30, 2012 | 1992 Cadillac DeVille
'91 oldsmobile cutlass ciera starts and runs fine but dies when driving short distance, restarts and runs fine but dies after another short distance.
Hello! I need the trouble code...The vehicle is an On Board Diagnostic 1 (OBD!)...You can not use a scanner on an OBD1...See drawing below of connector under the steering wheel...Short pins A to B...Turn on the key...Don't start the engine...Light on dash will flash the code ie...4 long blinks...pause... 1 short blink=code 41...each code, if more tan one, will flash 3 times...record the code # and send it to me and I'll fix the problem....codes are all two digit... guru...saailer
Dec 13, 2011 | 1991 Oldsmobile Cutlass Ciera
'87 300ZX(NON-TURBO) STALLS OUT/BOOGS DOWN
overhaul of carb needed, check the vaccum advancer for wear n tear, rapace f necessary fo
Jul 19, 2009 | 1987 Nissan 300ZX
Boating Logo
53 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
