Question about Symphonic ST419E TV
Game Mode No remote... can I use another remote to get a button to switch the input to "game mode"?
  • 2 more comments
  • debraca1201 Dec 04, 2007
    have no remote how can i use the game mode without the remote
    how
  • Anonymous Dec 07, 2007
    i bought the universal remote choose input and the game mode still does not work . is there a another way i can use it ????help please
  • mellomutt Dec 23, 2007
    same problem here. tried 2 different universal remotes. "input" does not toggle game mode.
I have the Xbox 360 remote... It works! ^_^ its $19.99 at best buy. When you programming it just hold down the TV and ok button. The number lights are going to stay on... put in 0445 the push the channel button up and down the TV will turn turn off/on. Then push the input button and you’re done. Hope this help.
Posted on Jun 10, 2009
We bought a universal remote & choose "input" - it works fine.
Posted on Nov 16, 2007
If you bought a universal remote that works how about listing the name/model number.
"It works fine" is useless without that info.
Posted on Jan 01, 2008
2 Suggested Answers
  • 277 Answers
SOURCE: Game Mode
not familiar with this model but ill try try in the menu puting it on game mode then look for external input mode in the menu and turn it too dont work fix ur remote or bye a new one (be sure that the new remote will activate the game option) good luck windman
Posted on Feb 13, 2006
I'm trying to get my TV into game mode. How do I do that?
Please try the following:
  • With the TV on, press the Menu button which will take you to the main menu
  • Then select the "Setup Menu" and press enter
  • Select "Game Mode" and press enter
  • Select "On" and press enter
  • Then press Exit to leave the main menu
These steps should get you going, however if you have trouble please tell me the exact model of your Samsung TV and I can give you further instructions:
Feb 28, 2011 | Samsung Televison & Video
Trying to connect a Sega Genesis. I know it's connected properly to the place where the cable wire goes and then that is connected to the connector. What channel do I go to to play the games?
The input from the Sega wont be on any channel number - you need to select the correct input for the Sega using the "INPUT SELECT" button on the Symphonic remote control supplied with the TV. Switch on the TV the Sega, then press this button repeatedly until you can see the picture from the Sega.
- If you are using the sockets on the BACK of the TV, the correct input is "VIDEO 1"
- If you are using the sockets on the FRONT of the TV, the correct input is "VIDEO 2". You can also switch to the "VIDEO 2" input by pressing the "GAME" button on the Symphonic remote - if you still have it.
If you don't have the Symphonic remote, look for a button marked "INPUT" or "SOURCE" if you are using a universal remote.
If you don't have any remote for the TV, you will only be able to use the sockets on the front of the TV. You will then need to switch to "GAME MODE" by using the buttons on the front of the TV:
1. Switch ON the TV and the Sega;
2. Press the MENU button;
3. Press the VOLUME UP button to open the PICTURE MENU;
4. Highlight GAME MODE using the CHANNEL UP/DOWN buttons;
5. Set GAME MODE to "ON" using the VOLUME UP/DOWN buttons;
6. Press MENU again to close the menu
You should now be able to see the picture from the Sega. If not, check you have correctly connected the Sega to the TV. When you have finished using the Sega you will need to use the method above to switch game mode off again.
Hopefully, I've covered every possible angle. If you have a different Symphonic TV model from the one listed above (ST420FF), the method should be similar, but if you have any difficulty, please post back for further assistance.
BElectric.
Jan 16, 2011 | Symphonic ST420FF 20" TV
How to get universal remote to turn the tv to game mode
I don't know if this can be done with a universal remote, but if you can let me know which brand and model of universal remote you are using, I will check if it is possible. If your universal remote has an "AV", "SOURCE" or "INPUT" button, try these but make sure the game system is switched on so you are able to see if/when you have changed to the correct mode.
If you don't have the original Symphonic remote, you should be able to switch the TV to game mode using the buttons on the front of the TV as follows:
1. Switch the game system on
2. Press the "MENU" button on the front of the TV
3. Highlight "PICTURE" using the CHANNEL UP/DOWN buttons
4. Press the VOLUME UP button once to enter the PICTURE menu
5. Highlight "GAME MODE" using the CHANNEL UP/DOWN buttons
6. Use the VOLUME UP/DOWN buttons to set "GAME MODE" to "ON"
7. Press "MENU" to exit the menu and play games.
The menu should automatically close anyway if you don't press any buttons for about 15 seconds.
When you have finished playing your game, repeat the above steps to set "GAME MODE" back to "OFF" and return to watching TV.
Hope this helps. Please post back for further assistance if needed.
Regards,
BElectric.
Dec 23, 2010 | Symphonic ST419E TV
How do you put the tv in game mode without a remote
Follow the steps below to switch your TV to game mode without using the remote:
1. Connect the game system to the TV using the AUDIO/VIDEO inputs on the FRONT of the TV.
2. Switch the game system on.
3. Press the "MENU" button on the front of the TV
4. Use the "CH" UP/DOWN buttons on the TV to highlight the "PICTURE" option. This is the first option so should already be highlighted.
5. Press the "VOL UP" button to select this option
6. Use the "CH" UP/DOWN buttons on the TV to highlight the "GAME MODE" option. This is the first option so should already be highlighted.
7. Press the "VOL UP" button to change the GAME MODE setting to "ON"
The TV should automatically switch to GAME MODE if you are using the inputs on the front of the TV.
8. Press "MENU" to exit and play your games.
Hope this helps. Please post back if you need further assistance.
Regards,
BElectric
Dec 06, 2010 | Sylvania 6427FF TV
How to change the tv mode. Its on AV mode and i want to change it back to TV mode
Hello
You can set the Game mode and External input mode at the same time by pressing the GAME button on the remote control. "GAME" appears on the TV screen. To exit the the Game mode and the external input mode, press the GAME button on the remote control again. To cancel GAME mode only, adjust the PICTURE control. The game mode will be set ot 'OFF" automatically. In this case "VIDEO" instead of "GAME" appeares on the TV screen. When you press the GAME button if the TV is off, the TV turns ON and will be in the GAME mode and external input mode automatically.
Nov 06, 2010 | Durabrand DWT1304 13" TV
How do I get the game mode back on?
[USING THE GAME BUTTON]
You may also set the Game mode and external
GAME button on the remote control. “GAME”
● To exit the Game mode and external input
control again.
● To cancel the Game mode only, adjust the
picture control. The Game mode will be set to
[OFF] automatically as explained in the previous
section. In this case, “VIDEO”(external
input mode) instead of “GAME” appears on
the TV screen.
● When you press the GAME button if the TV is
off, the TV turns on and will be in the Game
good luck
Jan 30, 2010 | Durabrand DWT1304 13" TV
Help with Game Mode/Channel Switch Please!
Go to Radio Shack and get an universal remote control, i have a Phillips Universal for mine. it has a tv/vcr button that also is an "input" button to switch channels to do this.
Aug 26, 2008 | Symphonic ST420FF 20" TV
Where did you find it? what site & can you give the part# of thee remote, so that I can do the same?
I had this problem on a symphonic 27 inch TV I just bought from a friend who no longer had a remote. The thing with the menu and buttons on the front of the TV doesn't actually change the TV to true game mode. I don't know what it acutally does, but it isn't really in game mode. When it is in true game mode you can't change the channels until you turn the "game mode" off. What I did was bought a universal remote (a specific one that someone told me about) for 8 bucks at walmart and I was then able to switch to game mode with the Input select on the remote. The remote I bought that actually worked is this one: http://www.amazon.com/Philips-Magnavox-PM435S-4-Device-Universal/dp/B00006686A/ref=acc_glance_ce_ai_-2_1_tit/002-3174824-8273629
Make sure you look at it before you buy it and make sure it has a button that specifically says "input" on it. I know that some of the universal remotes don't have an input select button or one that doesn't work. As long as you get a Philips-Magnavox that has that button, you should be ok. Much better solution that paying 30 bucks for a new remote specifically for the TV. Hope this helps.
Apr 26, 2008 | Symphonic ST419E TV
I own a symphonic 27" television
I had this problem on a symphonic 27 inch TV I just bought from a friend who no longer had a remote. The thing with the menu and buttons on the front of the TV doesn't actually change the TV to true game mode. I don't know what it acutally does, but it isn't really in game mode. When it is in true "game mode" you can't change the channels until you turn game mode off. What I did was bought a universal remote (a specific one that someone told me about) for 8 bucks at walmart and I was then able to switch to game mode with the Input select on the remote. The remote I bought that actually worked is this one: http://www.amazon.com/Philips-Magnavox-PM435S-4-Device-Universal/dp/B00006686A/ref=acc_glance_ce_ai_-2_1_tit/002-3174824-8273629
Mar 04, 2008 | Symphonic ST419E TV
Game Mode
Jan 02, 2006 | Sylvania W4913LT TV
Symphonic ST419E TV Logo
2,864 people viewed this question
Top Symphonic Televison & Video Experts
Computer Repairing
Computer Repairing
matt martin
matt martin
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
