Question about Koldfront Portable Counter Top Ice Maker White
How to clean Koldront ice maker - Koldfront Portable Counter Top Ice Maker White
What can i use to clean my portable ice maker. It smells like mildew.
I have cleaned Manitowoc ice makers and their company specifically made an ice maker cleaner and sanitizer. Try a google search for this product.
Dec 13, 2014 | Nostalgia Electrics RIC-100 Retro Series...
My ice smells moldy
Icemakers need to be cleaned about every 90 days, especially if it is a bin type unit that holds recirculated water in a tank which is then pumped over a grate to make ice. You didn't indicate what type of ice maker you have. Many manufacturer produce a cleaning produce for their ice makers. Here is a link to the Whirlpool/Kitchen Aid product:
http://www.amazon.com/Whirlpool-4396808-Machine-Cleaner-16-Ounce/dp/B001ECQ1YM/ref=sr_1_1/177-5038340-6980446?ie=UTF8&qid=1397503407&sr=8-1&keywords=Ice+Machine+Cleaner
It is made primarily for a bin type ice maker and does an adequate job if you use it on a routine basis (i.e., every 90 days).
If your commercial ice maker has removable parts, remove all parts that have direct contact with the ice. Wash these parts in hot, soapy water and use a brush to remove any dirt or mildew from the parts. Remove any ice or water storage bins and wash them in soapy water. Rinse each part thoroughly to remove all traces of soap. Use a 50/50 vinegar/water solution to break up any hard water (calcium) deposits on the parts. Sanitize your ice maker parts by soaking them in a solution made of 1 oz. of bleach and 1 gallon of warm, clean water. Allow the parts to soak for at least 30 seconds and leave them to air-dry.
Clean and sanitize ice makers that do not have removable parts by running two or three cycles and discarding the ice. Check you manufacturer's instructions for how to clean your ice maker. Some machines may not tolerate diluted bleach solutions, so check the sanitizing solution specified by your instruction manual through the machine. Always throw away the first batch of ice made after cleaning. Also change your water filter, if so equipped.
If you
Mar 29, 2014 | Kenmore Refrigerators
How do I clean my FLM70 ice maker
Google Franklin chef FIM70 Ice maker- compactAppliance.com, click on page scroll down page until you see Download product owner's manual ( PDF ) this will give you step by step instructions on how to clean your machine, The machine should be cleaned every 6 months. If cleaning dose not help with the problem than you need to look into a harvest problem.
Dec 04, 2013 | Franklin Industries Franklin Chef FIM200...
GE Profile Model PSS26LGSC Ice maker not working
Did the ice buildup appear to resemble the water overfilling the top of the ice maker? The only thing that I believe that may work is removing the ice maker, clean the excess ice buildup.dry and reinstall the ice maker and see it works. If the ice is above the normal level the ice can cause the motor that pushes the ice out of its slots to strain more than the gears or motor can handle stripping the gear or damaging the motor beyond repair, When harvest takes place the first thing that happens is a heater below the ice maker warms the cubes a little just enough to allow them to slide out of their slots and fall into the ice bin. The ice make for your model does not have replaceable parts and if bad or damaged it is less expensive and time consuming to by a new ice maker. If the water fills above the top of the ice maker it is usually the fault of the water control valve not closing all the way once it fills the ice maker after each harvest. Did water refill the ice maker when you cleaned it? Did the water overfill after you cleaned out the ice maker? What I am asking is water over filling ice maker again after you cleaned out the excess ice? If the water continues to flow from the WR57X10032 Water Inlet Valve
Apr 07, 2013 | GE Refrigerators
My ge monogram ice maker randomly goes into cleaning mode
Your ice maker is electronic and the electronic board inside has failed. Not much you can do in this case except replace the ice maker. Your Monogram uses a=> WR30X10093 Ice Maker Assembly
and here=> WR30X10093 Ice Maker Assembly I will be here should you have questions, Thanks Sea Breeze
Here is a Ice Maker Service Manual that may help should we have missed something=> HERE
Feb 28, 2013 | GE Monogram ZISS480DRSS Stainless Steel
How do i clean my ice maker?
Put your ice maker into the cleaning cycle and run some ice machine cleaner through it.
http://www.appliancepartspros.com/Appliance-Parts/mcn-ice-machine-cleaner-item-number-ap4308815.aspx
Aug 03, 2011 | Scotsman DCE33PA1BC 15in Built-in...
My icemaker just stopped making ice today....please help
Hi, first , pour about 2/3 cup of water into the ice maker . If if freezes , and dumps , replace the water valve. If it does not dump the cubes , replace the ice maker. After pouring the water into the ice maker , remove the bottom kick panel , and clean the bottom coils , of dust , lint , pet hair , etc , as this will raise the freezer temp . An ice maker has to be 5 degrees , to operate , correctly . If ice maker starts working , after cleaning the coils , GREAT ! ( it does happen ) .
Take care
May 16, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
The ice maker just stopped making ice.
First , pour about 2/3 cup of water into the ice maker . If if freezes , and dumps , replace the water valve ( pt. # 4389177 ) . If it does not dump the cubes , replace the ice maker ( pt. # 4317943 ) . After pouring the water into the ice maker , remove the bottom kick panel , and clean the bottom coils , of dust , lint , pet hair , etc , as this will raise the freezer temp . An ice maker has to be 5 degrees , to operate , correctly . If ice maker starts working , after cleaning the coils , GREAT ! ( it does happen ) .
Dec 04, 2009 | Whirlpool ED2FHEXN Side by Side...
I have model 3XART720F02 ART706 TYPE 2055A The water ice distribution area needs cleaning. Can this area be dismanteled
Prepare the Ice Maker For Cleaning
Step1Lift the power located above the ice maker storage tray.
Step2Unplug the refrigerator.
Step3Allow the refrigerator and to defrost. This will melt any large blocks of ice that have accumulated in the ice maker
Clean the Ice Machine
Step1Remove the ice machine storage tray.
Step2Dump any water in the ice machine storage tray.
Step3Wash the ice machine storage tray using warm, soapy water. Rinse and allow to dry completely.
Step4Sanitize the lines of the ice maker. Consult your manufacturer's
directions for steps to do this, because it's not available on all models.
Reassemble the Ice Maker
Step1Replace the ice machine storage tray.
Step2Plug the refrigerator into the outlet to restore power.
Step3Lower the internal power bar located just above the ice machine storage tray. This allows the ice machine to make new ice.
How to Clean an Ice Maker
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Aug 21, 2009 | Whirlpool Refrigerators
Sub zero particles in ice from ice maker
This issue occurs if your Ice Maker is not clean or have dust particals inside, follow the below steps in order to clean it properly:
Step 1 Lift the power bar located above the ice maker storage tray.
  • Step 2 Unplug the refrigerator.
  • Step 3 Allow the refrigerator and freezer to defrost. This will melt any large blocks of ice that have accumulated in the ice maker.
  • Step 1 Remove the ice machine storage tray.
  • Step 2 Dump any water in the ice machine storage tray.
  • Step 3 Wash the ice machine storage tray using warm, soapy water. Rinse and allow to dry completely.
  • Step 4 Sanitize the lines of the ice maker. Consult your manufacturer's directions for steps to do this, because it's not available on all models.
  • Step 1 Replace the ice machine storage tray.
  • Step 2 Plug the refrigerator into the outlet to restore power.
  • Step 3 Lower the internal power bar located just above the ice machine storage tray. This allows the ice machine to make new ice.
  • Jul 20, 2009 | Refrigerators
    Koldfront Portable Counter Top Ice Maker White Logo
    26 people viewed this question
    Top Koldfront Kitchen Appliances - Others Experts
    Angel Joseph Jr.
    Angel Joseph Jr.
    Are you a Koldfront Kitchen Appliances - Other Expert? Answer questions, earn points and help others
