Question about Refrigerators
Amana sxd23vl want freeze solid
4 Suggested Answers
  • 220 Answers
SOURCE: Amana SXD23VL hollow ice
Take the line loose from the back put it in a bucket turn it on and see how the pressure is,if it trickles out your problem is in the water pressure.otherwise you have a bad solenoid valve.
Posted on Sep 01, 2009
aasc
  • 1606 Answers
SOURCE: I have an Amana SXD23VL side-by-side refrigerator
Replace the water valve . Not enough water going into icemaker . Replace pt # 12544001 and 12544101 . This is both water valves , the first is the valve before the filter , and the second is the valve after the filter . If the water flow into a glass from the dispensor has not slowed , then replacing filter is not going to fix it .
Posted on Sep 02, 2009
Did you ever resolve this problem? My frig is doing the same thing and im not sure what the issue is.
Posted on Jan 19, 2011
Top shel and top door shelfs are not freezing food solid ... Bottom freezes , all food on top portion thaws
you may have ab ad fan inside the cooler and all of the cold air is staying at the bottom. Also there may be bad insulation at the top and there may be warm air up there.
Jan 11, 2016 | Amana 20.1 cu. ft. Frost Free Upright...
I have an Amana SD125F-L refrig-freezer. The rubber tube which carries water from inside the freezer wall to the ice maker tray frequently freezes solid with ice. After thawing with a hair dryer, it...
Hi Jan, the problem is a bad ice maker water valve. Pull the refrigerator out and look for the plastic water line that's going to the tube that's freezing. Follow that tube to the faulty water valve. The problem is, its leaking water slowly to the ice maker and it freezes up . Easy fix : Good luck
Appliance Repair Tucson, AZ
Refrigerator Repair service 520-888-7039
Aug 15, 2013 | Amana Refrigerators
I have a amana refrigerator and its not working right I cleaned the condenser coils and checked everything now it doesnt seem to make ice
Is the freezer freezing the food rock solid? Most ice makers require the freezer to reach a certain temp before it will make ice. What is the model number of your unit?
Apr 06, 2013 | Refrigerators
My refrigerator is on the lowest setting and everything is freezing up...water, vegetables, tomatoes froze solid etc....what should i do
i would have a close look at the thermostat i think its stuck on it may be cheapest to just put a new thermostat in
Aug 04, 2010 | Amana ARB2217CSR Bottom Freezer...
My freezer is not freezing food solid.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
dffg
Jan 17, 2010 | Amana ABB2524DE Bottom Freezer...
Sep 01, 2009 | Refrigerators
I have an Amana SXD23VL side-by-side refrigerator and the ice cubes are hollow. Why?
Your water presure to the frige is too low. Do you have a reverse osmosis water system hooked up to it?
Sep 01, 2009 | Amana SXD524VW Side by Side Refrigerator
Refrigerators Logo
21 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
