Question about LG LRM1260SW Microwave Oven
Microwave is not working. A small square sign blinks at the end of timer on display.
A small square red sign appears on the display & the position of this sign is just below the time on which we set the time, at the right down corner. When this sign appear it never start working. Please help with this problem
4 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: Erratic microwave timer dial
You can visit LG's site here and pick your region, then your country.
Then look in the red strip near the center top for the Service Centers link.
They may sell parts in case you or a friend want to do it yourself, but if not, they certainly can do the repair for you.
If it's less than one year old, it should be fully covered under warranty, I would think.
Posted on Dec 15, 2008
  • 4 Answers
SOURCE: microwave oven not working right
if the time of day is not programmed it wont work.... did u do that?
Posted on Sep 21, 2009
  • 6771 Answers
SOURCE: My LG LRMP1270ST microwave oven stopped working in
The main fuse has blown in the microwave, you also have secondary problem that sounds like the magnetron has failed, but there are two other parts to consider, the high voltage capacitor and diode work in conjunction with the magnetron to heat the food. The repairs could run as high as a new microwave oven.
Posted on Feb 14, 2011
Testimonial: "Thank you"
Graetz microwave does not heat, fan & timer work
If everything appears to be working as normal but there is no heat when microwaving then the most likely problem is you have a faulty Magnetron & would need to get this replaced. Try to get an estimate first as sometimes the cost of repair can outweigh the cost of a new microwave.
Dec 27, 2012 | Microwave Ovens
Sharp microwave 8888 is flashing and I cannot remove
see this steps and fix it. God bless you
Reset the clock. Press "Clock" and the correct time, using the number pads. Press "AM/PM" if applicable, and press "Start" or "Clock" to confirm.
  • 2 Press "Timer On/Off" to reset the timer if nothing on the touch pad will operate. Use the number pads to select a new timed amount, if desired, and press "Timer On/Off" to start. Press again to cancel.
  • 3 Press and hold "Clear/Off" for three seconds if the timer will not function or is blinking when you touch the pads. This will release the "Child Lock" feature. Make a new touch pad selection.
  • 4 Disconnect power to the microwave if following Steps 1 through 3 does not resolve the blinking timer. Wait a few minutes, and then restore power to reset the microwave.
  • However if the problem persist the display board
    main control board is faulty
    Oct 02, 2012 | Sharp Microwave Ovens
    My microwave oven from LG MG 604 W has now starting problem, when we open the door the light is on and even the display is okay we can set the timer but when we press the start button it doesn't start...
    The owner's manual should tell you what that symbol means.
    If for some reason you don't still have yours, you can download it here.
    I would suspect a bad door switch or door switch mount.
    You should see my text file on door switches for more information.
    You can order LG parts from Encompass here or you can call them toll-free at 866-779-5835.
    Sep 26, 2011 | Cuisinart CMW-100 Microwave Oven
    A "plastic" square has become
    That is a waveguide and the cover.
    If you let steam of food particles enter the microwave will soon be no good as it will burn a hole in the aerial assembly.
    The cover must be clean and fits as you say with a stainless steel screw.
    Hope this helps.
    Dec 13, 2010 | Sharp R-7A85 Microwave Oven
    Round soft key OXO Timer I need to change the clock time their model # is 1061978
    Operating functions:
    To set the clock, press and hold the clock/timer button for three seconds. A clock icon will appear on the left side of the screen. Input the time using the numerical buttons and then click the clock/timer button to save the time.
    To set the timer, press and release the clock/timer button so that the display shows all zeroes. Enter the desired time using the keypad. Press start/stop to start the countdown. The countdown may be paused by pressing the stop/start button and resumed by pressing the same button again.
    When countdown is complete, timer will beep continuously for thirty seconds and display will flash. Timer will then beep every ten seconds for ten minutes until the stop/start button is pressed.
    This timer will also time up to time activities. To start count up, press clear/memory so timer reads all zeroes. Press stop/start and a plus sign will appear on the right side of the screen as the timer begins counting up.
    Sep 18, 2010 | Microwave Ovens
    Microwave works but does not cook (does not heat up). Everything else seems to work properly.
    hello,
    what this means is that there have been a disconnection on the wire of the element (heater)
    what you need to do to fix up the problem is to unscrew the oven then trace the wire down to the element power point and fix it back to it position
    please make sure all form of power supply is OFF when carry out this function
    Good lock and thanks for using fixya.
    Jun 03, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
    Put in bag of crab rangoon. bag had foil on inside. i saw it spark into small flame. shut of IMMEDIATELY. now there are 2 read lights on display. can't make out what they are and the manual does not...
    Anytime you have arc welding in the microwave, its not a good sign. You may have burned out the megatron tube. The red lights are obviously warning lights. If you canot contact the mfg for the correct reading of these lights, you may want to get another unit.
    Oct 20, 2009 | Emerson Fans Emerson MW8115SS Microwave...
    No display, no power, complete blackout
    Yes, the fuse is bad. Be sure to use a ceramic fuse of the same current (Amps) rating.
    They're available at appliance parts stores, hardware stores, Lowe's, Wal-Mart, etc.
    We're happy to help and we appreciate your thoughtful rating of our answer.
    Apr 28, 2008 | GE Advantium 120 Convection/Microwave Oven
    Microwave won't work; timer word stuck on screen
    The problem is almost certainly on the control panel, which we regularly repair nationwide for $39.95 postpaid.
    Our site is linked here on Fixya: http://tinyurl.com/yzjozk
    Oct 25, 2007 | GE JVM1340AW/BW/WW Microwave Oven
    Keypad Problem?
    look on the back panel for any hole with a "RESET" label next to it. insert a small pin to reset your microwave
    May 25, 2007 | Emerson MW8168B Microwave Oven
    LG LRM1260SW Microwave Oven Logo
    Top LG Microwave Ovens Experts
    William Miller
    William Miller
    Chuck
    Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
