Question about Dishwashers
Heat pumps model 2HP13L36P-1b concord
How to reset light flashing or what they meen
2 Suggested Answers
  • 1144 Answers
SOURCE: Model # CPL J60-1B keeps burning out and
The term "Burn Out" is used when there is acid present in the system, and the acid eats the motor windings coating off, and it shorts out. Air/Moisture in the system causes acid. Burn outs are not always an electrical per sae. When the compressor was replaced, the tech should have flushed the system and also added a special filter/dryer made for such conditions. If that is not done, the residual acid in the system will take out the new compressor. You may want to look into that.
Not exactually sure what you mean by the "Meter Reading" being wrong?
Give me some additional info if you want to persue further.
Posted on Dec 31, 2009
CPJ18-1B Goodman heat pump. has a slow leak. I need to know what Ton or BTU to replace it with.
you have a 1.5 ton. 12000 btu's per ton. your model number has an 18 in it. tells you 18000 btu's
Apr 13, 2017 | Goodman Heating & Cooling
Whirlpool quiet partner iii pots & PANS LIGHT flashing
test the steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 22, 2013 | Dishwashers
Kenmore dishwasher clean button constantly flashing ,washer has been unplugged ???maybe reset itself did not work. 2 yrs old
please follow this steps and fix it. God bless you
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jul 09, 2013 | Dishwashers
Samsung DMT - 400 delicate light blinking
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Why won't my Kenmore dishwasher display work properly?
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Dishwasher Siemens /se64m359gb tap light comes on in red on main display,what does this mean?
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jul 08, 2013 | Dishwashers
Ed light flashing
I think you might try the reset switch on the battery pack
Apr 24, 2013 | Pride Mobility Victory 3 Wheel Electric...
Frigidaire Model ES200 White Electric Range f1
F-1 USUALLY MEENS THE MAIN PCB OR CLOCK ***. I WOULD RECOMEND REMOVING THE POWER AND PULLING IT AWAY FROM THE WALL .TAKE THE BACK PANNEL OFF AND LOOK FOR A BURN MARK. THAT SHOULD SHOW WHAT BLEW.
GOOD LUCK!
ERIC
Mar 05, 2010 | Electrolux Kitchen Ranges
Whirlpool Quiet Partner V light flashing
most of the time this meens your heat element is burnt out.
Feb 25, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Thermostat wiring goodman model aruf032-ooa-1b
is this a heat pump or straight cool with heat strips?
Mar 16, 2009 | Heating & Cooling
Dishwashers Logo
76 people viewed this question
Top Dishwashers Experts
Owen Barnes
