Question about Vehicle Parts & Accessories
1994 fleetwood pace arrow transfer switch location
  • 47 Answers
SOURCE: We have an Atwood 34m BTU furnace in our 1999
Check the belts for proper tension and inspect for cracks and fray replace if belts are in poor shape
Also look for a bearing with needs a lube job
A little bearing grease should solve the trick
Good luck
Posted on Jun 17, 2011
Ironfist109
  • 3018 Answers
SOURCE: 83 Fleetwood Pace Arrow (454 Chev chasis) front
  • Below is a diagram of the wiring diagram of the heater/AC fan
  • As you can see there is a fuse and a relay that would be the first two suspect.
  • If you have any comments please feel free to leave them here and I will respond to you.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Posted on Sep 17, 2011
dttech
  • 4803 Answers
SOURCE: 1996 fleetwood pace arrow owners manual
You might try the manufacturer's web site.
Posted on Dec 17, 2011
  • 747 Answers
SOURCE: Need a Wiring Diagram for a Radiator Condenser Fan which shows how to locate the Relay and Switch for a 1996 Fleetwood Pace Arrow Vision RV P30
I would call fleetwood out of nappannee Indiana a lot of times they use a special wiring using the A.C systems they install
Posted on Sep 18, 2012
carlsbiz
  • 1124 Answers
SOURCE: i need to find starter for 1988 fleetwood pace arrow, not turning over when itry to start it.
The Starter is located at the lower part of the motor where the
motor meets the trani.. You could probably follow the main positive
battery wire from battery to the starter to find it.. If that was your question ?
If you are trying to locate a new starter and or which one to get,,
you can find out what motor is has via the VIN # and go from there..
Try with this site ---
http://www.autopartsnerd.com/content.wws?fname=subject/vin.html
Good luck !
Posted on Sep 30, 2012
Where is the brake fluid reservoir located on a 1995 fleetwood pace arrow
I think it is on the driver's side framing. I believe you need to go through the front driver's side wheel well to get to it.
May 31, 2017 | RVs
How to id 74 pace arrow motor
Look at the motor builder not at the RV section, Louis
Aug 24, 2016 | RVs
Where does the white wire? go on fresh water tank level indicator for a 1986 pace arrow by Fleetwood
SORRY we would have n idea . but check what works and doesn't then you might have located the problem .
Feb 28, 2016 | Cars & Trucks
1983 Pace Arrow by Fleetwood. Where can I get a wiring diagram?
contact Fleetwood tech support they will send you a PDF file of it
Dec 17, 2015 | RVs
I need scan my 1994 pace arrow mobile home where's the plug located?
In 1994 there were not any such features. OBD-1 began in 1996 for most vehicles.
Feb 20, 2015 | Cars & Trucks
Fleetwood 1997
Until is not leaking, don't worry
Mar 20, 2013 | Cars & Trucks
Sep 18, 2012 | Cars & Trucks
Where do i find a manual for a 97 37ft pace arrow? or a least the specs for gas and holding tanks?
The only place you are likely to find a manual for a Pace Arrow is from the manufacter. Although ebay does sometimes have Pace Arrow manuals for sell on it.
Jul 01, 2011 | Ford F-450 Cars & Trucks
I bought a used 1984 pace arrow on a chevy chassic, while checking out the wiring I have found so many wires attached to the fuse box and other wires, I am trying to find a wiring diagram for both the...
you will have to contact pace arrow if still in business for the 120 volt wireing.they are all pretty much the same in similar years motor home so generic rv how to manuel would be ok.contact chevrolet for a cab and chassis manuel. as a side note, on the 120 volt system the black wire is not a ground.it is the hot wire.the white wire is nutral[ground] the 12 volt stuff is color coded like a 1984 chevy
Jun 07, 2010 | 1989 Cadillac Fleetwood
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
