Question about Polaroid Televison & Video
My sons Polaroid p24led12 won't switch on, the remote flashes but thats it. It is only 8 months old. I have tried replacing fuse in plug.
2 Suggested Answers
lenwest
  • 150 Answers
SOURCE: Indesit washing machine WIXE127 switches off main fuse
Have you added anything else that is drawing juice on the same breaker?
If so try turning those off.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Posted on Jan 31, 2009
HOW TO FIX A POLAROID P24LED12 TV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window".
Jul 23, 2015 | Polaroid Televison & Video
My rs200 toyota sewing machine bobbin won,t take thread round to lift bobbin thread
At 8 months old must still be under warranty, so take it back before you have any more problems and get a replacement.
Jan 19, 2015 | Toyota Sewing Machines
Reprogram astrostart j5f tx2000
Get under the dash or where the unit is located.
You will see 8 or 9 dip switches on the unit with an LED beside them.
Turn switch 1 and 8 on.
Press and release the brake. (LED will flash)
Press and hold start button on remote. (LED will flash and parklights will flash once.
Turn switch 1 and 8 to off.
Press and release the brake (LED will flash once)
In future would be a good idea to supply vehicle details etc as can sometimes be a known condition , that saves time looking it up , good luck
Nov 18, 2014 | Cars & Trucks
My polaroid lcd tv, wont turn on, its 16 months old, any ideas?
Try plugging it into another outlet - one which you are certain is working. If that doesn't work, you might have a bad fuse inside your TV. If that isn't it, the power supply board may have failed.
May 25, 2014 | Polaroid Televison & Video
Lights won't work on Harbor Breeze ceiling fan
Ceiling fans operated with remote controls, pull chains, and/or wall switches tend to get confused and just fail. You can try disconnecting power at the source and, while pausing briefly, remove batteries from the remote and push all buttons to eliminate the "stuck button" cause. Then, reconnect power and try various combinations of controls until something works or you give up in frustration.
May 03, 2017 | Dryers
Polaroid tdac-02212 remote quit working
should be under warranty but the remote itself can be tested by any shop--also some digital cameras when remote pointed at them in a dim room will react on their display screen with a flash when remote pointed at camera and buttons pressed on the remote.
May 21, 2012 | Polaroid TDA-03211C 32 in. LCD HDTV
Tv won't turn on at all
Hi
the best thing you do is to go back the unit where it you buy because this is under warranty
Thanks!
Jun 09, 2009 | Toshiba REGZA 47HL167 TV
Directv remote
1) Use 2 new AA batteries in RC32 remote control;
2) Slide mode switch to "TV";
3) Press and hold the MUTE and SELECT keys at the same
time until the green light under the selected switch
position flashes twice, then release both keys.
4) Enter 9-9-1-1.
5) Press PWR button on TV.
6) Point the remote at the TV and press CHAN+. Repeatedly press CHAN+ until the TV turns off. Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7) Use the CHAN- key to step back a code.
8) When the TV turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key. If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the TV remote control.
9) To verify the code, slide the MODE switch to the appropriate position.
10) Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
11) Enter 9-9-0. (The green light under the selected
switch position flashes twice.)
12) To view the first digit in the code, Press and release then number 1 key. Wait three seconds, and count the number of times the green light flashes. Write this number down in the TV owner manual.
13) Press number 2 for the second digit, 3 for the third digit, 4 for the fourth digit and 5 for the final digit.
To control TV volume from Directv RC32:
1. Press and hold the MUTE and SELECT keys until the
green light under the DIRECTV position flashes twice,
2. Using the number keys, enter 9-9-3. (The green light
will flash twice after the 3.)
3. Press and release the VOL+ key. (The green light
flashes 4 times.)
Feb 11, 2008 | Polaroid TLA-01511C 15 in. LCD Television
Polaroid flm 3201 wont turn on
If you have no power light at all on the front of your tv. Check the fuse by the power coard.
If you have a red light only and have the dark power board with black heat sinks. check the fuse in the center of the power board.
if the light turns blue when you hit the power button but no picture and have the dark power board replace the 2- 1000 mfd 10 volts caps with 2- 1000 mfd 16 volt caps at 105 deg.
need more help let me know
Nov 24, 2007 | Polaroid FLM-3201 Television
Polaroid FLM-1507 locked
My son locked my FLM-1507. I do not have the remote to unlock it. I also need the code to unlock my FLM-1507.
duanehatl@yahoo.com
Sep 16, 2007 | Polaroid FLM-2011 Television
Televison & Video Logo
348 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
