Question about Recordex Computers & Internet
Target Drive not ready error message - Recordex Computers & Internet
Crankstart
  • 696 Answers
SOURCE: Trying to burn dvd. It keeps saying Target drive not ready
Hi, assuming the rest of the drives are working there are three probable issues.
1. The cabling for power or data is loose or faulty, check the cabling, remove and reseat it, then try again with new data cable and swap power connectors with one of the other drives. If the results do not vary it's not the cables, If the problem moves with the data cable but is not resolved by replacing the cable it is the logic board at fault.
2. Try cleaning the drive, do not use brush cleaners as they can damage the head, just used a compressed gas can or air compressor on less than 20lbs/in, if this does not work...
3. The second drive may be faulty, check with the manufacturer/manual. Many of these devices require a specific model or one of only a few models for compatibility, replac with an appropriate model.
Hope this helps FixYa,
Chris
Posted on Jul 18, 2009
  • 8404 Answers
SOURCE: target drive keeps saying not ready
May I suggerst you reseat all internal connections on your drive? (Power, IDE or what ever) Make sure you are grounded to the case while you do this and you have the power cord disconencted from the wall.
Close up everything and re-connect all the stuff you disconencted.
After you do that, remove the device via the device manager.
Reboot - let windows refind the device. Have the driver CD ready if applicable.
Let me know what happens.
a
Posted on Sep 21, 2009
SOURCE: accutower duplicator
If your Accutower says Source Drive Not Ready, it means the tower is not recognizing the original disc that you want to make the copy of. Make sure the master disc is good by testing it on a different computer from the one you burned it on. Also, check that you have the source drive set correctly on the tower. Good luck!
Posted on Sep 29, 2009
  • 82 Answers
SOURCE: My Teac 1x1 dvd/d11A/kit burner/Dvw/D11A: will
whatever software you are using to burn dvd;s, make sure the right burner drive is selected. if it is selected properly and still having an issue. that means the dvd writer is busted and can't detect a blank disc place into it. in that case, have it replaced.
Posted on Nov 06, 2009
1vagabondlad
  • 56 Answers
SOURCE: getting an error message
Sounds to me like the sychronization got stuck, on the laser and its not going back to start. unfortunatly it's hard to fix but more than not it got dirt in it. if you open it, try vacuuming it out first with a small pait brush but don't force anything then you can rise it with a slight mist of Lysol, yea! works great and wont short out if used sparingly. good luck!
Posted on Sep 06, 2012
The burning drives are not recognizing the blank media.Try using all of the duplicator bays by burning to another drive bay. If all other drives burn fine then the one drive may need to be replaced.Try a different blank CD or using a different brand. The most common fault for this message is a bad blank disk.Finally clean the drive bays by using compressed air to blow any dust out of the system.
Dec 18, 2013 | ProDuplicator Computers & Internet
This message means that the burning drives are not recognizing the blank media. There are a few things to try and remedy this though the unit may need repaired.
First, try using all of the duplicator bays by burning to another drive bay. If all other drives burn fine then the one drive may need to be replaced.
2nd, try a different blank CD or using a different brand. The most common fault for this message is a bad blank disk.
3rd, It is OK per Microboards to open the unit and check for a loose drive cable. A loose cable can cause this error too.
Finally, try cleaning the drive bays by using compressed air to blow any dust out of the system.
If the error still continues then call Microboards tech support at 952 556 1639 to set up a repair.
Apr 15, 2013 | MicroBoards (DSRDVDD882) Burner
The error message "Target drive not ready" indicates that there is a problem with the blank disc inside the writer drive(s) of the duplicator. In order to solve this problem, please insert brand-new blank media into the writer drive(s) and press the ENT/OK button twice on the duplicator. If you are still having problems, please feel free to contact us @ 888-686-8868 x208. Thank you for your inquiry and thank you for purchasing EZ Dupe products.
EZ Dupe Technical Support
Jan 09, 2011 | EZ Dupe EZDupe CoolCopyD5 DVD 1 to 5...
My ACARD Technology Pro DVD duplicator is giving me a "Target Drive Not Ready" message and will not duplicate. What can I do?
My ACARD Technologyicon1.png Pro CD/DVD duplicator is giving me a "Target Drive Not Ready" message and will not duplicate. What can I do?
Nov 30, 2010 | Computers & Internet
What do you when it says target disck is not ready on a duplicator
Your disk *WITH* the data is the "source" disk.
Your "blank" disk is the "target" media.
Try a different "blank" disk.
If not any better, then take the unit to a computer technician, to trouble-shoot the hardware that is used to write onto the "target" media.
Apr 02, 2010 | EZ Dupe 1-Target CD/DVD Duplicator with...
Target Disc not Empty!!!
I have a DVD/CD duplcator, yes I can burn a CD, but when I try to burn a DVD I get this message TARGET DRIVE NOT READY, what can I do?
Nov 26, 2008 | Acard Technology (ARS-2030LD) DVD±RW...
Accutower duplicator
accutower won't burn cd it says "no clear cd'
Apr 08, 2008 | Tower ACCUTOWER CD "Music" 5 Writer...
Computers & Internet Logo
59 people viewed this question
Top Recordex Computers & Internet Experts
David Payne
David Payne
Are you a Recordex Computer and Internet Expert? Answer questions, earn points and help others
