Question about Asko 24 in. D3112 Free-Standing Dishwasher
Flashing light flashing glass light
The theft light is flashing, how do you turn it off?
you could try disconnecting the battery .or call your local ford dealer .
Oct 15, 2015 | 1999 Ford F150 Regular Cab
There is a blue light flashing on rear view mirror. Why?
Usually a flashing blue light is from an aftermarket installed alarm system or remote starter.
You may want to check your owners manual if the light is in the mirror glass.
Feb 21, 2015 | 2009 Hyundai Accent
I have an ariston ll64 and it is stopping a the last cycle button which is the picture of wine glasses. It then flashes with a green light.any ideas?
Error messages:
Your dishwasher is equipped with a safety system which is able to detect any operating anomalies. These anomalies are reported by one or two wash cycle indicator lights "E" flashing rapidly.
24432725-0h3kxpflbez5mdeb5anq3st4-3-0.jpgFlashing Led diode below button with the image of wine glasses means faulty thermistor NTC. So, could be faulty: thermistor NTC (defective or not positioned), wiring, control board.
Dado
May 16, 2014 | Ariston Technologies LL64WNA Built-in...
Projector had been overheating so we cleaned out the filter. When it was turned back on there was a loud pop. We turned off and turned back on, red lights started flashing and the fan roared loudly and...
The projector lamp has probably failed. If it had been overheating, the glass for the bulb would be weakened and then eventually when turned on the glass shatters, the pop you heard. Bulb replacement is usually a straight forward user replacement item. Ebay is often your best choice to get a bulb at a reasonable cost.
Mar 29, 2011 | Office Equipment & Supplies
What is the best setting for taking photos through glass.i have a olympus sp-590uz .ive only had the caamera a few days any help would be great
Photography through glass isn't difficult if you know a few guidelines.
If you're indoors in a museum, or aquarium etc, it would be best to turn the flash off. This will eliminate the flash reflecting into your photos.
If you need to use a flash, make sure you're not squared on the glass. IF you're at a direct, 90 degree angle from the glass, that's when the flash will reflect off the glass and back into your lens. An angle between 50-70 degrees will all the light from the flash to illuminate the subject on the opposiite side of the glass without reflecting.
You're camera has a high megapixel resolution so you can get great color and detail. If you use the zoom feature, you'll need to hold the camera very steady or if possible, use a tripod.
Another technique that alot of photographers use is called "bracketing" . Many of the newer digitals have a setting that will allow you to do this. Bracketing is simply taking 2 or more photos of the same image with slight exposure setting changes being the only difference between each shot. For example, one shot would be normal exposure, one would be a step or two over-exposed, and another would be a step or two under-exposed.
Many of the cameras will take the 3 shots all together-check your owner's manual for specifics.
With these simple techniques, you'll look like an ace!
K
Sep 18, 2009 | Cameras
My Phaser 6120 leaves light lines across the face
Lift out imaging unit and look down and back toward you, may need flash light, and you will see a 5" x 1/2" piece of glass. Carefully wipe it with soft cloth. Toner gets on this glass and creates the streaks. Often means a bad toner cartridge is leaking toner. Ron
Jun 28, 2009 | Xerox Phaser 6120N Printer
Suddenly I get circles of light on peoples glasses
The circle of light is almost certainly a reflection from either the flash, a lamp, the sun, or some other source of light since it only occurs with glasses. Try to eliminate possible sources for the reflected light. If you find that the flash is causing the problem, then the camera should be set to eliminate the flash going off. You can do that by selecting "no flash" if there is enough natural light. You many need to use the largest aperture and a tripod because low light will require long exposures, and any shaking will blur the photo.
Jan 30, 2009 | Nikon Coolpix 885 Digital Camera
Light flashing on 2410
Unplug the printer and leave it unplugged overnight (or just a few hours), then plug it back in.
Sep 15, 2008 | HP PSC 2410 All-In-One InkJet Printer
Flash rebound
A camera flash against a glass, or any reflective surface, will bounce the flash light right back at you. Turn off flash when shooting through glass. Note flash is only for shots less than 12 ft distance. It take it you are shooting scenery shots through vechicles or buildings, ie, long scenery shots anyway, so flash does nothing but bad things.
Nov 01, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
Fish photographing
I have had good luck with fish pictures by pressing the front of the lens barrel up against the glass. This blocks out reflections that the glass will cause and it also holds the camera very steady. If it is a small curved glass bowl, make sure that the glass lens does not actually touch the glass. You could scratch the lens. If the fish are in a small container, you will have to use the "macro" feature on your camera so that you can "close focus". If you have to take a photo with the camera lens away from the glass, the camera just may try to focus on the glass instead of the fish behind it. If this occurs, just point the camera at something nearby that is the same distance as the fish; press the shutter button half way down. Then swing the camera back to the fish and press the shutter button the rest of the way down. Never try to take a flash picture of anything behind glass as you will end up with a great shot of your reflected flash. However if you have the camera lens pressed against the glass, you can use flash if necessary.
Sep 08, 2005 | HP Photosmart R607 BMW.WilliamsF1 Team...
Asko 24 in. D3112 Free-Standing Dishwasher Logo
14 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
