Question about Poulan "Poulan" Push Mower
550 Had difficulty starting. Once started it ran very sluggish and then stopped. Checked plug, wired brushed it, cleaned filter, still nothing.
    Sergeant:
  • 352 Answers
TRY MY SELF PROCLAIMED TRICK: THE ON THE MOWER CARB REBUILD.
1. GAIN ACCESS TO CARB THROAT
2.FILL ENTIRE FLOAT BOWL WITH SPRAY CARG CLEANER
3.LET SIT
4. DO THIS A FEW TIMES....MAKE SURE PLUGS ARE "NEW"...OR ABSOLOLUTELY CLEAN...DRIP A FEW DROPS OFF GAS INTO SPARK PLUG HOLE...RETHREAD PLUG...FIRE IT UP UNTIL IT RUNS AND PULL THRU AND BLOWS OUT ALL IN CARB
Posted on Jul 21, 2013
I am completely stumped....Pressure Washer will not start I feel like I have tried everything. Please help
buy a new carburator on ebay for 20.00,the diaghram and all the rubber hoses are shot,that is what ethanol does,eiher try a rebuild kit or wait 2 days for a new one
May 07, 2015 | Cars & Trucks
Why won't my 130BT blower start? the unit won't start replaced the plug, dumped the fuel added 50:1 gasoline still nothing? Sprayed starter fluid in carb still nothing.
I had that same problem. I have not tried fixing lately. Take apart the carburetor and spray it and brush with carb-cleaner. You can try cleaning the fuel filter in the gas tank. Fish it out with your finger or a piece of metal wire. Take it apart and clean it with gasoline, also clean the air filter with soap and water and let it dry. If it still does not start, clean the muffler, where it emits the burnt co2, carbon builds up there over time (there is also a screen there where you can see the brown/black carbon). Try cleaning w the Carburetor cleaner spray and a toothbrush, wire brush or thin flat-head screwdriver and let dry. If that doesn't work, maybe you need to replace the whole muffler part. I think that is what I might do. I'm not using so haven't got around to fixing it. Hope it helps if not maybe a professional can help. Good luck...
Sep 18, 2014 | Husqvarna 295cc Back Pack Blower HVH 130BT
I have a 82 Suzuki gs550 . Haveing starting issue . One day it ran fine the next day all it did was click once. Charged the battery it read 13.17 . Bought a brand new silinoid and installed it . Cleaned...
have you checked the brushes in the starter or cleaned the commutator? Best to remove the starter and have it bench tested at a local parts store.
Jul 05, 2014 | Cars & Trucks
1991chevy lumina starts hard, runs sluggish and then dies when put into drive. already replaced computer
Having replaced the computer, best thing you could do now is a complete tune up-new spark plugs, wires, distributor cap, rotor, air and fuel filter. Change the oil and check all fluids. Have the computer scanned for trouble codes. Check if your catalytic converter is blocked or clogged-if bad, they will plug up and stop the car.
Apr 10, 2013 | Cars & Trucks
Car was running a little sluggish, changed plugs and car ran great for 45 minutes then started running rough. checked ignition module, coil packs. all ok. replaced wires, ran better then started running...
Make sure the HT leads are secure. They might be popping off, causing it to not fire on one cylinder. I always change the plugs and leads at the same time to keep them the same age. HT leads break down rapidly and need regular replacement.
Jun 23, 2010 | 1990 Oldsmobile Cutlass Ciera
Chainsaw strarts OK but stalls
Most likely fuel "Air" problem.
Old fuel can and will gunk up the air flow jets.
Would suggest cleaning the carb and filters.
Then replace with good fuel mixture and start again. :)
Make sure the choke is set correctly and the air filters are clean.
Had a lawn mower that would NEVER crank correctly after sitting idle for the winter. Had to dis-assembly the carb and clean literally with paper clip and tooth brush. Never once had to change the spark plug or wires. After spring cleaning (LOL) it would usually crank on the 2nd pull.
Mar 28, 2010 | Garden
I recently installed a fuel pump on a 1993 cadillac deville. i also changed the filter,emission control,plugs and wires. it fired up and ran for about 14 minutes. it ran very sluggishly then quit. i have...
was it the correct fuel pump with the propper psi?
have you checked you wires to make sure none got crossed. are the spark plugs propperly gapped?
Mar 07, 2009 | 1993 Cadillac DeVille
5 speed manual transmission sluggish and jerking during accellera
wqithout looking at it directly , could be neglect to the car it self, clean them batt, cables not just the outside of them take them off the battery . clean the right , ck the wires make sure thay are also not corroided , as for the running like **** , sounds lik maybe a vacuum line came off , could be bad sparlk plugs wires etc, if it just happened in a spur of the moment thing , I would ck those vacuum hoses , something like tha will make it run like you are saying , tune it up , plugs and wires etc, clean it so you can see it .listen for any strange noise and do be carful
Jan 23, 2009 | 2001 Toyota Corolla
Poulan "Poulan" Push Mower Logo
67 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
