Question about KitchenAid KGST300 Gas Kitchen Range
Oven "bake" doesn't work...
When we hit the "bake" and "start" buttons, the gas oven no longer ignites. The top burners and the broiler still work fine. I thought the bake element might need replacement. If this is the problem, where is it located?
  • 1 more comment
  • Mitcho Sep 01, 2007
    Thanks for the help! I still needed to have the repair done by a professional, but it was nice to know the exact problem and that it was beyond my own repair skills...
  • Anonymous Apr 28, 2008
    Our bake element does not ignight any more on our Kitchenaid KGST300. The broil element and the stove top works fine so it can't be a gas problem. We tried setting the temp. to bake on 200 and it ignighted... It has been a touch and go if the oven would turn on for the last few months, and now it won't. We checked the glow bar as suggested with someone else answer, and it is working fine. Please help as I am having overnight company soon! Sharon
  • Anonymous Mar 21, 2014
    can you tell me where we can get one
  • 63 Answers
Sounds like the bake glow bar needs to be replaced it is under the bottom cover inside the oven good luck
Posted on Aug 29, 2007
SOURCE:
The oven on my g70m no gas coming through the grill still operates
Good morning Mark, you most likely have a weak oven igniter. That would prevent the gas valve from opening causing a no heat condition in the oven. Also try the broiler if it's separate from the bake burner.at the top of the oven cavity as opposed to the broiler drawer underneath. That igniter typically gets used less often and takes longer to wear out and the broiler will come on. It could also be a bad gas safety valve but that is an unusual problem. Hope that helps.
Feb 10, 2018 | Ovens
Top oven not heating up on BAKE, broiler gas and flames come on. Stove top burners work, Bottom oven heats for BAKE and BROIL.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 08, 2011 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Oven "bake" burner wont ignite on a gas oven.
heatman101
Dec 27, 2010 | Whirlpool Ovens
Amana gas oven not working
SOUNDS LIKE U HAVE A WEAK BAKE IGNITIOR REPLACE THE BAKE IGNITIOR IT WILL SOLVE THIS ISSUE
Aug 31, 2009 | Amana ARGS7650SS Gas Kitchen Range
Oven won't ignite but broiler does
If your oven won't bake, check these:
Bake igniter
Other causes
Bake igniter Usually when an oven won't bake, it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself.
The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame.
Other causes Other reasons that your oven may not bake are:
  • The clock settings are incorrect (if you have timed baking or a self-cleaning oven).
  • The thermostat is defective.
  • The safety valve that prevents accidental gas flow is defective.
  • The selector switch is defective.
Aug 11, 2009 | Ovens
Bake does not work but broiler does.
OK, it is likley that the oven ignitor isn't working and needs to be replaced. To verify if this is the problem, when you turn on the oven to BAKE and set the temp at say, 350. Watch through the window, (or you can have the door open). Look at the bottom, back, center and see if you see a bright orange glow appearing under the bottom panel.
If you don't, that is why the oven won't lit the gas. There is an ignitor for both the broiler burner at the top and for the bake burner in the oven compartment.
The reason that the temp display reverts to 100 degrees is because that is the lowest default temp setting for the display and until the oven temp actually starts to increase, it won't change. So the temp display is working correctly for the BAKE function.
Here's a line drawing showing the part you may need. Ignitor Part # WB13T10045. The good news is that your oven uses the same ignitor for both the broiler and bake burner tubes, so you could swap them if you wish to confirm that is the problem before you go and order/buy a new one. These aren't cheap at $91 bucks, but you can shop around the web for a better price if you determine you need one.
Sometimes the ignitor burns out half way through but because it still lits/glows, people think it's OK, but it won't get hot enough to signal the gas valve to open and allow gas to ignite and get the oven cooking.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=JGS905SEK1SS&productCategoryId=0124250&brandId=3272&modelName=GAS-RANGE&diagramPageId=00001&componentDescription=GAS%20&%20BURNER%20PARTS&documentId=G6090295&backToLink=Return%20to%20Sub%20Components%20list
Hope this helps you out and remember to disconnect the oven from the electric power before performing any repair work. Best regards!
Aug 01, 2009 | GE Profile JGS968 Gas Kitchen Range
The oven gas does not come on? Top and Broiler does. Oven igniter does glow
Bake igniter
Other causes
Jul 11, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Whirlpool gas oven not working
hi. thanks for the question .the problem you are having is with the bake igniter located under the floor ,of the oven .replace the igniter. thanks te appliance doc rate me please
Oct 01, 2008 | Kitchen Ranges
Broiler will not light. Oven & top burners work fine
hi thanks for the question check to see if the broiler igniter is broken that could be the problem do you use the broil more than the bake if you do then change the broil igniter thanks the appliance doc
Sep 16, 2008 | GE Spectra JGBP30 Gas Kitchen Range
KitchenAid KGST300 Gas Kitchen Range Logo
480 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Jay B
Level 1 Expert
Colin Stickland
Colin Stickland
ittco
Level 1 Expert
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
