Question about Refrigerators
Fridgemaster mtrf222 instructions
I am purchasing a second hand frdge master but I've been told that the thermostat does not switch off. It doesn't over heat and it doesn't over freeze. How would I be able to fix this problem?
  • 10 Answers
SOURCE: Why is my car over heating? Not all the time like
i would start with the water pump .make sure it isnt damaged ,leaking ,or going bad,check hoses connected to it for leaks. add a thermostat for your vehicle ,have the radiator pressure tested,checkA C circuit to make sure fans are respondant to whatever situation i.e. fans come on with A C being on. check your cooling circuit relays, check your radiator cap,check coolant level,coolant temp switch and last but not least have vehicle checked for intake leak 01 malibus are notorious for over heating problems .hpoe ive been helpful
Posted on May 15, 2011
  • 405 Answers
SOURCE: Installed a new Filtrete thermostat on a new
hi.Does the new thermostat has the same rating with the old one?
Posted on Jul 23, 2011
SOURCE: the second hand on my
I see your issue here.
Watch this video it showed how to get the the Hand back to the 12 o clock position.
Tag Indy 500
I hope this Helps.
Good Day.
Posted on Aug 10, 2011
oldTech2332
  • 2341 Answers
SOURCE: I have made an attempt to fix my refrigerator.
Its ok to completly melt the frost using your hair dryer but first that needed to be done was check the thermostat while its still cold. Also i suspect that the wire ya find in the freezer not connected to anything has broken off of either the defrost heater or defrost thermostat so that is why the frost is building up.
GENE
Posted on Oct 09, 2011
caroldon
  • 17129 Answers
SOURCE: I've got a Kelvinator dishwasher KD12MM bought second hand, the machine goes on but does not pump water. Please help
Possible that the pump has clogged or is jammed with dirt. you will need to remove the pump and clean the pump assembly for a good spray pressure. If this wont work then the pump is faulty and needs to be replaced.Check this link for tips:
http://www.espares.co.uk/advice/dishwashers/a/3
Posted on Mar 13, 2012
I've just been given a second hand Daewoo fuzzy logic DWF 4094R. I've been told it works fine, but it has a hose missing. This didn't worry me because I like to do cold water washes. But I
I don\'t under stand what help you need.
If the cat urine smell is outside of the appliance then wash it down with Clorox.
If there is a filter on the output of this machine then service that before doing the next step.
If the odor is inside the machine then run Clorox for a couple of long hot cycles AND then run white vinegar in it. The Clorox will sanitize and the white vinegar will loosen and remove minerals that hold odor.
Add a quarter cup of white vinegar to each load until the odor is gone or your clothes will stink.
My thought is that there is a reason they gave you this "working" machine. If you have further issues then let us know.
Good luck,
Mike
Feb 05, 2013 | Washing Machines
My thermostat keeps blowing itself out
Electrical problem getting to hot ie burning out stat check transforme rvolts ?
Jan 24, 2013 | Heating & Cooling
Ion USB turntable
You can only contact the maker of the turntable.
Jan 13, 2013 | ION Audio Vinyl Recording Turntable
I purchased second hand card and use since then but now it's not working.there is no display.one of my friend told me that it has hardware problem.but i could'nt got any servic center in karac
Check your GPU connection see if it is connected properly, if it is, check the GPU itself for any defects (clear up dust cakes if any). You should remember to install the driver of the GPU for it to work properly. If all those don't work, I believe you have a faulty product and you should get it replaced.
Nov 03, 2012 | Computers & Internet
Master Cylinder? HELP!
Hi Jacki, If you are losing brake fluid it must be leaking from somewhere and the places are limited. Fluid can leak from any one of the four wheel brake cylinders, the master cylinder, the ABS pump and valve unit, the master cylinder or cracked or broken metal or flexible brake pipes. Wherever the leakage is, it must be visible and detectable, as the fluid will make the area wet, If you look at each one of the four wheels, I'm sure one will have been marked by the leakage. The ABS / Traction control are separate from the Emergency brake warning light. The latter (E Brake) warns of loss of brake fluid. Whenever you top up it will extinguish, but illuminating again when the fluid has leaked out! The ABS and Traction control warnings will come on when an electronic signal fail to be transmitted and thereby triggering a fault code. These codes will be extinguished when the vehicle is connected to a scanner and the faults are deleted from the vehicle computers memory. You will most likely find that the wheel cylinder which is leaking has contaminated the pick up sensor which sends the signal to the ABS / Traction system. It will likely need removing, cleaning and then refitting. I am very sure that if you take a flashlight and lay down, even without crawling under the vehicle, you can identify where the leakage is, and point it out to those experts who it would seem have been misleading you. I doubt the leakage will be on the master cylinder, as having two unrelated faults would seem to be stretching coincidence a little far. (But I may be wrong and two problems may have come separately together! I believe the two are related to one wheel cylinder which has contaminated a sensors, The leakage is the most serious problem, as it can leave you without brakes! have that seen to very urgently! In fact NOW!!!! Regards John
Feb 22, 2012 | 2007 Chevrolet Malibu
It takes about 30 seconds or longer to switch stations. I just purchased it last week. Do not have the manual
If you purchased it last week, does that mean that it's under warranty? If so, contact the shop, they will probable provide you with a new one, cause I've never ever heard of a TV set that takes 30 seconds to switch stations. Ever :-'
Sep 01, 2011 | Westinghouse LTV-46w1 HD 46 in. LCD...
I doubt you can help me. I've moved into a flat with a Master Lock Select Access outside the front door. [5401D) I have the instructions but there is no record of the combination, and stupidly I've...
Unless the last occupant registered your Master Lock 5401d combination at Masterlockvault.com and can assist you to recover the combination, then you can only try every possible combination.
Masterlock themselves will not assist you as you are not the registered purchaser.
Jul 27, 2011 | Master Lock 5400d: Portable Select Access...
I have a 200 heritage softail classic the brake light stays on and i dissconnected the pressure switgh for the foot brake and the light stays on. So I guess it's the hand brake switch that is shot. If...
If you disconnected the pressure switch for the rear brake and the light is still on, your deduction of a bad front brake light switch is right on. There is nothing else on the bike that would make the rear brake light come on. If you've moved handlebar switch housing or the master cylinder, make sure that they are positioned snugl against each other. Additonally, I've been reading where wear in the lever and pivot pin combine to make the switch not work. Replacing the lever and pivot pin may resolve the problem. To test, move the front master cylinder away from the switch housing and manually operate the switch to see if the switch is or is not working correctly.
Good Luck
Steve
Jul 06, 2011 | 2000 Harley Davidson FLSTC Heritage...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
