Question about LG LAN240HSV2-LAU240HSV2 24000 BTU 20 SEER Art Cool Ductless Heat Pump Air Conditioner
Room temp 78 degrees with unit setting at 68 degrees. The unit is running (i.e. compressor) but unit not pumping out cold air. To be specific the unit is pushing out cool air just not cold with such a difference in room temp and temp setting. Any suggestions other than having an HVAC service contractor out.
    New Friend:
  • 4 Answers
Sounds like it could be low on freon I believe these units have about 1.5 pounds of freon in them and are critical in not undercharging or overcharging them if it is a freon 410 ac unit the pressures should be about 135 and both lines cold if is low on freon a service tec will need to be called to try to repair the leak if possiable
Posted on Jul 21, 2013
  • 400 Answers
SOURCE: LG Room Air Conditioner Model
I would say that your return air sensor is faulty or not positioned correctly. Check sensor
Posted on Mar 05, 2009
boysor2933
  • 293 Answers
SOURCE: LG LWHD8000RY6 Air Conditioner Not Cooling Room
Remove the front cover of the unit to expose the cooling coil. Put the unit on and observe if there will be formation of frost (ice) on the coil. If there's frost formation, the common cause is dirty cooling coil. Have it cleaned using an alkali base coil cleaner. If the coil is clean, then the problem is the fan motor. It might be turning slow due to copper loss. Have it replaced.
Posted on May 29, 2009
SOURCE: LG 10,000 btu air conditioner
let me knkow what he says i have the same problem
Posted on Jun 29, 2009
reddyanantha
  • 205 Answers
SOURCE: LG 24000btu not blowing cold air. Fan runs but i
please check the temperature sensor this will make the compressor for running and stopping and also check the compressor if its in warranty period please call the service technician to check these and replace if necessary.
Posted on Sep 04, 2009
SOURCE: my lg wall unit (LWHD1009R) 10,000 btu the
my window ac 1.5ton cut off with a **** at 28 deg temp with in 3 minute .room temp is 31 deg. ac is 2years old and i bring in good working condition from my brother. it was kept idle for 1 year
Posted on May 09, 2010
Portable A/C: Compressor runs intermittently and doesn't cool room
Your issue sounds like either a bad "pressure switch" or that the unit is low on "Freon." Either of these problems will cause the compressor to start and run shortly then compressor cuts off, then and repeats itself.
From your description It really does Not seem to be a "bad board in that unit" because the compressor is starting up, even though the compressor is not staying on long enough to cool said area.
Aug 15, 2016 | Heating & Cooling
I have my brand new frigidaire window ac unit set at 60 degrees Fahrenheit, so why does it only cool and keep the room at 65 to 68 degrees Fahrenheit?
if you have it set at 60 F and it is working at 65 to 68 F then that would be about right
as the air is cooled the cold air falls to the floor and out under the door, open window or anywhere else it can escape
the unit has to be at 80% room height so if it is set in a window then when the cold air gets up to the thermostat or ac level in the window then it will stop cooling
So if the ac unit is say 4ft from the floor and the ceiling height is 8 ft then the ac will only cool the bottom 4 ft
cold air does not rise but falls down
if you are using a ceiling fan then the cold air is stirred up and the 65F sounds about right
remember that the setting temp ( what you set it at) is the lowest temp that it will go down to before it stops cooling and if that is not reached it will keep working to attain that temp and if the room is too big, air leaks under door . around the fit in the window , no insulated walls , hot exterior wall,etc then maybe 65 F is the best you will get
May 09, 2016 | Frigidaire Heating & Cooling
What does it mean when the aux is flashing on my thermostat?
I assume that you have a heat pump system. If this is the case, the outside temperature is probably lower than the heat pump is sized for and it is using the auxiliary heating system to keep up. The auxiliary heating system usually is an electric coil in the heat pump unit which supplements the heat being produced by the heat pump. This is normal operations and does not indicate a problem with the heat pump, it is just really cold outside. If it is not colder than usual outside, there may be a problem with the heat pump and you should call a heating contractor to check it out.
Jan 10, 2015 | Emerson 1F89EZ-0251 Blue 2" Thermostat,...
I don't know a good setting on a robertshaw 9420 thermostat, for really cold,and fast air condition.
Well Brian, an air conditioner creates the same temperature drop across the evaporator at any thermostat setpoint, so there is no setting that will get it really cold really fast. If your return air is 88 degrees (in a hot house where the system has been off) the supply air temp is going to be near 68 degrees..... as the a/c runs, the air changes within the structure cause a reduction in the average return air temperature and slowly drops the return to 87, then 86 then 85 etc, etc and the corresponding supply air temp continues to drop from 68 to 67 to 66 to 65 etc etc. Eventually the supply air temp after the appropriate 'air changes' within the structure will drop to 55 degrees and possibly even lower to satisfy the average room temp at 75, 74, 73 etc. to a point.
There are SOME newer a/cs that have two speed compressors that may effect the supply air temperature drop under differing load conditions, but thats a different ball of wax.
So, if you want it cold quickly you are out of luck, just leave the t-stat set at 70 degrees and pay the electric bill when it comes in.....
Dec 25, 2014 | Heating & Cooling
Temp setting way off kenmore 580
Remove the window unit and dissasemble,and clean it out,careful not to bend the fins on the condense and evaporator,but clean them out,and the inside of the unit also,then see what happens,if the problem persist,then find the probe on the evaporator and move it away from the evaporator until the compressor stays on longer.
May 27, 2010 | Kenmore Single Room Air Conditioner
I have a westinghouse window unit and I think it has heat strips for the heat. How do I tell if it is a true heat pump or if it has heat strips and how do I get to the Heat strips in the unit to check.
If it is a heat pump, the compressor will be running both in cool mode and in normal heat mode.
Confirm the current indoor temperature. Turn the thermostat up one degree at a time until it comes on. This will typically be 1 to 4 degrees increase. As soon as it comes on stop increasing the temp.
If the compressor is running, it is a heat pump.
Check the temperature coming our of the vents at that time. You should have 30 to 60 degrees increase from the air temp going into the unit and the conditioned air temp coming out.
Then turn the T-stat up another 10 degrees. If the temp coming out of the vents increases by 20 degrees or more. the strips are on.
The strips operate in three situations.
1) the system is set to emergency heat
2) The heat pump cannot keep up with the demand for heat. (because its too cold outside, the desired temp setting is greater than 4 to 8 degrees above the room temp, or the HP is malfunctioning.)
3) The HP is in defrost mode
You could also take the panels off the unit and look for a reversing valve, but unless you know what you are looking for you will not recognise it.
Oct 12, 2009 | Heating & Cooling
Samsung 8000 btu window air conditioner
Air conditioners rely on a difference in pressure between the "high side" and "low side" in order to perform. Of course, a/c's are designed to work in the heat. Having a cooler outdoor temp of 70 degrees probably is not sufficient to maintain adequate head pressure and will result in reduced cooling capacity. Also, since it was 68 in the morning in the room, it is possible that the indoor coil began to freeze up. Basically, you have a cold coil that you keep warm by moving air over it. If the air doesn't have enough specific heat (what your thermometer measures) it can allow the coil to get colder than 32 degrees and the condensate from all of your humidity will begin to freeze on the coil. My recommendation would be to check the a/c on a day that is 80+ degrees. If you have an avarage indoor temp of 70 degrees you should be able to look for the air coming out to be approximately 20-25 degrees colder than the air being sucked in.
Jun 10, 2008 | Heating & Cooling
Heater!!!
I am experiencing a similar problem with my Mitsubishi slimline MSH09TW unit; about 4 years old; It use to give us very hot air now it is giving some what hot air; northeastern USA current temperature about 15F. You think frigid weather in Cranbury NJ could be responsible or some thing else is going on. Please help me if you have some time and knowledge about Mitsubishi heat pumps. Sincerely, DSS
Oct 31, 2006 | Mitsubishi MS12TN Air Conditioner
LG LAN240HSV2-LAU240HSV2 24000 BTU 20 SEER Art Cool Ductless Heat Pump Air Conditioner Logo
202 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
