Vaillant ecotec plus boiler fault f63 - Computers & Internet
2 Suggested Answers
  • 55 Answers
SOURCE: lost my user manual for the vaillant boiler ecotec plus 824 R1
try to enter here all informations and you can find the manual: http://instructions-manuals.com/search.php?cmarque=VALLIANT%20&modele=ECOTEC%20PLUS%20824
Posted on Oct 27, 2009
Got a f.75 on boiler have to put pressure up to 2.0 bar before it starts
I take it this is a Vaillant EcoTec boiler? If your having to pressurise to 2.0 before the F75 goes, there's a strong probability there's a problem with the water pressure sensor. These can sometimes just have dirt/sludge in them, and can be cleaned, however a lot of the time they just need to be replaced. F75 can also mean there's a circulation problem through the boiler, and you will get the same fault code. If you have the old rubber hoses on the flow and return pipes, these can be prone to blocking/restricting and Vaillant have actually modified this part whereby by the pipes are solid copper.
Dec 04, 2012 | KDS Valiant 6380iPTD-01 Notebook
New Vaillant 360 eco plus boiler, takes almost 3/4s an hour for rads to come up to a decent temp. Hot water is fine. Called out install Engineer who is an excellent tradesman but he says everything
We have just had our old system boiler replaced with a vaillant ecotec plus 837 and sounds like a similar working operation to ours. At first I was a little concerned,but I was told by our installer that he was told by vaillant that these very latest boilers size the system on start up for about 10 mins, then take temperature to target flow which you set boiler at. So even by setting target flow temperature very high you still get the initial sizing cycle, which ours was about 30-35c temp. These boilers seem to run biased for efficiency as after a while they modulate the boiler burner down and the radiators run more on the side of warm than really hot like the old type boilers. You also get better efficiency as at lower temperature the boiler condenses better. You will also find you get a more constant temperature in your home rather than over shoots. I was concerned at first, shame there was no info/explanation in user manual as people do need to know that this is normal operation. We are used to ours now, took a month and by the way these boilers can make a creaking noise but was told this normal expansion/ contraction but annoying when sited in bedroom cupboard. Best of luck!
Oct 27, 2012 | Water Heaters
A have a vaillant ecotec boiler and when it fires up the fan is very noisy is this right
most likely no. there might be a obstruction in the blades, dirty filter, the motor might have a bad berring , the fan blades might have bent and now are touching the housing prob should call a trained tech boilers aint no joke
Aug 06, 2011 | Heating & Cooling
F22 error/ low pressure
F.22 Dry fire Too little water in the appliance, water pressure sensor defective,
cable to pump or water sensor defective, pump blocked or defective,
pump output too low
May 11, 2010 | Heating & Cooling
Vaillant ecotech plus f75 code not firing up
F75 is telling you that the pcb has not recognised the slight increase in pressure that is created when the pump kicks in. I hate to say this, but it is a known issue with the ecotec plus range. Usually cured by replacing the sensor (old ones orange) in the bottom left of the boiler. New versions are now black. Can also be caused by muck in the sensor due to poor flushing when the system was installed.
Feb 26, 2010 | KDS Valiant 6380iPTD-01 Notebook
Lost my user manual for the vaillant boiler ecotec plus 824 R1
Oct 27, 2009 | KDS Valiant 6380iPTD-01 Notebook
My parents have a Vaillant Ecotec 831 boiler. Has continually broken down ever since it was fitted nearly 2 years ago. The guy who fitted it keeps coming out and it works for a few days then packs in...
Get vaillant to look at it. It could be installation fault. Their advise is impartial and they can advise if boiler can be repaired.
devinder
Corgi engineer
Oct 14, 2008 | Heating & Cooling
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
