Question about Garden
Toro 6.75 149cc pull cord has to be pulled 6-8 times to start a cold engine.After that not a problem.How can I improve this?
  • 2,359 Answers
Winter methanol fuel is problematic for small engine.
Add small amount of methanol will help.
Check the manufacture spec for the gap and re-gap it to the min. gap to get the strongest spark.
Posted on Jan 13, 2014
SOURCE: the pull cord has no tension to make the engine start
It seems you do not have enough spring tension. Remove the starter housing and grab the slack rope and wind the pulley two or three times in the tension direction until the slack gets pulled into the pulley by the spring. Hope this helps. Donnyb60
Posted on Mar 19, 2009
wadembly
  • 462 Answers
SOURCE: Mower won't keep running after 10-15 seconds.
check the air filter & also spray some carb.clean in the carb see if that helps
Posted on Jun 06, 2009
SOURCE: toro self propelled 22 inch recycler lawn mower start pull cord is "stuck"
Casey,
My son just bought a new Toro self propelled 22" recycler and has had problems on two different occasions. The mower just bogs down to a stop and when he tried to pull the starter cord, it was very VERY difficult to pull. At first I thought the engine had seized up for some reason (no oil?), but we found the problem.
First, disconnect the spark plug wire from the spark plug (to avoid the engine starting); tip the mower on its side and check very carefully the pulley and transmission belt. In his case, a piece of wood had gotten stuck between the belt and the pulley. Removing it fixed the problem (now he mows a little higher so as not to get so close to any debris). (We did have one further problem after that - the engine would not start - not even fire. After pulling and pulling, checking for gas, and checking that the air filter was cleean, we decided to check if the cylinder was flooded - we removed the spark plug, wiped and dried if off, and replaced it. It started right away.)
This belt 'n pulley arrangement isn't the best idea, if you ask me.
Good luck.
Posted on Jun 08, 2009
mowerman1857
  • 389 Answers
SOURCE: I have a broken pull cord and cannot figure out how to fix it.
Easiest way is to remove the complete blower housing assembly, remove the old rope, then twist the rope pulley around and around until the spring is tight, ease it back until the hole in the pulley for the rope lines up with the hole in the recoil housing and stick a small screwdriver through the pulley and the housing to hold tension on the spring. Next, take your new rope and feed it first through the recoil housing, then through the hole in the pulley, tie a good solid knot right at the end of the rope and pull it back out until you feel it pulling on the pulley. Now holding tension on the rope, remove the screwdriver and let the spring tension slowly pull the rope back into the the pulley until it is full, pull it back out about a half turn on the pulley and tie a slip knot against the outside of the housing to hold it in place and reassemble everything. Hook the end of your rope through the rope guide on your handle if it has one, slip the handle on and tie a knot to hold it. Cut off the excess, pop out the slip knot and it will pull up tight and you are ready to go
Posted on Sep 16, 2009
  • 25 Answers
SOURCE: Toro powerlite 98cc engine...unit will start by
I believe your carburetor needs to be rebuilt or replaced. The carb has thin rubber diaphragms that meter in the fuel to combustion chamber. If the diaphragms get hard (from gas sitting in carburetor for extended time or from hot weather) they won't allow enough fuel in to keep up with the demand. if you need parts email desertairrepair@aol.com.
Posted on Feb 12, 2010
I have a Toro 8526 snowblower. Pull cord drags in cold weather- I have to use electric start-once started and warmed up, pull cord works fine-is this condensation you think?
Sounds like your recoil starter is dry. when it's cold it makes it a lot worse. I would shoot a little oil into the recoil. Even try a shot of WD40 and if that works use an oil can to shoot oil into all the moving parts
Dec 22, 2016 | Garden
We have a toro model 20031. The battery doesn't work and my husband disconnected all battery connections. Should the engine still start with the pull cord?
leave all the battery connections connected, then prime the carb, and pull to start, i have a quad with an electric start and a pull start, it will not start with the pull cord if the battery is not connected.
Dec 14, 2014 | Toro Garden
I have this Toro trimmer/edger.Can't pull the starter cord
you must take apart the cord recoil and rewind the pull string,inspect string make sure its the same thickness through out if not replace it, not too hard i believe you can do it.
Apr 26, 2010 | Troy Bilt Tb70ss Gas Trimmer
I have a Toro electric start 22'' inch lawmnower Model No. 20018 with a Tecumseh LEV 90-120 engine. The mower may be started with the electric start or manually with the cord. The battery was in need of...
It sounds like the starter drive may be jammed. It should not be engaged unless you are using the starter motor. Take the spark plug wire off, put on heavy leather gloves, and try turning the blade by hand to dislodge the starter drive. If it does dislodge, plug the spark plug wire back up and try the pull start again.
Aug 29, 2009 | Toro Lawn Mower With Toro Power Tools
Motor turns, but cord rips out of my hands when starting
sounds like timing issue check the flywheel key and see if it sheared. could be the valves also but i doubt it.
Jul 27, 2009 | Toro Lawn Mower With Toro Power Tools
Toro 6.5 lawnmower wont start when you pull the cord it comes out about an inch then it locks where you cant pull it no more
Remove the plug then try and see if you can pull the cord any futher.If not you may have to dismantle the pull start and check the clips are not jamming.
Jul 06, 2009 | Toro Lawn Mower With Toro Power Tools
Toro GT5 lawnmower - the pull cord (to start the engine) only comes out about 3 inches - I'm afraid to pull to hard for fear of breaking the line.
First - remove spark plug and squirt 3mls of engine oil in there - replace spark plug and leave overnight.
Try pulling that start handle !
Two things may happen - it snaps or - it turns over.
If it turns over - prime fuel and start in choke setting.
If the cord snaps - undo the pull start block - and take it to a lawnmower spares depot, and buy some more cord. It's quite cheap.
Get the length right so you don't have too much.
Next - the engine is probably seized - so needs freeing up. You may be able to do this with the new cord, Otherwise - take the head off the cylinder and tap the piston down with a wooden drift while turning the crank.
Use a non-setting gasket sealant like hematite red to re-use the old gasket. Lawnmowers are quite resilient.
Jun 29, 2009 | Toro Lawn Mower With Toro Power Tools
Pull Start Locks
Disassemble and, re-engage the pull cord locking pawl spring
May 20, 2009 | Toro Lawn Mower With Toro Power Tools
Cannot pull the cord more than 6 inches to start Toro lawn mower.
Hi Patti, If you can not pull the cord more that what you said, try removing the spark plug and see if that makes a difference, if not, leave the spark plug out to prevent accidental starting, raise up the front of the mower and see if you can turn the blade if not...it only gets worse from there. If you can't turn the blade from under the mower, the engine is more that likely seized up, sorry
Apr 25, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
101 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
