Question about Hunter Fan Company 7-day programmable thermostat
Thermostat Our thermostat reads error 104. What does that mean?
Hs error code what does it mean?
Water Temperature Sensing Error
A) Inlet water temperature sensor is reporting a temperature in excess of 104 degrees. Normal operation resumes 2 minutes after inlet water temperature sensor reports temperatures of 104 degrees or less. This error functions in both normal and remote thermostat modes.
or
B) Inlet water temperature sensor is reporting a temperature change at a rate faster than 6 degrees in 60 seconds, indicating a potentially damaging low water flow condition. Normal operation resumes when temperatures stabilize. If this condition is detected 3 times, the heater will lock-out until the electrical power is cycled off and back on.
Jun 19, 2014 | Hayward H400FDN Low NOx Natural Gas Pool...
What is error 104
Try doing a Google search for the brand and model of the fan and then for the error code.
Aug 09, 2012 | Dryers
Denon error 104
error 104 is unable to actuate focus. Which means the laser lens assembly is most likely defective
Feb 04, 2010 | Denon DN-C680 CD Player
My honewell th8320 is reading error 126 or 626
Look in the manual that came with the thermostat it will give you the problem for each code.
Nov 11, 2009 | Honeywell Electronic Programmable...
What does OH mean on a hot tub control panel
OH stands for overheat. This normally occurs when the water temperature of the spa reaches over the safe temp of 104 degrees, as a result of a failure in the thermostat control. But if you receive this error and the water is not scorching, (a fairly common occruance) then the temp sensors have likely failed. Replacing the temp sensors will most likely rectify the problem. If the problem persists, then the circuit board is bad.
Oct 31, 2009 | Coleman (5040B750) Patio Heater
Aftersigning in my mail is not opening and can't read mail ...
do u mean in www.hotmail.com or in outllok 2003???
If it is happent on hotmail just go with right click on IE and go properties -advanced and restore default then go PROGRAMS and RESET WEB SETTINGS!
UPDRAGE AXTIVEX AND JAVA
Oct 27, 2007 | Computers & Internet
Hunter Fan Company 7-day programmable thermostat Logo
63 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
