Question about Toro Garden
Brand new carb also
SOURCE: Troy Bilt Lawn Mower pull Cord broken
there should be four bolts holding the cover on that houses the pull cord assembly take the bolts out look inside you should see the rest of the broken cord at the other end there is a spool that the cord rolls up in to pull the cord until it stops the other end of the cord is a not in the cord pull on the knot the broken peice should come out turn the spool 2 times in the direction that is against the pressre while holding the spool in place feed the new cord in through the whole that you pulled the broken cord out of then tie the cord in a knot wind the rest of the cord up then feed the other end of the cord through the new pull handle tie the cord in a knot put the housing back on
Posted on Mar 21, 2009
SOURCE: MTD Yardman push mower runs fine for awhile then cuts off.
Try buying a new plug first but if it continues then I would say that there is debris in the carb.
Posted on May 03, 2009
SOURCE: I have a briggs and stratton lawn mower ad the pull-cord is stuck
make sure nothing is jammed around the blades...if thats ok, remove the pull cord housing and try and spin the engine. if it doesnt turn, the motor is locked up and needs repaired
Posted on Jul 10, 2009
SOURCE: Toro Recycler 6.5HP recoil start cord pulls hard & snaps back in
This sounds like you have bent the shaft. This happens when you run over something hard. Hope this will help.
Posted on Jul 25, 2009
SOURCE: My riding mower will start by pull cord but not from ignition
Jump the solinoid with a screw driver, it the engine starts, replace the solenoid.
Posted on Apr 23, 2010
Apr 09, 2016 | Garden
Jul 21, 2013 | Garden
May 09, 2013 | Husqvarna Garden
Feb 09, 2011 | Boating
Nov 09, 2009 | Homelite Leaf Vac Attack
Oct 30, 2009 | Husqvarna Backpack Blower 155 145 Starter...
Jul 05, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Mar 12, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Jun 24, 2008 | Ryobi 15" Electric Factory Reconditioned...
Apr 24, 2018 | Toro Garden
Apr 23, 2018 | Toro Garden
24 people viewed this question
