Question about LG WH12LS30 12X SATA BLURAy BURNER BLACK WSOFTWARE LIGHTSCRIBE BLUK Burner
Reset the flag opc failed
Will not burn
I just install a new opc belt in a xante colourlaser 1200 printer, it still say install opc belt.
You probably need to go into the menu structure and find the resets menu. It could be under machine info or maintenance. When you have found the reset menu or parts life, you should be able to reset the OPC Belt.
Jan 11, 2015 | Xante Office Equipment & Supplies
My opc led burns when i turn on the tv
You can leave it on and enjoy the tv self adjustment feature or turn it off by pressing menu. Navigating down to opc and pressing enter. Navigating to off. Pressing enter and then pressing menu.
Mar 15, 2011 | Sharp Televison & Video
How do I reset the OPC belt on MFC-9420CN using the menu?
hl-2700" OPC Reset
press GO and "+" at same time
press "+" until OPC BELT appears
press "SET"
that will reset the counter on the expensive OPC.
Since the "MFC-9420CN" is build on the same chassis and engine, the "OPC belt reset for the 9420CN" is as follows:
Press 1 and 7 at the same time
Press 1 to reset the life counter.
Oct 20, 2010 | Brother MFC-9420CN All-In-One Laser...
Reset replace OPC belt
Here's the link on how to replace the Photodeveloper Cartridge on the Lexmark X500/X502: http://bit.ly/bzQQtH.
Here's the link on how to reset the photodeveloper (OPC) count on the X500/X502: http://bit.ly/9BxHqz.
Hope this helps.
May 25, 2010 | Lexmark X502N All-In-One Laser Printer
Machine is asking for U28 replace black drums - I replaced black tone cartridge, the opc Drum Unit and the Toner Waste Container and the machine is still inoperative
on the back of the drum unit is a little "flag" that activates a sensor when you insert the drum to reset the drum counter. if the drum is replaced incorrectly or is from a poor supplier then the flag will be in the wrong position and when inserted will not reset the counter. try another black drum to reset the counter, do not discard the drum as the technician that visits in future can reset the flag for you.
Apr 17, 2010 | Panasonic DP-C263 Copier
OPC belt has 78% left -cant rid the problem
Look at the OPC belt edges, there's a shiny spot that passes thru a sensor, a can of air should blow out the sensor, carefully! When the sensor can't see the timing spot you get that error. You may have to replace the OPC since companies are imbedding a chip that tells the machine when they're used up.
Sep 01, 2009 | Brother MFC-9420CN All-In-One Laser...
OPC belt is replaced and has 100% life but the OPC
make sure all components are properly seated. also try turning the printer off and waiting a few minutes and turn back on.
Aug 19, 2009 | Brother MFC-9420CN All-In-One Laser...
Blinking power and opc leds on front of unit
From the information you have provided failed capacitors in the power supply is likely causing the problem. The safety circuitry shuts the TV set down when it detects a problem. This model of TV has over 2,000 parts which include millions of transistors inside the integrated circuits. The capacitors will change value, leak and become defective. Resistors will change value and burn. Integrated circuits and transistors can go bad. This can cause other components to become defective, which can have a domino effect and cause other parts to fail. Replacing one defective part may make the TV operate for a short time but the part will fail again since if the parts that caused the failure to begin with are not replaced. The only way to know for sure what is causing the problem, which parts that are no longer within factory specs and for proper repair all the electronics must be diagnosed by someone with the correct electronic test equipment and the skills to use the test equipment. The repair should cost about $250 if carried into a TV repair shop. A small TV repair shop will often charge less than a large repair facility.
Jun 04, 2009 | Philips 50PFP5332D 50 in. Plasma...
OPC Belt needs replacing
Try pressing 1 and 7 at the same time
The LCD will show "OPC belt 1. Reset 2. Exit
Select 1 to reset the life counter.
This is supposed to be done when replacing the drum unit...but I've found that I can get 1.5 to 2 lifespans from a single unit.
Jan 31, 2009 | Brother MFC-9420CN All-In-One Laser...
NO OPC BELT on MFC-9420cn
The opc sensor is not sensing the belt. Open the front cover and remove all the toner trays. You will see the green OPC and the sensor is located in the left upper corner. Also open the top cover and remove the OPC. Clean the sensor with a soft bristle brush. Also make sure the OPC left side is free of toner deposits. This may incorrectly trigger the OPC position sensor. Hope this helps.
Jan 14, 2009 | Brother MFC-9420CN All-In-One Laser...
LG WH12LS30 12X SATA BLURAy BURNER BLACK WSOFTWARE LIGHTSCRIBE BLUK Burner Logo
74 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
