Wont turn wheels to left
This is a messy thing to trouble shoot. You should take the return hose from the input of the pump off. You can do this at the pump or at the wheels. Then you need to run it and catch all the PS fluid that comes out. Turn the wheels to the left and the right to get all the fluid out. Replace the fluid. You can flush it out with diesel if you want. IF that does not help then you have to take the power assist off the unit and have it disassembled to see if it is a seal or something sticking in the unit.
SOURCE: The left wheel on my self propelling John Deere
stripped gear or stripped wheel on drive axle, please rate help, thanks
SOURCE: need diagram for installing mower belt for blades
Hey if its a 42" cutter deck this should be the one:
http://i876.photobucket.com/albums/ab330/Brado83/JDDeck.jpg
It may be a 48" in that case it would be different
Brad:)
SOURCE: blade belt diagram for John Deere LX178 Riding
Remember the belt rule, V of the belt goes in V pulleys.Flat pulleys that are stationary or move get the back of the belt. You can figure it out. Its not rocket science. Remember at some point there has to be a tensioner,usually gets the back of the belt if its a flat pulley. U may have to remove the spring and then reattach the spring after the belt is routed.
get down there and look to see if all the steering linkages are still connected together.
