Question about Acer Aspire 5100-5033 Notebook
The power somes on,but nothing else comes on
The screen wont boot up
  • hitash32 Sep 01, 2008
    i have an acer aspire 5100, when i turn it on the monitor will not power up, but when plugged in to an external monitor the damn thing works fine. the fans come on and everything else works. i can sometimes get it to flash on briefly by pressing fn f6 but the monitor will flick off immeadiatly after. is the problem the inverter or somthing else? and if so what?
  • 43 Answers
Yes i would say the screen has gone out.go with that and see if it works try another monitior first.good luck.
Posted on Jul 11, 2008
  • 60 Answers
Okay, now ignore everything you just read. Plug the laptop upto an external LCD or monitor and turn it on. Does it come on? if it does then its quite likely that one of 3 things has gone, Your CCFL (backlight), the inverter board that powers it or the the screen as a whole. If you look at it in good light is there a faint background? Also are all of your other system lights coming on and the fans spinning?
Posted on Aug 30, 2007
  • 64 Answers
If the screen is blank remove the battery and the power cord. Wait a minute and plug in the power cord and try it. If it works you can put the battery back in. If it still fails it's probably a bad motherboard.
Posted on Aug 29, 2007
2 Suggested Answers
parrotheadpc
  • 2600 Answers
SOURCE: It wont power on. The power light comes on but
Try these troubleshooting tips, they may help.
Power is on, but nobody is home….
This is a common problem I see a lot and there can be multiple problems here. First off, if you have lost the backlight on the LCD, you might not be able to see what is on the screen….LCD makers are making the panels very dark and if the light has failed it is very difficult to see what may be on the screen. Try shining a flashlight on the screen near the bottom and see if you can make out anything on it.
If not, attach the laptop to another monitor using the video output, you may have to toggle through the video outputs on the laptop by using the Fn key + one of the “F” keys….sometimes it is F4. If you see your desktop on the external monitor than your screen may have died but your video card is still good. In this case, change out the screen and inverter.
If you still can’t manage to see a display, then the other issues are a virus or malware that has changed the resolution to one the video card cannot process, in which case, the hard drive would have to be removed, attached to another computer and scanned to remove the bugs.
The video processor or video card has failed on the motherboard. If the computer has not been cleaned and has run hot, the processor can suffer significant damage that can result in this condition.
Work on simple first, until you get to complicated. In the end, worst case scenario is the main board has to be replaced.
Posted on Nov 07, 2009
Presario v2000 wont boot it powers on then screen says press F1 or F10 but can go no farhter
Sounds like it is not seeing a bootable device, maybe bad hard drive, could be a bad setting in bios. Click here for tech support
Mar 26, 2013 | HP Compaq Presario V2000 Notebook
Possible hard drive failure
Does the splash screen come up? Most of the time if it is your hard drive the ACER splash screen will come up and then a Hard disk 0 error after that. If nothing appears on the screen then you have a bigger issue.
Is there any noise at all (Fan, hard drive spinning)? If so try hooking it to a external monitor to see if there is any movement. You might have a problem with your LCD.
Apr 20, 2010 | Acer Aspire One PC Notebook
Had trouble booting the computer over time. Sometimes power light would come on and nothing else. By unplugging, waiting 15sec it would power up. Over time this stopped working. Eventually power light...
Time to look for a new computer. That and take out your hard drive to copy your files over.
Sounds like motherboard problem. Probably not worth repair.
I've got an HP desktop with similar problems. It turned on one day just fine. The next day not. I don't even get the boot up screens. Disconnecting Hard Drive and CD/DVD components do not help. I should at least get some BIOS POST beeps and a Hard Drive Not Found or such. I do not. On occassion it will boot to a blank screen with white cursor in upper left. Most the time no screen at all. On rare occassion it comes right on and boots Windows. I guess it could be the power switch ... but I doubt that.
Nov 22, 2009 | E-Machines eMachines Desktop PC
Wont boot no bios screen nothing
Check your memory card. Reseat or clean its edge connector with soft eraser.Do this after you shut it down properly , battery disconnected, and no any other power source is connected.
That is the first thing to suspect. Or try it also with a spare good ram card.
May 09, 2009 | Everex StepNote XT5000T Notebook
My toshiba 2455-s305 wont boot up
If you are familiar with your laptop, i.e. the locations of hard drive, try to take it out of the its bay and put it back again. Also, if you can have someone check your battery packs, because from my experience with this laptop, when the battery packs is not charging well, i got some booting up problems.
Mar 19, 2009 | Toshiba Satellite 2455-S305 Notebook
Computer wont Boot up normaly
first romove the power cable. then remove the ram, then remove the agp or pci express if you have. Then adds this thing together. add power cable.
Start the computer.
Jan 21, 2009 | Gigabyte GA-8I848P-G Motherboard
Wont send power to screen or keypad/mouse
Try Reseating the RAM/ try with another working RAM. Before this remove all peripherals like HDD, CD-ROMs, Floppy Drives. Check with another Power Supply,
Jun 21, 2008 | Intel Motherboard
NO POWER!!!HELP
Is the voltage meter directly on the Battery?? What model Dell is it?? I have found that on the D800 models for some reason the connection from the power button to the Motherboard comes loose. You need to remove the Keyboard cover to check this.
Jun 06, 2008 | Compaq Evo N610C Notebook
Screen wont show boot screen
fo to bios options by pressing f2 or del soon the power button is released. thre u can find an option to enable silent boot . turn it on
Dec 08, 2007 | Dell Latitude C400 Notebook
Acer Aspire 5100-5033 Notebook Logo
179 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
