How do I replace a lid switch for a Whirlpool
How do I replace a lid switch for a Whirlpool washer/dryer combo. model #LTE6234DQ4. My machine filled with water then stopped. I'm pretty sure it is the lid switch, which I found, but I have no clue how to replace. Here's a picture from when I unscrewed the lid switch.
4 Suggested Answers
JR JR
  • 116 Answers
SOURCE: washer fills with water, then stops
OBVIOUS REPL LID SWITCH AND SHOULD SOLVE YOURE PROBLEM 100 % MAYBE INSTALLED IN CORRECTLY,, TAKE A LOOK AT YOUR LID MAKE SURE BUMBER IS ON AND NOT TWIKED
Posted on Nov 30, 2008
SOURCE: Maytag washer filled with water then stopped working.
You can check the lid switches (they are paired) the following way:
1) take off the front and top washer housing panels.
2) look for the wire bundle coming off the lid switch and find the plastic pull apart connector.
3) undo the connector.
4) take an Ohm meter and check the resistance when the lid is closed: a) orange and black wires should complete a circuit, orange and pink should also complete a cicruit, all other pairs shold be "open".
5) check the resistance when the lid is open: orange and white should make a circuit, but no other pairs.
6) replace the defective switch, or replace the complete unit.
7) check the 250V 1A fuse in the left front, replace it if it has blown.
Good luck.
Posted on Dec 15, 2009
  • 207 Answers
SOURCE: My washer fills and doesn't
The fill switch is bad. That's the only "safety" on the washer that will shut the water off after reaching desired depth. To test it, run your machine on the various water levels. For example, start out on the low setting. If the water doesn't shut off after the tub is half full, then it's the fill switch inside the unit next to the tub.
Posted on Sep 13, 2011
Testimonial: "Thanks for the quick response. I will replace it tomorrow and let you know if it works."
Maytag lse7806ace
open and close the lid,if you don't hear a clicking sound you just have a bad lid switch,you have an older machine and it has a cherry switch in it,go here and look at part number 5
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Washer-dryer-combo-Parts/Model-LSE7806ACE/3048/0152000/M0601018/00016?blt=06&prst=0&shdMod=LSE7806ACE
part number 208823,all it is is a safety so the washer can't run with the lid open so it will fill and then stop because the switch is bad.
Jun 06, 2013 | Washing Machines
Overflowing Washing Machine, water does not stop filling, overflows to floor. This is a Whirlpool Thin Twin Stackable
sounds like you have a bad water level pressure switch part 3362987
http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Washer-dryer-combo-Parts/Model-LTE5243DQ6/1198/0152000/W0604125/00001?blt=06&prst=&shdMod=
go her part number 10 in diagram or there could be something in the hose,the hose could have fallen off or could have a hole in it,i can't find a video with a stack machine but this explains your problem
http://www.youtube.com/watch?v=jzKBUI5D0Vs
Mar 30, 2013 | Whirlpool LTE5243DQ Combination...
Washer stopped at the drain cycle Model LSR8233JQ1
Could be either a bad lid switch or a bad water valve.
Set the timer dial to SPIN and turn the machine on.
If it spins the lid switch is OK. If it does not spin the lid switch must be replaced.
Next,set the timer dial on a wash cycle and set the water temperature knob to COLD water. If it fills,the lid switch is bad. If it does not fill the water valve is bad or the cold screen filter is clogged.
If the COLD does not fill,turn off the cold water faucet. Remove the cold water hose from the machine water valve and check for a clooged screen.
If it does not fill with COLD water and the screen is clear,replace the water valve.
Oct 27, 2009 | Whirlpool LSR5132PQ Top Load Washer
Water won't dump
When you replace the pump, always to remember to makes sure the pump is pushed all the way in so that the shaft has a good grip. Try taking it out and pushing it all the way in. The 4 legs should touch the motor, as you put the 2 little clamps on the top and bottom.
Good luck, I'm pretty sure it's something really basic with the pump :)
Jul 19, 2009 | Whirlpool LTE6234D Top Load Stacked...
Replaced Washer Timer
Next time it stops cheak your lid switch.When it stops do not touch any thing just open lid and find a pen or somthing to push the switch down.If it comes on then you will need a lid switch.If not let us know good luck:)
Mar 30, 2009 | Whirlpool LSB6000PQ Top Load Washer
Water fills the washer during spin cycle
defective timer...a model # should be under the lid...or open dryer door and on front dryer panel right hand corner..onthejob
Jan 16, 2009 | Whirlpool LTE5243D Top Load Stacked...
My whirlpool thin twin filled with water and stopped!:(
Well if it fills then it needs the lid shut to work. So if the lid is shut it hits a lidswitch and if that lid switch is broken then nothing will work washer wise right? As far as the dryer that may be a blown fuse but nothing on the washer could stop it from running cept maybe a bad cord or breaker.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 28, 2008 | Whirlpool LTE5243D Top Load Stacked...
Washing Machines Logo
Top Washing Machines Experts
