Question about Dryers
Honeywell tabel fan model HWF-1600
Tabletop or wall oscilating,with remote and wall bracket. white, has several speed settings......... need wall bracket!!
Cerfer39
  • 709 Answers
SOURCE: wiring ceiling fans to wall switch
Hi Bigelow,
You need two switches.  It sounds like the Electrician set up the junction box for two circuits(Lights and Fans).  i say this because your supply has 4 wires, Red , Black, White and Bare. We may be able to oversome this with one Lutron Switch. Allow me to investigate, and I will be back.
Posted on Oct 29, 2007
burzerko
  • 254 Answers
SOURCE: 1VCF2 Dayton Oscillating Wall Fan
The speed control switch which is what the cord is attached to has gone bad. You can get these from grainger.com for the dayton line of fans.
Hope this helps
Posted on Jun 22, 2008
  • 157 Answers
SOURCE: hampton bay fan, wall mount remote control
Hello burrow31. There maybe a switch located on the fan stating 'remote/manual'. Check your manual. Remove the battiers in your remote and short out the battery contact terminals. Reinstall the battiers, start the fan and after fan has reached set speed press & hold fan speed button for one second. Still no speed change contact the Mgfr. with model & serial #.
Posted on Oct 13, 2008
frolovvl
  • 561 Answers
SOURCE: oscillating bracket broke, need to replace
Please suggest where I can buy a new blade for 16' airworks pedestal oscillating fan?
Thanks... VladF
Email frolovvl@sympatico.ca
Phone (home) 905-891-5741
Phone (cell) 416-471-1326
Posted on Sep 03, 2010
  • 122 Answers
SOURCE: bought a 36" oscillating tower fan model FZ10-9LR
this happen to me one i just went in bought new fan took the good remote out and gave them back the bad one brought it all back and got my money back.good luck
Posted on Aug 05, 2011
Testimonial: "great idea"
We need a wall mount bracket for the Lakewood RR/16WM Oscillating Wall Mount Fan
I'd suggest you contact the manufacturer and see if you can order that one part.
Jun 23, 2014 | Lakewood RR/16WM Oscillating Wall Mount...
Honeywell HY-108 fuse
is imple you must take out the cover and see if the fuse is glass or ceramica unplugged the device from wall. and the same type of fuse, voltage, and amperios, YOU CAN NOT PUT MORE OR LESS ONLY EXACTLY. Otherwise you will have burning.
God bless you
Aug 02, 2012 | Honeywell HY-108 8-Level 32 inch QuietSet...
Hampton Bay model 11420 52 inch fan did not come with any instructions.
If the fan and light assembly are fully assembled, all you've got to do is connect the original wires to their respective(white,black and uncoated copper ground) wires. Then mount your motor/light assembly using the proper supplied harware. Next you just put on the fan blades, connect each one with the three screws to the bracket. Do the same for the other two,three or four blades. and attach them to the motor assembly. P.S. When you are attaching the fan blades, make sure the side that faces down is correctly positioned and that it matches all the rest. If this blad is to be operated using the pull cords you're all set. If the fan is mounted too high up and it is not remote controlled then you'll have to purchase a special three speed wall switch for it. In the latter case you would leave the fan speed on high on the unit itself.
Jul 19, 2009 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Fan with remote won't work with wall switch. I
I just recently purchased a hunter ceiling fan w/light and remote. Had it installed and wall switch would not work, only remote. I contacted Hunter company directly about this problem and I was told that they redesigned their fans with remotes so that only the remote works for turning off power to fan. The person who made that made that BRILLIANT change should be fired. So to those of you who own a newer hunter an product with a remote ne your wall switch will not work tat s te reason why.
Jul 14, 2009 | Hunter Ceiling Fan Light Remote Control
The Hampton Bay Altura Ceiling fan functions only with remote.
I contacted the manufacturer (kingofffans.com) after my Altura fan would run on high speed only and the remote would not control any thing. They said their was a manufacturing defect with a capacitor that affected many of the Altura fans. We are now on a waiting list for a new capacitor and housing, because they did not have enough replacement parts.
Nov 26, 2008 | Hampton Bay 52 In. White Redington...
Hampton bay fan, wall mount remote control
Oct 11, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Wall switch
I had this same problem (sort of) - my daughter lost the remote to our fan and it would not work from the wall switch. What you have to do is go up to where your fan is connected to the ceiling, slide the canopy down, and remove the remote transmitter. Then just rewire the fan normally - white to white, black and blue to black, and the ground wires together. Turn on the power and your fan light should work with the wall switch. You will have to pull the cord for the fan to work.
Jan 07, 2008 | Honeywell HFS641P Stand (Pedestal) Fan
Open Questions:
Dryers Logo
32 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
