Question about Simplicity for Children Baby Gear
How to change battery on simlpicity bassinette
I need to change the battery on the music device and light
  • Roberta McCormick Jul 23, 2013
    There is a device on the bassinette for music, vibration and light that is not working. I am assuming there is a battery somewhere, but may just a motor and I don't have the instruction booklet
Changed battery and it doesn't detect transmitter. Everything else works and the transmitter gets detected by our treadmill, so I know it works.?
Transmitter Battery
The estimated average battery life span of the transmitter is 2500 hours of use. If you suspect that the transmitter battery
has run out, contact your authorized Polar Service Center for a replacement transmitter. Polar recycles used transmitters;;;
Dec 28, 2013 | Polar F6 Wrist Watch
Is the quinny freestyle 4xl able to have a bassinett attachment?
does anyone know where i can purchase a quinny freestyle 4xl stroller cover...not just the rain one i want a waterproof fabric one?
Jul 18, 2012 | Quinny Freestyle 4 Marina Stroller
Bassinett mattress for Graco Pack n Play
You may be lucky with Mamas and Papas, I know that they do make travel cot mattresses, but am unsure if they will make the size you require. I would suggest that you measure the internal dimensions and contact them,
I hope this helps.
Sep 20, 2009 | Baby Gear
How do you put batteries in sooth n amuse
remove it from the side then hold bottom with one hand hold arm of mobile about 3 inches from that bracket n twist it should unlock then pull apart batteries go inside
Mar 21, 2009 | Graco 9445DOH Crib
I need the schews for the bassinnette
Take the piece with the needed screw to Ace Hardware and ask for help.. They are always able to help me.
Mar 15, 2009 | Eddie Bauer Musical Rocking Bassinet...
Instructions for bassinette and valco runabout delux
Not sure if this is the correct model but hopefully it helps.
http://www.valco.com.au/pdf/11_Document.pdf
May 26, 2008 | Valco Runabout Deluxe Jogger
Rocking mechanism doesn't work and can't find replacement parts. There were no instructions included with bassinet.
I have the same problem, the only "function" switches I can locate is the "on/off" switch & volume control for our "rocking Bassinet." Also - no instructions
Feb 10, 2008 | Eddie Bauer Musical Rocking Bassinet...
Baby Gear Logo
51 people viewed this question
Top Simplicity for Children Baby Gear Experts
Dennis Crouse
Joseph Hoffmann
Are you a Simplicity for Children Baby Gear Expert? Answer questions, earn points and help others
