Question about GE "General Electric AEN10AQ 10,000 BTU EnerStar Window Air Conditioner, 3 Speeds, 24 Hour On/Off Delay"
My AC unit just died out of the blue.
Hello. I just recently received a brand new AEN10AQ unit for my home and it was working perfectly yesterday evening. It was working fine since until this morning at around 9:30 AM. The AC just died. No response, no power, and it's still plugged in. I even tried the remote and there's still no response. I believe it may be a blown fuse, but I'm not sure. Anyone willing to help me out?
  • 4 Answers
Sounds more like a bad breaker possiably not getting power to your unit I would check the breaker first
Posted on Jul 21, 2013
4 Suggested Answers
mc1bean
  • 3053 Answers
SOURCE: why won't my lg ductless heat pump regulate the room temperature?
After I have been reading up on your unit it appears that the thermostat is not operating correctly. I found this real basic information on installation for your unit. This link I am giving is pretty basic instal schematics. But seems to be something about your thermostat needs to be dialed in or is not working properly.
http://www.premsales.net/docs/GE/GE%20Minisplits.pdf
I hope this helps some. Mike
Posted on Oct 21, 2011
  • 207 Answers
SOURCE: Wall thermostat shows NO POWER, But there is power at recepticle
hmmm no clue needs time to reserch
Posted on May 23, 2008
  • 587 Answers
SOURCE: AC will only work in the early morning.
If your AC only works when it is cool outside, then you probably have a dirty condenser coil, you're overcharged on refrigerant or the outdoor fan is not running at full speed.
Posted on Sep 26, 2009
I have an TX-SR313 for a year now and it was working perfectly until yesterday it just automatically shots off even when I turn it on for several time it just shots off. How can I solve that Problem?
Hello, It seems like the receiver is going into protection mode. A unit will only go into protection mode for two reasons mainly. The first reason is if there is an internal short. The second is if there is an external short which is typically only caused by one or more of the speaker connections. To isolate whether the short is internal or external, you would first need to unplug the receiver and disconnect all of the speakers. At this point you will plug the receiver back in with no speakers connected and turn the unit back on. Also turn the volume up to about 70 (even with no speakers connected). If the unit stays on that means that one or more of the speaker connections was causing the receiver to go into protection mode. If the receiver shuts off again with no speakers connected, then that means the unit would have an internal short and would have to go in for service. Thanks, FJD
Apr 17, 2016 | Onkyo Tx-sr313 5.1-channel Home Theater...
Stratus wont start
Could be crankshaft sensor.
Apr 27, 2013 | 2004 Dodge Stratus
BOSE LIFESTYLE TV SENSOR PROBLEM
Usually on any equipment with a remote---if you hold remote real close and it works you have either a dirty lens for the receiver or a defective infrared receiver in the unit-----odd that moving things would cause this.
If it is only the on/off function having a issue--that would rule out both of the possible solutions I suggested.
Be sure batteries are new/good and no indirect light is hitting front of unit where receiver is located.
May 18, 2012 | Audio Players & Recorders
I own 3 of these. Two of them have been hooked up for over 3 years and worked perfectly until yesterday. All of a sudden, the remote wouldn't work and I couldn't turn the unit off with the power button. ...
If you are using these DVRs over the air only, with 1.2.06 installed you have to run the G* Test in the 9012 menu, to get the digital data going, after removing power. That is why your clocks are --:--. I highly recommend that you update the firmware in both of these units to 1.2.21, to avoid having to mess with the G* Test.
Aug 17, 2010 | Sony DHG-HDD500 400-Hours Video Recorder
Hello. I have Onkyo tx-sr606 home theater
could be a bad soldered joint or loose connector, even a bad earth in the secondary power circuit.
Feb 27, 2010 | Onkyo TX-SR606 Receiver
HELP!!! Cannot start VAIO ARG230G
do safe mode, and find out if your disk is clean or overly fragmented
Mar 12, 2008 | Computers & Internet
Problem with pioneer vsx-916 av receiver
Be sure you have proper impedance with both sets connected. Some units have a selector switch in the back of the receiver to set the proper bias. ...accordianman
Jan 21, 2008 | Pioneer VSX-915 Receiver
Lost all my Saved Favorites!?!
If the favorites do not show up, unfortunately they may be gone forever. Check the Recently Found and see if any are there, then re-save them. I don't know why it would lose the favorites to begin with, but once gone, they are usually gone. By the way, resetting can remove them also.
Nov 05, 2007 | Garmin nuvi 350 GPS Receiver
GE "General Electric AEN10AQ 10,000 BTU EnerStar Window Air Conditioner, 3 Speeds, 24 Hour On/Off Delay" Logo
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
