How to adjust the scanner to a specific language?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Office Equip... Master
  • 102,366 Answers
What make and model scanner? What program(s) are you using with the scanner?
Posted on Jul 22, 2013
There is a manual for audi a8 l-2009 in the Slovak language?
u can ask for a languages cd from the company, then put the scanner on the car and put the cd in the navigation dvd, put change language in the scanner.. and see what the software tell u... by the way u can choose 3 languages with ur language, when u choose them u can save them and use them whatever u want
Mar 11, 2011 | 2004 Audi A8
Hello. The DLC 7070-M1 shower interprets characters in English (QWERTY), while my keyboard is in French. How to make the shower interprets characters in French? Thank you for your help.
Try downloading the latest version of the driver for the barcode scanner (English name for it). When you install it, there is likely a step that lets you set the language. This is where you would get the computer to show the readout in French.
You may have a barcode control options program on your computer that goes with the driver. If you find one, there is most likely an Options or Preferences menu item that would let you change the language.
Somebody who has actually installed one of these could be more specific, but I'm confident that one of these two suggestions will work.
Oct 29, 2010 | Datalogic DLC 7070-M1
Does the soft ware in the V700 support early colour negative material ? I can find Ilford HP5 but not Ilfocolour !
There isn't a specific template for that film, but you can try out with generic settings and see how it goes. I rarely use the specific film settings from scanner software, and always prefer to adjust them to each roll I scan. Good luck with that! :)
Jul 09, 2010 | Epson Perfection V700 PHOTO Flatbed...
Replacements?
If you go to www.pandigital.net and click on all personal photo scanners/converters, you'll see a picture of your scanner. Click on it. Scroll down to the bottom of the page and there'll be options including downloads. Click on downloads and you'll have to know your product specifications to get the right one, but the manuals are all there, in all languages, so make sure you get English. Hope this helps a little.
Jun 18, 2010 | PANDIGITAL Panscn02 Photolink Scanner
Needs canoscan drivers
Drivers are specific to the operating system (ie drivers for Windows XP may or may not work with Vista). Click on the link below and you will be navigated to the Canon driver download page. Choose your operating system (OS) from the drop-down menu, your preferred language and you will be ready to download the drivers.
CanoScan LiDE 600F
Oct 05, 2009 | Canon CanoScan LiDE 600F Flatbed Scanner
Konica bizhub C351 copier with a C9401 error code
To you need a mechanical adjustment.
A. Adjustment of the scanner motor timing belt. This adjustment must be made the scanner motor assy has been removed,or the scanner drive cables have been rewound.
1. Remove the IR rear cover.
2.Remove 16 screws and the reinforcement frame.
3.Loosen the 3 screws that secure the scanner motor mounting bracket.
4.With the scanner drive gear set screw located on the right hand side as shown on the left,slide the scanner motor assy to the left and check that it is returned to the original position by the tension of the spring.Perform this step three times.
5.Tighten the three screws to fix the scanner motor assy into position.
B.Focus positioning of the scanner and mirrors unit. This adjustment must be made in case the scanner drive cables have been rewound
1.Slide the mirrors unit to rhe center until it is pressed up against the cutouts in the rails.
2.If the mirrors unit is not pressed up against the cutouts,loosen the adjusting screw to which red paint is applied of the mirrors unit and press the carriage up against the cutouts.Then tighten the adjusting screw.
C.Scanner position adjustment.This adjustment must be made if the scanner drive cables have been rewound,focus positioning of the scanner and mirrors unit must be completed.
1.Slide the mirrors unit to the position shown on the left.
2.Secure the scanner in the position shown on the left using the 2 scanner positioning screws.
3.Make the FD-Mag. adjustment.:
FD Mag setting range :0,990 to 1,010 in 0,001 increments.
If the specified width om the copy is less than 298,5 mm increase the settings.
If the specified width on the copy exceeds 301,5 mm decrease the settings.
Adjustment procedure:
1.Call the Tech.Rep.Mode to the screen.
2.Touch these keys in this order : Machine Adjust - IR Area.
3.Position the color chart correctly so that the original reference point is aligned with the scale.
4.Press the Start key to make a copy.
5.Check point D( D:300+/- 1,5 mm) on the image of the copy.
6.If the image falls outside the specified range,touch FD-Mag.
7.Change the setting using the up/down key.
8.Press the Start key to make another copy.
9.Check the image on the copy to see if the specifications are met.
10.Make adjustments until the specifications are met.
Good luck,please answer.
Aug 02, 2009 | Konica Minolta Office Equipment & Supplies
Can't change the language
Wow I am so sorry to tell you that searching all the manuals it appears that the phone is made in language specific models and as far as I can tell it can’t be changed! I hope I am wrong but I have looked at the US, Europe, and Worldwide HTC sites and that was spelled out clearly the phone is made language specific. Good Luck
Jul 20, 2009 | HTC Touch P3450 Smartphone
How to scan with mac
    1. Connect a compatible scanner to your computer. A list of compatible scanners is available in technical document 107203 "Mac OS X 10.2: Scanners Compatible With Image Capture "
    2. Install any necessary software drivers that came with the scanner.
    Note: Not all scanners require the installation of additional software drivers.
    3. Turn on the scanner.
    4. Press the scan button on the scanner. See the documentation that came with the scanner for specific instructions. Image Capture opens automatically and a preview scan appears.
    5. Select the area of the image you want to scan.
    Figure 1 Preview image with area to be scanned selected
    6. Click Options in the toolbar to adjust settings specific to your scanner.
    Figure 2 Options icon
    7. Adjust any settings in the drawer that appears.
    8. Click Scan.
The scanned image is saved in your Pictures folder in your home directory and opened in Preview.
Note: These are the default options. They can be changed in the Image Capture toolbar.
Jul 16, 2009 | HP Photosmart C6280 Printer
Change game language nintendo ds
MY daughter chose the wrong language when setting her new game on her ds lite for the first time, how can I get back to the language choice screen on the game to reset it
Dec 11, 2008 | Computers & Internet
Connection problem
If you do not have the software, then you'll need to download it from Brother's web site. The link below is specific to your printer. You'll need to choose "all" software, then choose your Operating System (ie: XP, Vista, Mac, etc), and then language, then click the 'search' button. This will bring up a complete list of all available software for that printer in that language, and for that specific operating system.
You will want to choose 'full driver & software package'.
Enjoy!
http://welcome.solutions.brother.com/BSC/Public/Templates/DownloadTop.aspx?NRMODE=Published&NRNODEGUID=%7b2C7B4D65-D5B3-47BF-958E-322BE5EFDCA8%7d&NRORIGINALURL=%2fbsc%2fpublic%2fus%2fus%2fen%2fdlf%2fdownload_top%2ehtml%3freg%3dus%26c%3dus%26lang%3den%26prod%3dmfc7420_all&NRCACHEHINT=NoModifyGuest&prod=mfc7420_all&reg=us&c=us&lang=en
Jun 12, 2008 | Brother MFC 7420 All-In-One Laser Printer
11 people viewed this question
jasbo
jasbo
