Question about HHB Radius 50 Tube Amplifier
Feedback noise
When i press on the selector button i start to hear a feedback noise and if i increase the drive volume the feedback noise is more louder.i just wnat to cut that noise.
  • HHB Master
  • 5,259 Answers
You have two clues here to help you solve this problem. First since the volume control turns up the noise, whatever causes this noise is before the volume control. You don't state that the noise is in one channel. If is in both, then a part found in either of the channels can not be the cause. If it is common to both channels you are looking at something common to both channels that is causing it. For example something in the power supply?
Posted on Jul 31, 2013
How do I increase the volume on the speaker?
Search Results
    How to improve sound quality and increase volume on ...
    https://www.androidpit.com/improve-the-sound-and-volume-quality-on-...
    Dec 4, 2015 - Not all smartphones are blessed with speaker quality or volume levels to make your stereo envious. ... How do you improve sound quality on your phone? ....I've seen a 'little' cellphone case, foam padded with a zipper, that ...
    How to increse speaker volume on android smartphone
    www.instructables.com/.../How-to-increse-speaker-volume-o...
    InstructablesRequirements:You will need a phone with Mediatek chipset. ... is a quick turtorial on how to increase the volume of front-facing speakers on android smartphone.
    Increase your Android Phone's Audio Output with Speaker ...
    www.techverse.net/increase-android-phone-volume-output-speaker-boost/
Jan 27, 2016 | Cell Phones
How do I change radio volume on the alarm?
This clock is supposed to have an automatically "increasing" volume feature (starts off low, gets louder over a minute or so).
If not sufficient, look on the top right side of the clock, there should be an up/down volume control. It is a black oval-shaped button with a picture of a sound speaker in the middle. Push it upward to increase volume and downward to decrease volume. Unfortunately, you have to have a flashlight or light on to see it because none of the controls are illuminated.
Dec 02, 2013 | Sharper Image Sound Soother White Noise...
How do i turn my sound up
The Windows operating system on your Toshiba laptop contains a functionality that allows you to increase the volume.
Your laptop's volume is a measure of the decibel levels of sound that your Toshiba laptop will put out.
If you are having trouble hearing music of video files, you may need to boost the sound volume, which can be accomplished by following several steps.
Press the "Start" button on your desktop.
Click on the "Control Panel" icon then double-click on the icon labeled "Sounds and Audio Devices."
Click on the "Volume" tab then move the device volume slider to increase the volume.
Close the "Control Panel" when you have completed the operation, and your volume should be louder.
Hope this helps.
Nov 20, 2012 | Toshiba Computers & Internet
Please advise as to how to increase the VOLUME on my DECT 6.0 phone.
To adjust the ringer volume:
  1. With the phone in standby, press ^ or v. The display shows the current volume level and the handset sounds the ringer at that level.
  2. Use ^ to make the ringer volume louder or use v to make it softer or turn it off completely.
  3. When you hear the ringer volume level you want to use, stop pressing keys. The handset will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset won't ring. If you have any accessory handsets, other handsets will ring according to their individual settings.
To adjust the earpiece volume:
You can choose from six volume levels for the handset earpiece. To adjust the earpiece volume while on a call, press ^ to make it louder or v to make it softer. The handset display shows the current volume level for the earpiece.
To adjust the speaker volume:
You can choose from six volume levels for the handset speaker while on a speakerphone call. To adjust the handset speaker volume, press ^ to make it louder or v to make it softer. The handset display shows the current volume level for the handset speaker.
Note: The handset earpiece and the handset speaker have separate volume settings.
Apr 06, 2011 | Uniden DECT 6.0 Cordless Telephone...
The volume on our E67 series tv will not go past a certain level. how can i fix that?
It is true that you won't start to hear this television's volume increasing until the volume level passes 10. Then it gets louder until the volume level gets to 30 then between 30 and 60 it doesn't get any louder. This is the nature of this particular television. You can go into the audio category of the menu and increase the treble and the bass. Listen to the television with surround on and then off to see which one is louder. Connect the television to a sound bar.
After a television is a year or two old it may start to degrade naturally so you might benefit from being walked through an INIT. Call 877-332-7867 to be walked through one and the television may sound louder after it is complete.
Sep 28, 2010 | Sharp Televison & Video
I have a presidian corded phone for which I have lost the manual. I am unable to increase the ringer volume and hence can't hear the phone when it rings. I was in a radio shack store and they had a...
On the Presidian DECT 6.0, there is a screen near the top, with a ring centered beneath. If you press on the top or bottom of the ring, you will make the phone ringer louder or quieter. The display will also show you a volume bar as you make this selection. When you are done, press the button in the center of the ring.
Dec 11, 2009 | Lands Phones
I have a gn9120 headset that i love. suddenly, callers are complaining that they can't hear me. Is there volume adjustment or is there a defect?
Volume adjustment is made by depressing the two + and - together until beep is heard
once beep is heard press the + button several times until louder bleep is heard this will increase transmission from headset and cure the problem
Steve
Jul 15, 2009 | GN Netcom GN 9120 Professional Headset
Motorola Razr sound too low to hear person on the line
when you call some one
try pressing up the button on the left
there are three buttons on the left and 1 on the right
press the up button it will say on the screen ring style volume 7 or 6 or what ever you have set it up to
but during the call when you press the same button it lowers or higher the volume of the speaker
thats the easy way to do it
Nov 05, 2008 | Motorola Mobility RAZR V3
How is ringer volume adjusted?
VOLUME
While talking, press the VOLUME buttons (left and right
arrows) to control the volume of the handset's earpiece.
There are four volume levels. Press the right arrow (+)
button to increase the volume level, and press the left
arrow (-) button to decrease. VOL 1 is the lowest level and
VOL 4 is the loudest.
Jan 02, 2008 | GE Cordless Phone 900 MHz
HHB Radius 50 Tube Amplifier Logo
47 people viewed this question
Top HHB Audio Players & Recorders Experts
John
John
darren dillon
Level 1 Expert
Are you a HHB Audio Player and Recorder Expert? Answer questions, earn points and help others
