The screen just stays black ans says no signal
    Brigadier General:
  • 3,400 Answers
Daniel,check the cabels must be seated tight,also the videocard should be seated tight.
Posted on Jul 21, 2013
Whenever I turn on my desktop the screen just stays black.
It appears that your power supply is good, the startup chime says that the system board has passed self diagnostics. If you have a black screen then the problem is either the video card or the screen itself. Unfortunately it is very difficult to tell which one. You might try to use an external monitor. If it works, then the problem is with the LCD.
To use an external monitor you need a Mini-DVI to VGA adapter, or a Mini-DVI to DVI adapter if your display will use a DVI connection. Either adapter is available at any Apple retailer. The connector on the back of your Imac is next to the ethernet connector, and should be the last in the row.
Apr 27, 2010 | Apple iMac G5 Desktop
Tv does not stay on, screen goes black
Checked all connection given properly checked your cable connection some time cable connection not proper than also its display no signal
Jan 23, 2010 | Westinghouse SK-32H240S Television
Nec Multisync LCD 195VXM+ black screen after turning on computer
I'm thinking your video card is sending a signal the monitor doesn't recognize.
You'll need to start the computer and hit F8 until you get the black and white menu. Choose the VGA mode and it should work well enough for you to adjust the refresh rate or the resolution to get the monitor to work
Aug 28, 2009 | Computers & Internet
Dell E171FP Monitor goes black after 2 secs
Hi, I don't think the problem is with your monitor. Your monitor sounds like it's doing exactly what it's supposed to do. The monitor is supposed to turn off if there's no cable attached, which means there's no signal input. When the screen goes black, does the power light stay on and turn orange? or does it go off as well? I would recommend that you lower your screen resolution to 1280x1024 or lower in the Display Properties window, then remove your primary monitor, and connect the monitor to your desktop computer. You should see it light up when connected. The monitor auto-senses when there's a computer attached to the cable and when there's a signal. If it doesn't see a signal, it goes black to save power.
Jun 17, 2009 | Dell E171FP 17" Flat Panel LCD Monitor
MX 6124 Gateway notebook screen stays black when powering up
Repaired! This sounde like a fuelty screen or screen inverter. To check this, connect to an external monitor, if the external works properly, then it's the screen or inverter. If the external doesn't work, let me know and we'll run the problem down to a more indepth (internal) trouble shoot.
Jun 28, 2008 | Computers & Internet
Black Rectangles on 42" Vizio HDTV LCD
Your DirecTV signal is probably too low. That would produce the small black rectangles (pixilation). Also, try replacing the cable you are using to get the signal from the DirecTV receiver.
May 20, 2008 | Vizio L32 32 in. LCD HDTV
StudioWorks 700s Monitor No Signal
Try to connect the monitor to a different desktop/laptop, to see if it works at all.
Try a different monitor on your computer, to see if the video-card in your computer is the problem.
Or, spend $50 to $100 to buy a used 15-inch or 17-inch LCD monitor.
Sep 20, 2007 | Computers & Internet
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
